Question about Sharp Notevision PG-M20X Multimedia Projector
I have a Sharp PG-m20x notevision when I turn it on the red light blinks, no fan, not working. any ideas?
  • Anonymous Apr 08, 2009
    I moved the projector worked and turned off, only blink the red light
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 8 Answers
I had the same problem with the blinking red light on my PG-M20X. It looks as if realy RL701 on the main power board is the problem. I removed the cover of the relay and cleaned the contacts. Despite the contacts being worn down it worked great. I have ordered a new relay from Sharp for about $35 to replace it (part # 95CK3102AL001).
Posted on Aug 11, 2009
Thank you so much for your suggestion! i sent my unit and thay fixed the problem once. this time, I took off the cover and looked for that relay and lightly sanded the conections on the relay (after taking the black cover off). and presto it works!!!!!!!!!!
thanks, i would have never been able to fix this on my own.
Posted on Nov 07, 2009
  • Henry Rancourt Nov 06, 2012
    How did you get the cover off? I removed the 3 screws on the bottom and still could not get to relays.
2 Suggested Answers
projdoc
  • 2237 Answers
SOURCE: I got a free sharp notevision PG-m20x. I plug it
if you don't hear a high-pitched whir, the colorwheel needs replacing. if you do hear it, the lamp may need replacing. if the lamp is new, there is a power supply problem.
Posted on Sep 10, 2009
Power light comes on red then blinks but never progress from there
This sounds like the same problem that I had with a blinking red light on the PG-M20X. Below is the solution that I posted a couple of years ago:
The RL701 relay on the main power board is the problem. I removed the cover of the relay and cleaned the contacts. Despite the contacts being worn down it worked great. I have ordered a new relay from Sharp for about $35 to replace it (part # 95CK3102AL001).
Feb 03, 2011 | Sharp Notevision PG-M20X Multimedia...
Sharp projector PG-M20X will not power on an power light is flashing red
I had the same problem with the blinking red light. I looks as if realy RL701 on the main power board is the problem. I removed the cover of the relay and cleaned the contacts. Despite the contacts being worn down it worked great. I have ordered a new relay from Sharp for about $35 to replace it (part # 95CK3102AL001).
Aug 18, 2010 | Sharp Notevision PG-M20X Multimedia...
I turned the projector on and worked for a while then it stopped projecting the bulb light is blinking red and the power is green any help
It appears that the unit is overheating. Make sure that the fan comes on and that you do not have the projector sitting on a rug or fabic that will restrict air flow. j.
Aug 07, 2010 | Sharp Notevision PG-M20X Multimedia...
There is a blinking green lamp light and the lamp will not fire up. it keeps shutting off
Time to replace the lamp, sounds like it has expired. Lamp light is probably about to go red too when it's really bad! :
Good Luck!
Jan 10, 2010 | Sharp Notevision PG-M20X Multimedia...
Sharp PG-M20X digital projector runs 2-5 minutes then shuts off
the Fan has the problem , I had the same of yours. I noticed some particle was inserted in the center of the fan and removed it , worked perfectly. If old one produce little particles.
Good luck.
Dec 03, 2009 | Sharp Notevision PG-M20X Multimedia...
Sep 04, 2009 | Sharp Notevision PG-M20X Multimedia...
The Notevision came on and powered up. I left the room and came back and the red light blinks but the motor does not come on.
I had a similar problem with the blinking red power light. It looks as if realy RL701 on the main power board is the problem. I removed the cover of the relay and cleaned the contacts. Despite the contacts being worn down it worked great. I have ordered a new relay from Sharp for about $35 to replace it (part # 95CK3102AL001).
Apr 23, 2009 | Sharp Notevision PG-M20X Multimedia...
Red blinking light fan not working and ideas?
I had the same problem with the blinking red light on my PG-M20X. I looks as if realy RL701 on the main power board is the problem. I removed the cover of the relay and cleaned the contacts. Despite the contacts being worn down it worked great. I have ordered a new relay from Sharp for about $35 to replace it (part # 95CK3102AL001).
Dec 02, 2008 | Sharp Notevision PG-M20X Multimedia...
Blinking Red Light
Oct 21, 2007 | Sharp Notevision PG-M20X Multimedia...
Sharp Notevision PG-M20X Multimedia Projector Logo
945 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
