Trying to install new HP laserjet but while the installation CD is installing the software, it halts with a Fatal Error called: Error 3726, then MSI.selfinstallingportmonitor ....what is that all about, and what can I do to fix this? My OP System is Windows XP
  • 1 more comment
  • baymont Dec 02, 2008
    I did that while on the phone with HP tech support, but it didn't help. The tech guy must have thrown up his hands after 2 hrs on the phone, booting and re-booting and downloading, but the same error keeps popping up to halt the installation.
  • larvin Dec 22, 2008
    Yes today i had the same problem on colorjet 7100. I installed it at one xp machine with out problemes, but on the next on the lan, it went wrong.
  • rick100 Jan 23, 2009
    I had similar problem with installation of HP color laserjet CM2320nf. It says " Fatal error during installation. Error 1327, Invalid drive Z:. It also asked me to go to HP.com/support and look for information on MSI.selfinstallingportmonitor but I couldn't find any info on their site. My colleague spent a lot of time with HP on phone but so far no solution. Any info/ help is much appreciated.
Had exactly the same problem. Previous HP installs are causing this issue. Cleaning up temp directory (c:\windows\temp) fixed the problem.
Posted on May 26, 2009
    Genius:
  • 2,785 Answers
Plz download the drivers from the manufacture website and try to install it.
Posted on Dec 02, 2008
Scanner software can not install
hey edmrb. Sorry to hear your having trouble. Try working through this document to see if it helps resolve the issue.
A 'Fatal Error' (MSI error) Displays on the Computer During HP Software Installation in Windows
Let me know if this helps resolve the issue. If not post back with any new information and we can go from there,
Mar 07, 2014 | HP LaserJet M4345 MultiFunction Printer
Error 2753 HP3050
If it is related to the infamous Fatal Error, MSI.dot4msi, code 2753 of HP installations, then it is not a compatibility issue, but an installation problem.
The HP un-install does not clean its previous installations well, causing some of the dll-s to be locked by Windows, thus disabling install of the new software.
What you need to do is manually delete any trace for HP previous installs from your PC.
Search for HPz*.*, HPw*.*, HPq*.* files, and delete them. Those files that you cannot delete - rename them and delete in safe mode.
Also, search the registry for any HPAIO entries - delete all of them.
Then, reset your PC, and install the new software.
It worked for me (and this is the only thing that worked...)
Good luck
Jun 09, 2009 | HP LaserJet 3055 All-In-One Printer
Fatal error MSI: DOT4WRP
Very simple.Insert the printer installation software cd
First right click your cd drive and select open then go into the folder called util.
Then go into the folder called "CCC".
In that select uninstallation l3
once this uninstallation completes.
go into Local Disk C:\program files\hp\
and delete the digital imaging folder as much as can be deleted.
restart the computer.
goto hp.com and download the software for officejet 6500
After downloading it run it and when the type of uninstallation comes select advanced.
Next select custom installation and uncheck.
hp updates.
Hp Customer Participation Program
Hp Web Printing.
click on next first select usb installation and click on next(irrespective of whether it is a usb or wireless connection).
click on next and dont plug in the usb cable.
at the bottom there will be a box that says check this box if you want to connect your device later.
click on next.
the installation will finish.
Now insert your printer software installation cd and click on add a device or install and now you can choose your type of printer connection and your issue will be resolved.
Apr 21, 2009 | Xante Accel-a-Writer 4G Laser Printer
Fatal Error while install software for HP C8180 printer, Vistax64
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 04, 2009 | HP Photosmart C8180 All-in-One InkJet...
Install Failed - GetDatFilename() Returned False HP Laserjet 3055
You can find & download the need drivers /program here;
http://h10061.www1.hp.com/ccsearch/search?pname=LaserJet+3055&opname=HP+Photosmart+C4180+All-in-One+Printer&qry=driver&submit.x=10&submit.y=9&method=prodFinder&enc=UTF-8&ctry=us&lang=en&dlc=en&sni=1141647&search=0
Good Luck!
Rich Lilja
Dec 03, 2008 | HP LaserJet 3055 All-In-One Printer
Fatal error installation of ProL7590
There are alot of fatal error messages. You need to provide the exact fatal error message.
Here are the basic troubleshooting for that type of error :
1. Turn off your firewall, anti-virus and spyware and then install it
if it will not work
2. Download the software for your printer in the website www.hp.com/support make sure that you are going to download and install the full feature of the software
Aug 03, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
Fatal error installing HP 3055 all in one
Try download he right software for your OS from HP.com, typically software issue. Be sure to choose the right language for your full software solution, get fatal error when trying to install software with wrong language support.
Aug 02, 2008 | HP LaserJet 3050 All-In-One Printer
Error 1603 Apparently Win XP, Me and 2000 have a security function that doesn't let you overwrite existing twain and/or twunk files.
So you have to install these files manually:
Search on the installation CD or in the unzipped downloaded full solution the folder setup\scan, there you'll find the file data1.cab.
Doubleclick it and extract the following files to a temporary folder:
F1922_TWUNK_16.EXE.096CD9AA_35CA_455C_ADCB_36EF6B7F7892
F1923_TWUNK_32.EXE.096CD9AA_35CA_455C_ADCB_36EF6B7F7892
F1928_TWAIN.DLL.096CD9AA_35CA_455C_ADCB_36EF6B7F7892. F1939_TWAIN_32.DLL.096CD9AA_35CA_455C_ADCB_36EF6B7F7892.
Rename these files to twunk_16.exe, twunk_32.exe, twain.dll and twain_32.dll respectively
Copy (and overwrite if necessary) them to the Windows directory (c:\winnt in my case)
Now you can re-install the complete HP software again, in my case it worked and I'm now able to fully use my CM1015 multi-function printer!
Dec 13, 2007 | HP LaserJet 3055 All-In-One Printer
Computers & Internet Logo
694 people viewed this question
David Payne
David Payne
