Adjustments on Technics SL-B2 Automatic Turntable
You said you have the Technics SL-B2 and it works great. I do not have the manual and wonder if you could tell me what the pitch adjustment does. I've moved it back and forth but am not sure if it changes anything but am not sure what I should be looking for. Also what number should the anti-skipping knob be set on and what numbers should the adjustment at the end of the arm be set on? Would any of these adjustments help to eliminate crackles on some records? Any help you can give me will be appreciated. Thanks
  • elizapp Feb 17, 2009
    Thank you ever so much for your help. Your explanation was very clear so had no problem following your directions. Thanks again.
  • 104 Answers
The pitch is just the speed, adjust to your liking.
"How do I adjust tracking pressure and anti skate?
If you are lucky enough to have these two adjustments here's how: Move tracking force counter weight till needle suspends/hovers above record. then rotate numbers to zero. (this is zero grams pressure on record) then rotate weight AND numbers to recommended tracking pressure for your needle usually 1.5 to 3 grams is average. Then rotate anti skate to be equal. That should get you there. If you still have adjustment related distortion then it may be time for a new needle.
NOTE: Anti skate is adjusting side to side pressure WITHIN GROOVE of record. Tracking pressure is how hard the needle is pushing down inside the groove." from
turntableneedles.com/FAQs_ep_33.html
lots of crackles are caused by crummy records and needles. to some small degree are unavoidable no matter what, but above all the records must be clean.
someday the manual may show up for free here
http://www.vinylengine.com/library/technics/sl-b2.shtml
Posted on Feb 11, 2009
  • Steve W Feb 11, 2009
    the pitch is just the speed, adjust to your liking.
    http://www.vinylengine.com/library/techn...
Owners manual for SL-L3 turntable
Two Speed Direct Drive Fully Automatic Turntable with linear tracking ... Technics SL-L3 / SLL3 owners manual, service manuals and schematics are for ... www.vinylengine.com/library/technics/sl-l3.shtml
hope this will be of help
Feb 02, 2012 | Audio Players & Recorders
Where can I purchase a Technics SL - B2 turntable belt? John Maxwell
try MCM electronics supply. (MCMelectronics.com) You might have to buy a kit of assorted belts or ten belts. MATelectronics is another supply house.(matelectronics.com) or google SL-B2 turntable belt.
Jul 28, 2010 | Audio Players & Recorders
Where can I purchase a new rubber belt to drive my Servo Automatic turntable SL-B210 Ths is not an electronic belt
Here is a link for Technics Turntable replacement belts...just scroll way down the page for your SL-B210 belt listing $10.00. Hopes this helps.
http://www.turntablebasics.com/belts/technics.html
Oct 28, 2009 | Technics SL-1210 Turntable
Technics Turntable Auto-return problem - please help !
Great!! You're Happy, I'm Happy.
Now there's some kind of rating procedure on this screen. If you could rate my asistance, I'd appreciate it, Dan.
thanks...
Charlie
May 30, 2009 | Technics SL-BD22 Turntable
Technics SL-B2 Frequency Generator Servo Automatic Turntable will not play
hello
You need a belt.. Lift up the record support..(platter) Underneath you will see a metal post.. Belt goes around that and the bottom of the plate.(there is a rim) . If the belt is there, motor might be bad..
Oct 09, 2008 | Technics SL-1210 Turntable
Using Technics SL-B2
check the antiskating. then i don't know.. maybe the tonearm has to be calibrate
Feb 18, 2008 | Technics SL-1210 Turntable
2,510 people viewed this question
 Grubhead
Grubhead
