Question about HP Color LaserJet 2600n Printer
Stuck on "initilizing"
The printer jamed and I removed the paper. Once I closed the front cover the display reads "Initilizing". It is stuck in this process.
  • neillabelle Dec 02, 2008
    I checked there is no paper jam. All the ink cartridges where replace several days ago and hundreds of prints ago. The paper tray is full. Any ideas?????
  • Alexander Akoi
    Alexander Akoi Oct 29, 2012
    ok thank u. i'm going to open it to check for any piece of paper and get back to you later.
  • 386 Answers
There are 3 things that will prevent it from going "ready"; they are
1. a paper jam (did you retrieve all of the page out of the printer?), all it take is a small piece of paper in the wrong spot and that will do it.
2. No paper in the paper tray.
3. The ink or toner cartridge is not seated properly or just plain missing. A color laserjet has 4 cartridges.
Good Luck!!!
Posted on Dec 02, 2008
  • Richard Lilja
    Richard Lilja Dec 02, 2008
    What error codes appear in the printer's lcd screen? What does the printer driver say when you open the printer on your computer?
    Unplug the printer, wait 10 seconds and turn it back on, does it clear itself?
    More info is needed before I can help further with more details!
    Experience still says a paper jam is still there.
  • John Campagna Nov 17, 2012
    Thank you it was a small piece of paper
Lasterjet m1212 nf MFP printer refused to print, it keeps initializating, how to solve it?
connect the printer directly to the walloutlet....
try with a different walloutlet as well....
then unplug the power chord from the back of the printer as well as other cables if it is connected without turning the printer off...
then press and hold the power Power cycle unit by switching the power switch off, wait for 10 seconds, then power on..
if it does not work then
  1. Turn the printer off.
  2. Press and hold down CANCEL and Start Copy buttons at the same time while powering on printer.
  3. Continue to hold down buttons until the control panel display reads PERMANENT STORAGE INIT.
  4. Release the buttons. Printer will return to Ready automatically
Hope this helps
Oct 29, 2012 | HEWLETT-PACKARD M1212nf All-In-One Laser...
Samsung CLX3170 printer makes loud clanging noise when printing and smudges some lines. Started after a paper jam. Have turned off/on several times
there is a rest of the paper jamed still inside the printer you need to remove all the jamed paper then it will work, to find out where the paper stuck's open the front and rear cover, maby you have to remove the toner cardriges as well.
May 17, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
I have a paper jam and it says to open the front cover, put the front cover just shows the ink cartridges and there is no visible paper jam. how do i find the jam and remove it? It's a canon image...
The paper jam could be in three places.
First:
Open the cover of fixing section, its above bypass, and check for jamed paper
Second:
Open the transfer cover, these cover has handle and it goes by pulling toward you, and check for jamed paper.
Third:
In hight of first paper cassette, on left sideway of copier, beaneath the bypass are small door, open it and check for paper jams. Be sure that you closed them properly because if they arent closed the check printer cover message will arrise.
Hope that helped
Jul 07, 2010 | Canon ImageRunner 1600 Copier
My konica 1112 copier is showing 36 error it does;t work
it will be showing j-36, its the jaming code, open front cover of the copier and then close it. if still the problem persist then "two part" the machine,open front cover, and press the green lever downside and the release it, now remove the paper from the machine where it is stuck and then close the machine and turn it on. code will be removed..........
Jun 17, 2010 | Konica Minolta Office Equipment & Supplies
Printer sayes its jamed but no signs of being jamed
Could be a defective sensor. But before you jump to conslutions, check the following. remove the paper tray and look inside for paper. open all the covers, front and side. If you look in to the side cover you will see a rubber roller running on a silver roller. Turn the rubber roller with your finger and see if there isn't any paper stuck there, While you are at it also check on the top of the opening where the fuser is located for stuck paper ( Fuser is hot so be carefull) Close all the covers properly. If the problem is still there It might be a sensor and will have to be replaced. Let me know if you need any more help.
May 21, 2010 | Ricoh Aficio MP 1600 Black and White...
Hp laserjet p2015 printer showing jam & toner light on
This problem is not initilize the printer. so i change the formater board, now its workinfg fine
Sep 29, 2009 | HP LaserJet P2015 Printer
Got a paer jam and don't know how to open cover,
Turn of the printer, and do not close any of the tray or doors before all of the jams are cleared.
1). remove the paper from paper tray, removed the tray and remove the jams.
2).open the front cover and removed the toner cartidge assembly, remove any jams in this area, and behid the toner cartridge asembly.
3).left the flap at the front of the printer adn remove any jams heneath the lap.
4).Open the rear exit and remove any james.
close all covers and reinsert the paper tray and turn on the printer.
May 13, 2009 | Dell 1700 Laser Printer
PAPER JEM WHILE PRINTING. I NEED A HEIP TO REPAIR THE PRINTER.
first, if thare any paper is jamed in the paper tray, pull the paper stright out. take out the remaining paper. close the paper tray.
opne the front cover pull out the toner cartirdge, remove the jamed paper.
open the inner door (where the paper exit). make sure there is not paper jamed it.
close the front door. if any paper jamed inside of the machine, it should automatically eject it out.
Note: reset the printer by opening and closing the front door.
Apr 03, 2009 | Samsung ML-2510 Laser Printer
HP Color LaserJet 2600n Printer Logo
105 people viewed this question
Seeker5211
Seeker5211
