Question about Canon PowerShot SD600 Digital Camera
Switching to movie mode automatically even when on camera setting
my canon sd600 often goes into movie mode automatically when I switch it to camera mode. so it starts taking a movie even though the setting is on camera. please help!
thanks a lot!
  • lxinatr28 May 18, 2009
    Mine does that too. I'm about to take it apart and see what I can find. But I bet I'm going to have to just buy another.
Ok. I took off the 6 small screws holding it together, inspected it to see if it was anything obvious and easy and but no. I seen the small switch inside and figured it was at fault and needed to be replaced. (yeah right! like that could be done) then put it back together and so far the problem is gone. now i just have to wait and see if it stays that way. so far so good.
Posted on May 18, 2009
Why can I not get my Canon PowerShot S3 IS to switch to the PLAY mode?
Search Results
    [PDF]Manual
    gdlp01.c-wss.com/gds/3/0900001323/01/PSS3ISCUGba-EN.pdf
    Avoid dropping or subjecting the camera to severe impacts. Do not ... 2006 CANONINC. ... When switching between shooting and ... The camera switches to Playbackmode, but the lens does not retract ..... Play/Print/Set up/ My Camera Menus.
    Canon S3 IS Review: Full Review - Operation
    www.imaging-resource.com/PRODS/S3IS/S3ISA3.HTM
    Record Mode LCD Display: In Record mode, the PowerShot S3 IS's LCD reports ...Unlike its behavior in Record mode, the Display button will not let you view ... switchwith the red camera icon, this mode sets up the Canon PowerShot S3 IS ... exposure setting you've chosen if the camera can't get a good exposure with it.
    [PDF]Download
    galeria-zdjec.pl/ksiazki/instrukcje/Canon/canon_pss3_eng.pdf
    Shoot movies in any mode by pressing the movie button ... with My Colors ... caused by the malfunction of non-genuine Canon accessories (e.g., ... warranty does not apply to repairs arising out of the malfunction of .... Switching between Metering Modes . .....Do not get the camera caught on other objects or subject it to.
    How to give your low-end Canon digital camera RAW support
    archive09.linux.com/feature/118946
    Linux.com
Jan 24, 2016 | Canon PowerShot S3 IS Digital Camera
Just bought a new eos d600 . How do I turn on the autofocus?
Set the autofocus switch on the lens to AF. Press the autofocus button on the camera (right on the cursor pad) to bring up the AF mode. Use left/right or turn the command dial to select the desired autofocus mode and press SET.
It's in the "Changing the Autofocus Mode" in the manual (page 83 in my copy).
Mar 23, 2011 | Canon PowerShot SD600 Digital Camera
I have a 4 year old Canon SD 600 and these days it defaults to video mode even in photo mode. I have tried everything, taking out the battery for a long time and putting it back, but always stays on video...
If you have tried to move the switch on the back between the stillphoto, view and video setting, and it does not change modes, the cameras life is as you put it, over.
Mar 08, 2011 | Canon PowerShot SD600 Digital Camera
SD600 stuck in Video Recording mode
This worked for me. Take out battery and card. Wait a few minutes. Set camera in Auto (stil pic) mode. Replace card and battery, turn on. Select function, tab through all options returning to auto. Press function. This seems to be working, Let me know how this works for you. I found nothing on the Canon site. A sad commentary on the company.
May 31, 2009 | Canon PowerShot SD600 Digital Camera
Pictures too bright
This has happened to me also. You mention that you were changing settings. The symptoms sound like your camera is in a special setting other than "Auto". Examples that would produce such results include Fireworks or Manual. Recommend trying to change your settings one more time:
1. Turn the camera on, and press the FUNC/SET button.
2. Press left or right on your circular dial switch until "Auto" is selected.
3. Press the FUNC/SET button one more time to set the camera to Automatic.
Now take a picture to see if this fixed it.
May 11, 2008 | Canon PowerShot SD600 Digital Camera
POWERSHOT SD600 WOULDN'T SWITCH ON
Hi , try to remove memory remove battery from partment clean contacts and assemble again .
Mar 22, 2008 | Canon PowerShot SD600 Digital Camera
"Card Locked" error is false!
Remove card from SD600 camera. Locate sliding switch on side of SD card and move from lock to other (unlocked) position. That ought to do it. Compact flash card is another issue.
Mar 19, 2008 | Canon PowerShot SD600 Digital Camera
Stuck in movie mode, but won't record
internal microswitch connector has been damaged.so it has been stuck at movie mode ,it can be replaced.
Mar 06, 2008 | Canon PowerShot SD600 Digital Camera
Playback function
Unless your an electronics expert, you run a very high degree (89-100%) of probability that the camera will never work again. If your cameras aren't under warranty, than call the canon north america offices, and explain the problem they will more than likely work with you considering this is a wildly popular problem with this specific model.
Oct 23, 2007 | Canon PowerShot SD600 Digital Camera
Pictures are too bright when shooting outdoors in sunlight
Have you tried changing your settings manually to outdoor? Or adjusted the aperture? You can usually find the aperture settings under the menu button. If not, try adjusting to outdoor conditions and disabling flash. And also, lower your white balance a good bit.
May 01, 2007 | Canon PowerShot SD600 Digital Camera
Canon PowerShot SD600 Digital Camera Logo
199 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
