Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Sony kp-51ws5520 wont turn on-9 stanby red blinks!
  • Anonymous Jan 17, 2009
    yup, got the same thing happening. I've tried everything, no dice!!
ctf1800
  • 4402 Answers
SOURCE: SONY KP-57HW40 TUNS OFF AND STANDBY LIGHT BLINKS 6 TIMES
6 blinks is usually associated with failure of the horizontal deflection amplifier - which shuts down the high voltage system as well.
The repair requires testing to determine the exact parts that have failed. There are, for example, a few hundred parts and a section of the Jungle IC chip involved. So, repairs could require something as simple as replacing some inexpensive passive components OR as complicated as replacing the jungle chip (very expensive).
most of the time it's the horz. transformer and transistor.
Posted on Dec 20, 2007
SOURCE: Sony KP-51Ws520
9 blinks means, "Zero Crossing Detector" and the probable cause locations listed are "D6166 or D6114 is open (G board)". I had the exact same problem so I just ordered a new G board and swapped it with the old one and now everything works fine! You could order a new one at this site: http://www.partstore.com/PartSearch.aspx?PartNumber=A1054157A&x=31&y=19. The Sony board number is A1054157A. Replacing the G board is rather simple; all you got to do is pull out the back cover of the TV and the G board is the first board on your very left. After that unplug the four connectors and replace it with the new one. Here is a picture of the G board inside your TV: http://img47.imageshack.us/img47/8396/backev6.jpg. Hope this helped!
Posted on Jul 16, 2008
ladywinn
  • 5138 Answers
SOURCE: 9 blinks
D6117- Change switching Regulator on G board you can also do Self-Diagnostic Mode Press display ,5 . vol- ,power. this should turn set on and show other codes telling you what else maybe wrong. TO Remove codes and clear back out Press display,5,vol+,power Now Press 8 and Enter.
Posted on Jan 05, 2009
SOURCE: Sony Wide Screen Projection TV KP-51WS520
I had the same problem. blinking 9 times, pausing, 9 times...... remote would not power the tv on. after five minutes of pressing the remote it finally would. after turning it off you would have the same problem. sometimes a half hour of pressing remote in every which what way. finally left the tv on for three days and would mute at nite to go to bed. didn't think that was the best way so turned it off and it never turned back on. checked all the forums and found out it was the g board. unfortunately, you cant buy the whole g board anymore. if you take the back panel off the tv, on the lower left corner is where the g-board is. there are 3 little things to unplug and two screws (phillips head) in the middle of the g board. its simple to figure how to take it out. go to the sony direct parts website. the part # is A1054157A for the g board. since they dont sell it anymore they have a phase 3 program where you send in your old g board and they repair it for 64.95. it'll cost about 8 bucks to ship it to them. better than the 400 bucks the tv guy wanted. address is sony customer satisfaction ctr. , materials door 27H, mount pleasant, PA 15666 there number is 866-748-8272. call first and they give you the step by step instructions what to do. after tax and shipping it came out to less than 80 dollars.even came with a warranty. got it back in a week, popped it in and just love turning the tv on. anyone can do it.
Posted on Feb 06, 2009
  • 178 Answers
SOURCE: Sony KP-46WT520 TV won't come on.
That is a diode in the sub power supply, it is a small board with only a few parts on it to the left of the d board, for the zero crossing detector. D6301 sony part number 6-500-567-21
Posted on Sep 02, 2009
Testimonial: "WOW!! Impressive. Thanks for the fast reply"
The standby light just blinks when i try to turn it on and it wont turn on
Count the number of blinks of the standby light. It will bink a count, pause and do it again (Common counts are 2 -9) Give this count to a Sony service center and they can help you know what the issue is. (Probably the lamp)
Apr 17, 2010 | Sony KP-51WS520 51" Rear Projection...
The tv wont turn on. the red light blinks 9 times.
There is a problem with one or two of the diodes on the G board.
Zero Crossing Detector 9 times 9:0 or 9:1
Probable cause • D6116 or D6301 is open (G Board)
symptom • No picture
I hope this helps and good luck!
Oct 31, 2009 | Sony KP-51WS520 51" Rear Projection...
Wont turn on
Nine blinks means, "Zero Crossing Detector".  The probable cause listed is "D6116 or D6301 is open (G board). (http://www.manual.agoraquest.com/viewtopic.php?topic=22865&forum=34 )
If you don't know what this means I'd reccomend contacting a certified electronics repair shop.
May 24, 2009 | Sony KP-51WS520 51" Rear Projection...
Set wont turn on, stand by lights blinks 9 times
Have the same thing happening with ours... we were told by a repairman that it needs a new D Board. He told us that if we could fix the TV for under $500 that it was worth it, if not (which of course, we can't when you add in labor cost) don't fix it. I like the TV but I can buy a brand new flat screen for that!
Good Luck
Mar 29, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
5 yr sony/ stanby light
THERE ARE NUMEROUS COMPONENTS WHICH MAY CAUSE YOUR PROBLEM. EXPECT $300 - $400 REPAIR BILL
TAKE SET TO SONY AUTHORIZED SERVICER.
30 YR SERVICER
APGONZO
Jan 07, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony Wega stanby light blinks 5 or 6 times
When a Sony TV flashes five times, that means that there is an AKB circuit fault.
Six blinks is also a fault related to video problems, and regards a fault concerning the digital board and the Jungle IC (the main CPU).
This means that there is something wrong with the video.
Try first unplugging power for few hours, if that does not work, call a technician, as several IC and components must be tested and eventually replaced.
Nov 22, 2008 | Sony KP-51WS520 51" Rear Projection...
Stanby light
you might wanna have the tubes checked
Aug 14, 2008 | Sony KP-51WS500 51" Rear Projection...
Red light blinks 10 times then 9 but won't turn on.
Can you confirm that the model number of your set is KP46WT520 as I dont want to give you the wrong information.
Jun 24, 2008 | Sony KP-46WT520 46" Rear Projection...
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
