Question about Apple Cinema HD 23" LCD Monitor
Apple Studio Display Flashing Power Button
When I switched my mac on yesterday I noticed the image on the screen was flickering, this lasted about 5 mins then the top of the screen went dull, but stayed bright at the bottom (I can see an image over the entire screen). The power button on the monitor is constantly flashing too - any ideas?
  • Anonymous Mar 23, 2014
    when flash occurs there is a message I see in yellow flashing before my eyes what is a compiler on computer or programming tool?
For the brave of heart, You can disassemble the monitor. After you get in to the inside of it, you'll see a circuit panel with 6 ballast coils on it. On my Cinema display, what happened was that the solder joints on some of those coils had cracked, causing intermittent connection. After hitting all the connections with a soldering iron to heal the cold solder joints and re-assembling it, it is working perfectly fine now.
Posted on Jan 06, 2008
  • 624 Answers
Hi Lusciousleri, Some Apple LCD panels can report problems then encounter. I'm betting if you watch you'll see a pattern of a short flash, followed by another short flash followed by a long and then repeating. That indicates a backlight error, which typically means a trip to the authorized Apple repair shop. Let us know if you have any other questions and please don't forget to rate the posting.
Posted on Jan 30, 2007
What would make a MacBook display flash off and on?
If this is the 15-inch MacBook Pro with Retina, it is a known problem that Apple has been less than cooperative in fixing:
How to Fix Flickering Display on MacBook Pro Retina
Mar 14, 2012 | Apple MC968LLA 11 MacBook Air Notebook Mac...
The screen on my Apple MaxBook Pro with 17" display started flashing repeatedly and then went blank. I took out the battery and unpluged it. When I pressed the power button, nothing. I did...
Have you tried starting from the system disks that came with the computer? Put the disk into the computer and start up holding the C key down.
Nov 26, 2010 | Apple MacBook Pro with 17" Display
Computer froze and will not restart
You need to reset the firmware.
Remove the battery, and boot up but holing the power button down until you hear a loud Beeeeeeeeep, and the lights start flashing. Let go, and wait.
Regards.
Jul 21, 2010 | Apple MacBook Pro Notebook
The computer is completely dead, on battery and mains power cord also?  No lights, no screen resolution (not a flicker) and no HD noise at all - completely dead, but the battery (5 flashing LED's on...
well..it should on power along..seems that perhaps the motherboard is unhappy..here's something to try..remove battery..flip over the computer, open the panel with memory..ground your hands on metal..then remove and re seat memory sticks(be careful to NOT touch the gold fingers). close it back up..plug in wall ONLY, try it again.
Nov 28, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Pinstripe cinema display flickers on momentarily then goes black. Image comes back for a split second while when power light glows steadily then goes away while power light flickers. this is a 22"...
when the screen is black and the power light is steadly lit, shine a flash light at the screen. if you can see something, the inverter board is bad and the back light cannot turn on. if the power light flickers, reseat the power plug and put your ear to the back of the monitor where the power plug is. if you hear a buzzing or any high pitched noises; the power supply is bad. use the macufactures warranty for repairs.
Nov 18, 2009 | Computers & Internet
I am using an Apple 30inch Cinema Display with a MacPro Desktop. Occasionally, Lines would appear on the screen and I would have to restart my computer, but not the screen, upon start-up, has a number of...
This sounds like a video card issue with the Mac Pro, have you tried testing the display with a different computer?
Next, check for any software/firmware updates from Apple and install if necessary.
Next, I suggest resetting the SMC to flush out any legacy niggles, this can be accomplished by following these instructions as provided by Apple.
To reset the SMC on a Mac Pro:
  1. From the Apple menu, choose Shut Down (or if the computer is not responding, hold the power button until it turns off).
  2. Unplug all cables from the computer, including the power cord and any display cables.
  3. Wait at least fifteen seconds.
  4. Plug the power cord back in, making sure the power button is not being pressed at the time. Then reconnect your keyboard and mouse to the computer.
  5. Press the power button to start up your computer.
Another way to reset the SMC on a Mac Pro computer is:
  2. Open and remove the metallic outer door.
  3. Press the SMC_RST switch that is located slightly below and to the right of the row of diagnostic LEDs. Use a non-metallic, non-conductive object, such as a wooden pencil. Note: Mac Pro (Early 2008) does not have an SMC_RST switch, refer to the reset procedure steps in the previous section.
  4. Replace the metallic outer door.
If the problem persists and you have identified that the problem is definitely with the display then any further information you can provide would be most helpful in diagnosing the problem - otherwise, if it is the video card then (assuming it's still warrantied) get in touch with Apple. If out of warranty then I'm sure we can guide you through the replacement process if needed!
Oct 28, 2009 | Apple Computers & Internet
Apple G4 MDD, dual processor. Won't power up
check apples web site. I believe there is a topic on this issue.
Jun 03, 2009 | Apple Power Mac G4 Dual Mac Desktop
Mac Mini G4 Flickering Screen at Start Up
Did you check the wires?  Sometimes if you pull one loose it flickers.
Aug 13, 2008 | Apple Mac mini G4 Desktop
Hp Laptop screen flicker
Hi, i noticed that when I unplugged my HP the screen stopped flickering. I then re-plugged in the power, when to the Nvidia control settings, to PowerMizer, and changed 'ac outlet' to Maximum Power Saving.
Not the world's greatest solution, but hey, working laptop now.
Cheers,
Andy.
Nov 21, 2007 | HP Pavilion zd8000 Notebook
Apple Cinema HD 23" LCD Monitor Logo
929 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Peter Dragonetti
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
