Question about KitchenAid Architect® KEMS378S Electric Oven
Oven unit not heating up - Kitchenaid KEMX377GWHO
I cleaned my Kitchenaid oven today using the self cleaner. That all worked fine but this evening when I tried to cook dinner, the oven did not get hot; not even a little bit. The fan is running and blowing a lot of cool air. Microwave portion works fine.
This sounds like a blown thermal fuse, a common problem. What model oven was this?
Posted on Jan 14, 2009
My oven will not get hot on bake or broil....what could be the problem?
Posted on Jul 16, 2011
Oven won't heat
You may have a blown thermal fuse in series with the heating elements. If the oven exceeded the maximum allowable temperature during self-clean, the fuse will open. See this discussion:
Oven Failure After Self Clean and F1 Errors
Aug 22, 2014 | KitchenAid Ovens
Used self cleaner on my Kitchenaid oven and now oven doesnt work.... not the household fuse any suggestions
Is it a fan forced oven? Does the fan and the light come on when you turn it on but no heat?
Feb 06, 2011 | KitchenAid Ovens
I cleaned my self-cleaning oven yesterday and today it won't heat up. Can you help me out?
hello,
Here are solution on how to clean up your oven below.
Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work;it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • Thank for visiting.
    Oct 09, 2010 | Whirlpool Ovens
    After using self cleaning feature...oven door locks up...4th time this has happened...kitchenaid says "no known issues with your unit or the problem you reported...can you halp
    Hello - we have had this same issue a number of times as well. Do you lose all power on the unit too? We do - have discovered that using the self-cleaning isn't really a good idea with these ovens. The ovens aren't really made to heat to such high heats that are used in the cleaning cycle and during that last hour of cleaning it hits it highest peak - and it blows it's fuses. We recently blew 2 fuses at the same time, locking both doors (Double oven) and knocking out the power for the entire unit. Our repair man said that the average on wall ovens is anywhere between 6 - 12 cleanings before you will blow the same fuses and the whole cycle starts all over again. Our expense was $350. So, self-cleaning now means elbow grease around this house. How this information was a bit helpful for you.
    Jul 02, 2010 | KitchenAid KEBC208 Electric Double Oven
    Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
    We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
    Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
    My KitchenAid Supra self cleaning convection wall oven stopped heating after I had used the self cleaning program. I ordered a new heat sensory unit $80.00 but after I installed it the oven is still not...
    There is a overload thermostat on the rear of the oven that will have to be replaced.
    Self cleaning features are not recommended by most appliance technicians.
    Self cleaning causes parts to fail often.
    Feb 27, 2009 | KitchenAid KEBC107 Electric Single Oven
    Kitchenaid superba electric oven kebc107kss05
    Did this with me twice now on self clean. It's the thermostat on the back of the oven. Set to trip when oven gets too hot which happens with self clean. Part is about $45 - $50 and pretty simple to install. Hardest part is pulling the oven out of the wall.
    Nov 11, 2008 | Ovens
    OVEN will not heat
    KitchenAid KEBC107KSS does not heat hot enough and does not heat evenly. When the temperature is dialed higher, it burns the cookies. When the convection fan is on, it has a 'cooling effect' so the temperature never reaches the proper level. Is this problem repairable? Or is this a thermostat issue? Thank you for your help!
    Feb 24, 2008 | KitchenAid KEBC107 Electric Single Oven
    KitchenAid Architect® KEMS378S Electric Oven Logo
    480 people viewed this question
    Top KitchenAid Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
