Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Water leak at filter
The inlet hose going to the filter is leaking at the fitting. How do you remove the water line? Whirlpool refrigerator model GD55HA. I simply want to remove the hose from the fitting.
I had this with a Kitchenaid Superba and wanted to get rid of the filter holder assembly entirely as I have an undersink unit which serves the fridge. I removed the plastic line (nut) at the back of the fridge (which led to the filter holder at the front) where the flexible copper tubing inserted (this was a 3/8' compression fitting-plastic) and also the returning line (1/4" copper compression nut on a plastic line) at the manifold (again in the back of the fridge) where it gets split between the water line and the ice line. I then just connected the 1/4" flexible copper directly to the manifold (1/4" nut, compression sleeve, male-male connector) using a pre-made 1/4" flexible compression line. Sounds complicated but after seeing how the water routes it was fairly quick work.
Posted on Mar 07, 2010
Can the water filter housing be the cause of slow water when the filter is in place?
Even a new filter will reduce the flow some what. I think the pressure to the filter is low or restricted . that will cause a reduction in flow, no it should not leak, check on the seal.
May 27, 2015 | Whirlpool Refrigerators
How to replace water line whirlpool refrigerator
You should valve the water off to stop the leak first. You can remove the complete line that is defective, usually a 1/4 inch tube either plastic or copper. Use two wrenches to loosen the compression nut fittings on each end, one wrench holds one part and the other wrench on the nut on the 1/4 inch line. Your local hardware store should have a kit or replacement parts readily available if you bring them what you removed, the water line and connecting device. It may be a good idea to replace the water filter while the water line is out of service. The water filter should be flushed out before using the water from it.
Mar 31, 2014 | Whirlpool Refrigerators
Hi, I just found a leak in the back of the fridge from the green water line. Is it something I can fix easily or should I have an expert take a look?
If water appears to be leaking from the back of the refrigerator, check that the water line from the household water supply to the refrigerator is not damaged or cracked. Check all connections that are accessible such as the connection at the supply valve and the connection point of the supply tubing onto the back of the refrigerator. Check that the tubing is firmly inserted into all fittings and all fittings are tightened.
Saddle Valve Shutoff Valve
Leaking from under the door
On exterior dispenser models, if water appears to be leaking from under the refrigerator door, look and feel under the door to ensure the water connection to the dispenser is properly done. Firmly push the water tubes into the fitting.
NOTE: This connection was disconnected if the doors were removed during installation or if the door swing was reversed.
Leaking at the filter
Ensure that the filter is correctly installed.
Jul 02, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
GOOD MORNING, I AM WORKING ON A WHIRLPOOL S/S. REFRIGERATOR MOD#GS5SHAXNLOO. THIS IS THE MODEL THAT THE WATER FILTER HOUSING IS LOCATED ON THE BOTTOM BEHIND THE KICK PLATE.I WAS WONDERING IF ANYONE ELSE...
I think your unit is clogged somewhere, the water should drain into a pan under the freezer and down a tube to a pan under the fridge which is located just behind the front kick plate. here it should evaporate NOW if the tube gets clogged the water has to to go someplace. meaning the leaking water may not exactly be coming from where you are thinking, it could be somewhere up stream. you could apply some silcon on the poits you suspect and see.
Regards
Jul 01, 2010 | Refrigerators
Leak from refrigerator bottom when dispensing water
Good day,
The water supply starts at the dispenser, runs thru the door to the door's bottom where it connects to a swivel connector.
From there it travels under the machine and back into the fresh food compartment to a reservoir located behind the crispers where it is chilled.
It comes back out and travels to the filter system if you have one, and from there to the water valve located on the back rear of the machine.
One of the plastic lines or a fittings is leaking.
It's a look-see repair. Should be one person drawing water, while a second should be looking with a flashlight.
Nov 20, 2009 | Whirlpool Refrigerators
Whilpool ed25sm Cold water dispenser leaks
your water valve is bad. behind the ref. in back is a cover. unplung unit remove ref. from back wall about 2-4 ft.remove back cover and you will see a water valve. thats the piece that the hose (your incoming water supply line hooks upto) 1/2 fitting. turn water suppy off. remove screw holding valve. disconnect wires one bye one and hoses one bye one.(so you dont mix them up).if your ref has a inline water filter and has not been replaced in a while i woiuld try that first. valve is about 45-85/ depending on your model ,i do not have that.and labor roughly 75-125 to replace depending on were you live and who you use. hope this helps you.
Sep 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Whirlpool refrigerator also leaks water from back.
Leaky dispenser ???
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. If so you need to replace the valves.
Aug 20, 2009 | Refrigerators
Refrigerator gushing water through ice maker filter
Filters themselves don't usually leak. Check full insertion of filter, cracked filter housing or cracked supply line.
Aug 14, 2009 | Whirlpool Refrigerators
Water leak where hose meets refrigerator connector
I had a similar problem several years ago with water leaking on the floor at behind the fridge. Turned out to be the gasket at a connection the same size as a garden hose at the water valve, so I used a garden hose washer and that did the trick. That was on a Whirlpool vintage about 1990. Can't say what the model was.
Mar 01, 2008 | Refrigerators
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
328 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
