Question about Microwave Ovens
Clarification on microwave
Sharp SN R-510HKF M# 428742 Made in 2005, purchased in 2006
The microwave inside light comes on when you punch in the time and power desired and hit start;
but the carousel does not turn and there is no noise or cooking.
Myhusband fiddled with the door latch and it did respond for a shortmoment; otherwise it has not worked; all the panel lights work all thetime, timer, etc..
  • Microwave Ovens Master
  • 9,098 Answers
That would be a bad primary interlock switch (bottom door switch) or its mount is loose or broken.
See this link: http://www.microwavedisplay.com/doorsw.txt
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Dec 02, 2008
How do I replace the inside light on my R-520 ks Sharp Microwave
I don't know the exact model but most MWs have a plastic panel that pops off easily. Some, however you must take the cover off the MW oven. Just a tad more difficult.
Dec 25, 2014 | Sharp Microwave Ovens
I have a sharp microwave oven .had it for less than a year and the I inside base has bubbled and the paint is coming off is it still safe to use ?
It is always difficult to give specific advice when the oven cannot be viewed. Howeverwith the risk of paint getting into food replacement would be best. With this being a relatively new microwave it may be under warranty or Sharp may offer some credit for the purchase of a new one 1-800-237-4277
May 27, 2014 | Sharp Microwave Ovens
Sharp Microwave Oven over stove fan goes on by itself
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
So please post a
NEW question, and please include your brand name and the full model number from the tag in or on the unit, as well as the answers to these questions:
Which fan is it?
The
internal cooling fan, which comes on automatically whenever the unit is microwaving?
Or the hood vent exhaust fan which you can turn on and off manually?
Or the convection fan, if it is a convection model?
When is it coming on?
Is it coming on whenever you cook on the stove top?
Thanks!
Oct 09, 2009 | Sharp R-1870 Convection/Microwave Oven
Microwave Will not Run
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
You will need to remove the outer cover, then shut the door and then you can adjust the door latches.
Dec 26, 2008 | Sharp R-9H66 Microwave Oven
Microwave lights up, timer works, not carousel or cooking
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
Otherwise, the best place to order Sharp parts is Tritronics.
You can also call them at 866-779-5835.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Dec 02, 2008 | Microwave Ovens
Sharp Carousel Microwave Model R-510HKF (less than 3 years old) ONLY turns on when button to open door is pressed
This is usually caused by either a bad door switch or a loose door switch mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can probably find an exploded view by entering your FULL model number here: http://www.searspartsdirect.com
We're happy to help and we appreciate your thoughtful rating of our answer.
May 06, 2008 | Microwave Ovens
Sharp R-1505 microwave
The power fuse open , if open replace it don't make jumper it b
cause fire .
the power transformer builtin fuse open/
The door micro switch open /need to replace.
Jan 03, 2008 | Sharp R-1505 Microwave Oven
Sharp microwave r630ds
The problem is in the display control unit mounted in the outer door panel.
We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service.
We have full details, plus *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Nov 23, 2007 | Sharp R-630D Microwave Oven
Sharp carousel microwave R-510HKF
If the internal fuse is good, I would suspect an open thermal cutout on or near the magnetron inside.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 19, 2007 | Sharp R-510HW Microwave Oven
Microwave Ovens Logo
78 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
