Question about Kenmore 63792 Microwave Oven
My outside glass is slipping down. - Kenmore 63792 Microwave Oven
  • Kenmore Master
  • 9,098 Answers
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove to find out what parts need to be replaced.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Posted on Dec 08, 2008
THE GLASS ON THE OUTSIDE OF THE DOOR HAS DROPPED DOWN ABOUT 3/4". 1) IS THIS DANGEROUS? 2) HOW CAN WE FIX IT?
This is probably not a leakage issue. However, the door has to be removed and disassembled (or replaced) to reset the glass. By DHHS rules, anyone who performs a door repair is required to perform a microwave leakage test with an approved 'Microwave Survey Meter' How old is this unit?.
Nov 03, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Goldstar Mv1526W
is the lock/screw was loose//?
Jun 11, 2008 | Goldstar MV-1526 Microwave Oven
The outside glass on the microwave door has slipped down. Is that dangerous and can it be fixed?
Its not real good as it could shatter if door closed hard and there to protect against microwave radiation on the front.
A repair shop who looks at this will know first if door can be opened up and fixed or the door will have to be replaced.
Dec 17, 2012 | Goldstar MV-1615 Microwave Oven
Is there anyway to view cleaning instructions for pop up toasters online
Model number?
In general unplug it, go outside, remove any slip out tray from underneath and shake toaster, also turn it upside down and shake it, dont touch the elements or poke near them and wipe down the outside with mild detergent/hot water mix.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
Mar 06, 2011 | Microwave Ovens
PLMVZ169HCA Turntable slips on the glass plate
hmmm? me's thinking about this one!!!!
the glass plate has drive dogs on the bottom of it, that fit into drive dogs on the turn table, if its not meshed up right it just spins freely and normaly throw's the glass plat off??? are the bearing that are under the glass plate turning freely? thats the big ring that the plate rides on near the out side edge of the plate, and can be taken out for cleaning??? it looks like a hoop with 3 or 4 rollers in it??? if you forgot to put this bit back in the right way up after cleaning it thats the problem???
Oct 23, 2009 | Frigidaire PLMV169DC Microwave Oven
The glass on the microwave door on the outside has slipped down and there is no screws to take apart the door and fix the glass. Does this fall under the warranty? My 5 years is up on 12/01/09.
I would contact customer service (for Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here about the warranty and to find your nearest authorized servicer.
If not, it's pretty easy to fix this yourself.
There are probably broken tabs on the inner or outer door panel.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Sep 26, 2009 | Maytag MMV1153A Microwave Oven
Outside glass dooor on Whirlpool oven fell off, what do i do?
Sep 15, 2009 | Whirlpool MH1150XM Convection/Microwave...
Microwave door glass has slipped down into the frame
What usually happens is there are tabs on one of the inner door panels that holds the glass up.
If one tabs breaks, the other one soon will, then the glass slips down.
If the mesh / screen is still in place and undamaged, and the door is otherwise undamaged, there shouldn't be any leakage.
You or someone you know may be able to take the door apart and use epoxy to fashion new retainers for the glass.
Or you can usually order the specific door panel piece that you need but if you want to, please reply back with your brand and model number so we can help you.
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 07, 2009 | Microwave Ovens
Loose glass in door
Silicone glue would be best since it has very good heat tolerance and, if the clear is used, there will be no problem with it absorbing energy but I wouldn't use any with colorant as it could have metallic pigments.
Dec 23, 2007 | Whirlpool GH7145XF Microwave Oven
Glass front on door unglued
First: do not use this unit with the glass improperly installed. Often, these installations use double sided foam tape, available at any hardware store. Carefully remove the screws in the door being careful to catch the glass. Clean the area where the tape will go with glass cleaner or alcohol. Allow to dry and buff to remove oil and grease. Install the tape and glass. Reassemble.
Dec 18, 2007 | Maytag MMV1153A Microwave Oven
Kenmore 63792 Microwave Oven Logo
54 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
