Question about Cell Phones
I can't recharge my nokia N73 cell ph. after dialing 123 then option 2 for recharge giving the card activation no. but after pressing hash it is again asking for the card activation no. and the process is going on. i tried by *123* also but not working. pl help my validity is over
  • 365 Answers
Try to recharge by putting the SIM in other phone
Posted on Dec 02, 2008
Application folder and Application manager not opening, after downloading some games and anti-virus software in my Nokia N73
Dear customer
You should format your phone 1) Open your memory card from the phone 2) Connect the battery and switch on your handset 3) Dial *#7370# and ok 4) press security code 12345 and ok
It will take a several time and your phone will restart in a few seconds If your anti-virus and software are downloaded in memory card then format the memory card in your PC. Thank you for contact.
Jan 06, 2011 | Nokia N73 Cellular Phone
How to flash n73 4n
Hello
Remove the back cover and the battery from your cell phone. Locate a silver sticker with a bar code on it. Take note of the 15-digit IMEI number printed on it. At this time, also remove the SIM card and write down the numbers printed on the back of it. The SIM card is the small, white data chip in the silver cradle right next to the sticker. You will need these numbers to obtain your Nokia unlock code.
Request a Nokia N73 unlock code from your service provider. If they cannot provide you with an unlock code, you can buy one online.
Replace the SIM card, battery and cover. Fully charge your handset.
Turn on your handset and type "#PW+".(you get P by pressing the * key three times and you get W by pressing the * key four times)
Enter the unlock code given from your phone company or website. Make sure you dial the number exactly as it was given to you. If you dial this number incorrectly three times, you will be permanently locked out of your handset.
Dial "+1#". At this point, the screen on your Nokia N73 should read "SIM Restriction Off."
Oct 04, 2010 | Nokia N73 Cellular Phone
I want to format my n73 how can i do
here is how to format Nokia N73
1: Turn of the phone
2: Press and hold the green dial button +* + 3 and then power on the without releasing the buttons until it turned on. It will give you a time option after.
Note: Don't release the buttons until it completely on because it won't display the formatting message.
Sep 12, 2010 | Nokia N73 Cellular Phone
N73 no memory card inserted solution
Full format solution for NOKIA
Switch-off your phone. 1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
Mar 10, 2010 | Nokia N73 Music Edition Smartphone
I have nokia n73. there is a problem in its use. whenever i use it , it gives the message of memory full and asks me to delete some data. please tell me some solution.
The phone's internal memory and memory card may be running out of space. Try to delete unnecessary files and free some memory space. Go to Menu>Tools>File Manager. Select the folder or file you want to delete and scroll left or right to switch from the phone's internal memory to the memory card.
Format the memory card and the phone's internal memory if the problem is not resolved above. But it will erase all saved data on both memory.
Memory Card Formatting Procedure
  1. Go to MENU > TOOLS > MEMORY.
  2. On the memory card menu press OPTIONS.
  3. Scroll to Format memory card.
  4. Press Select.
  5. Select Yes
  6. Once the formatting is complete, remove the memory card.
Phone Memory Formatting Procedure
  1. On your phone dial *#7370#.
  2. Press Yes then enter your phone lock code. Default code is 12345.
  3. Formatting is complete when the phone restarts. Insert the memory card and format it again.
Jan 15, 2010 | Nokia N73 Cellular Phone
How to switch fixed dialling on nokia n73?
Press menu button and select Contacts > Options > SIM contacts > SIM directory to see the names and numbers stored on the SIM card. In the SIM directory you can add, edit, or copy numbers to contacts, and you can make calls. To view the list of fixed dialing numbers, select Options > SIM contacts > Fixed dialling contacts. This setting is only shown if supported by your SIM card.
Oct 17, 2009 | Nokia N73 Cellular Phone
Nokia n73
first of all u have to check that ur ph. imei is in proper digit
or this type (??????????????????).
if ur imei is currupt u have to rebuild software in ur mobile
Feb 27, 2009 | Nokia N73 Cellular Phone
Phone memory full option
Press menu -> msg -> option -> other -> there will phone memory selected change it 2 memory card.
take care
Feb 20, 2009 | Nokia N73 Cellular Phone
How to get IMEI for nokia n73 phone
just dial *#06# and you will get the imei.
Oct 31, 2008 | Nokia N73 Cellular Phone
How to format my phone n73 memory full actully my phones memory showing full and due to that i am not able to perform any application. pls provide me any solution myself Dipesh Thanks
hi
on dailing screen dial *#7370# then the phone automatacally give you the option for restoreing the factory settings then press "ok" here is your mobile formate
thanks
your friend from fixya!
Oct 24, 2008 | Nokia N73 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
