Garmin nuvi 755T Car GPS Receiver Logo
Todd S Posted on Mar 05, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Garmin Nuvi 755t Stuck in power up cycle
Garmin Nuvi 755T-At approx 18 months old. It would randomly turn off (while driving). It would turn back on when power slider was moved to and held in the "on" position (regular start up). It did this for approx an hour. Then it turned off by itself and tried to restart by itself. Garmin comes on the screen, and every 8 seconds it flickers. It never goes past this point. Using the gargin usb cable and going to garmin, it always says "No garmin device connected". Obviously, it's stuck in power up cycle. Would changing the battery, or unplugging the battery help?? Btw, this happened just over a year ago. It's plugged in to the computer as i'm typing this and it's doing the exact same thing!! Garmin appears on the screen and every 8 secs, it flickers and just says garmin. Would love to have my garmin working again, but not sending it to garmin for $100 to get a refurb with 09 maps!!! Can hardly believe they don't put most current maps on the refurb!!! They make you pay for it . . . . ANY help greatly appreciated!!! Thanks!!!
  • Todd S Jun 21, 2012
    Appears no one else has had this problem :( I just hate to spend the money on a new battery if that's not going to fix it.
Michael Grimes
Level 2:
Scholar:
  • Garmin Expert 195 Answers
  • Posted on Apr 08, 2017
Michael Grimes
Garmin Expert
Level 2:
Scholar:
Answers
195
Questions
0
Helped
38717
Points
395
You can do two things.
First, plug the GPS in overnight in a regular USB charger. If the battery charges up, then the problem is with your Garmin vehicle cable.
If it does not charge up, you can buy a battery replacement kit for it: https://www.amazon.com/Garmin-Nuvi-755-Replacement-Installation/dp/B003VFSR4M
2 Related Answers
Anonymous
  • Posted on Apr 24, 2010
SOURCE: How to charge Garmin 755t
I had the same problem with mine & it was only 6 months old. The battery needs to be replaced. This is a good site that shows you how to change the battery & you can order the new battery from them as well. http://www.newpower99.com/
Anonymous
  • 2335 Answers
  • Posted on May 27, 2010
SOURCE: Garmin Nuvi 1300 (and 1490T) won't start up
A Garmin Nuvi 1300 that won't start, freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
2answers
I can't adjust bluetooth,there is no "bluetooth" icon.
The Nuvi 755T does not have bluetooth capability. See this link to see the specifications of the 755T from the Garmin website:
https://buy.garmin.com/en-US/US/prod14933.html
Bluetooth wireless technology No
You would have to have a Nuvi 765T to have bluetooth
https://buy.garmin.com/en-US/US/prod14926.html
Bluetooth wireless technology Yes (with A2DP technology)
No bluetooth icon on nuvi 755t.
The Nuvi 755 does not have bluetooth capability. You would have to upgrade to a Nuvi 765.
Car power supply for Garmin nuvi 755t does not work. Not sure if its the Wire, mount Adapter or other.
I assume you have checked the cigarette lighter to be sure it's working.
The most likely problem is the fuse in the power cord/charger. The plug which goes into the cigarette lighter socket has a ring at the end of it. Unscrew the ring, taking care not to lose any small parts, and it comes apart. Replace the fuse and it should be ok.
Garmin Nuvi 755T touch pad gone askew
the touch screen is defective, i suggest that you replace the GPS, a new touch screen installed is about $250
1helpful
Garmin 755T - Same Problem
Have you tried a complete reset? If not this is what you do. Turn on the Garmin at the same time press the bottom right hand corner of the screen. this will return it to factory standard, but it will wipe out any information you may have stored on it.
3helpful
2answers
My garmin 755t power on stop working!!!
HI, same problem. I bought my 755t just over a month ago. I found a solution on this site.
U can opt to have garmin fix it (who knows how long it may take?) or if you are handy, there are 2 little screws at the back of the 755 remove them and pry the back cover open. Just be very careful not to disturb the wires too much. Disconnect the battery and reconnect it 10 or 15 minutes later. That's all. Close the cover and replace the 2 screws. Install latest software I think it is version 3.60.
There is software bug that comes up randomly and sets the unit into an update loop that is with version 3.40 on a certain day of the year. I think on the longest day of the year. Anyhow, I fixed mine 3 days ago it works flawlessly.
Itunes to garmin 755t
You will need to convert your iTunes library to MP3 format, and then transfer to the Nuvi 755t in order to play them.
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
