Question about HP LaserJet 4350 Printer
Blank print out
HP LaserJet 4350 Printer displays 51.10 error message. Its symptons are as follows; When i sellect printer self test, it begins to send data and seconds later the attention led begins to blink whilst paper goes to the output bin and comes out blank. Engine test fails also. What could be the problem.
    Scholar:
  • 27 Answers
This is laser scanner error message. The document is not being read from the data being sent. This could be a loose or damaged cable or bad scanner assembly. You can open it up and look for loose cables or connections to the board but otherwise if the scanner assembly is bad, it may require replacement. This should only be accomplished by a service professional as it is not a user serviceable problem.
Posted on Jan 29, 2007
Hp laserjet p2055dn blank display
Similiar Blank Display solution from HP web site:
HP LaserJet P3005 Printer Series - Blank Display
ISSUE: Printer has a blank display.
SOLUTION:
Check if the printer is connected directly into a wall outlet. If not directly connected, power off the printer and connect directly to wall outlet.
Disconnect any local or network connection from any device and keep the printer connected with the power cord cable.
Power cycle the printer. If the issue persists, continue with step 4. If the printer powers up to READY, perform the following steps:
Print a configuration page and check the firmware version. If the printer does not have the latest firmware version, upgrade the printers firmware. Click here to see the latest firmware available for your printer at www.hp.com/go/support . Select Download driver and software (and firmware) and type in the product name or select the product from the product category list.
When the firmware upgrade is completed, power cycle the printer and print a configuration page again and check firmware date code, (it should change to the latest version) then power cycle the printer again.
If the printer powers up to READY, plug the local or network cable back in and print a Windows test page by printing from any application.
If the issue persists, continue with step 4 below.
Remove any additional memory DIMM installed (usually the LaserJet P3005N, DN and X come with a 32 MB memory DIMM installed), and any Internal EIO card or internal hard disk installed and then power cycle. If the issue persists, continue with the next step.
Perform a cold reset:
Turn the device off.
Turn the device on. When the memory count begins, press and hold the check button. Continue holding down the check button until all three device control-panel lights flash once and then remain on. This might take up to 10 seconds
After the message SELECT LANGUAGE appears on the display, press the arrow up or arrow down buttons until COLD RESET is highlighted.
Press the check button. The device performs a cold reset and then continues its power-on sequence.
If the issue persists, continue with the remaining steps.
If the printer powers up to READY, test the printer functionality by printing internal pages. Plug the local or network connection in and test the printer from the workstation.
If the issue persists without any internal device installed, the printer will require service.
Contact HP support.
Click here for information on contacting HP support at welcome.hp.com/country/us/en/wwcontact_us.html.
HP LaserJet P3005 Printer Series Blank Display
Apr 09, 2016 | HP Office Equipment & Supplies
8550 cold reset
Performing a cold reset 1 Print a configuration page to record the previous printer settings. 2 Turn the printer off. 3 Hold down GO while turning the printer on. Release GO after COLD RESET appears on the printer control panel display. COLD RESET (in English) appears on the display for one second to verify that the key sequence has been recognized, followed by the power-on self-test message. Once the power-on self-test is finished, the message RESTORING FACTORY SETTINGS displays in English.
Sep 22, 2011 | HP Color LaserJet 8550dn Printer
Hp 4350 printer memery error
Hi guyfr,
This means that the printer is unable to read the electronic information (e-label) on the print cartridge so that the printer can keep track of the page count for the print cartridge.To resolve the issue:
  1. Open the top cover and remove the print cartridge. Then, reinstall it.
  2. This is typically an e-label issue. The printer will continue to print after pressing the green SELECT button. The consumable management features will be lost (such as the gas gauge, cartridge page count, estimated pages remaining, etcetera) and the control panel may report that the printer has a non-HP print cartridge installed; however, the product will continue to print without problem until the toner runs out and the pages begin to fade, then the print cartridge may be replaced as usual.
  3. If this workaround is not acceptable or the error message persists after performing all of the recommended actions, contact an authorized HP Service or Support Provider: http://www.hp.com/go/support
Hope this helps.
Thank you for using FixYa.
Nov 01, 2010 | HP LaserJet 4350 Printer
LaserJet 4350 Printer: 49.2f02 service error on hp 4100 printer...
Turn the printer off for a few minutes and then back on. If that does not fix the problem, try to have the print queue cleared and tray again. Most of the time it's a PDF file that causes this problem. If that does not fix it, it may need a new Jetdirect card.
May 16, 2010 | HP LaserJet 4350 Printer
LaserJet 4350 Printer: HP 4350 printer, 49.2F9D service error...
1st thing to do is upgrade the firmware. Go to hp.com and look for the software and drivers. Drill down to the firmware and read the instructions.
59.40 error code
That's a main motor error, something could be jammed in transport, or a generic toner cart. that is too hard to turn, try powering on with toner removed...
Aug 20, 2009 | HP 4250 Monochrome LaserJet Printer
Printer error messsage
attempt to clear the print spool and set the its settings to print directly to the printer. Do a test print, then enable print spooling again. If the same thing happens, uninstall and reinstall the latest printer driver
Jan 16, 2009 | HP LaserJet 4350 Printer
HP Laser Jet 3200se fax machine
Hi..
The service error refers to an hardware issue with the printer.. U can try the following step,if this didnt resolve the issue only option is servicing.
1. Unplug printer.
2. Press and hold SYMBOLS & ENTER/MENU.
3. Continue to hold down the buttons while you plug back in the printer, through the entire
power-on sequence.
4. When display reads PERMANENT STORAGE INITIALIZE or HP LASERJET 3200
release the buttons.
Jan 09, 2009 | HP LaserJet 3200se Printer
HP 4350 ERROR MESSAGE: 49.2F90
he printing operation has been aborted.
The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications.
Action :
1> Press Cancel Job to clear the print job from the printer memory.
2> Turn the printer off and then on to clear the error message.
3> Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job,.
Mar 15, 2008 | HP LaserJet 4350 Printer
Printer displaying 49.2F80 error message
Network data corrupted or print job corrupted
Jun 07, 2006 | HP LaserJet 4350 Printer
HP LaserJet 4350 Printer Logo
144 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
