Question about Sunbeam 5833 ExpressBake Bread Maker
Paddle spindle has come loose from breadpan
Wobbles and won't stay fixed in place
  • Anonymous May 08, 2009
    i have the same problem. service told me i need to buy a new pan
  • 69 Answers
Hi pasternak194
It looks athough the small circlip (shaped like a horseshoe) may have come of the end of the spindle.
This holds the spindle on the end of the driving pin.
(I may be wrong)
You need to contact the manufacturers or have a word with someone who can supply these things.
Kind regards
Alleluia
Posted on Dec 02, 2008
Bread pan comes loose and bangs around during kneading cycle--how to fix?
Hello....I wrote this for those with bread pan problems....be sure to read the part about how to restore the "spring" of your bread pan clips...
Bread pan removal:
I am assuming you have the type of bread machine that has the little metal spring clips inside the oven compartment. Before inserting the pan always check on the bottom of the pan (underneath) to see how the impeller "T" is aligned and turn it with your fingers or turne the paddle with your fingers so the "T" will fit into the gaps of the impeller in the bottom of the oven. Once you have aligned them then place the pan in the oven and "pop" push the pan in place so the spring clips grab the matching clips on the sides of the pan. Also look to see if your pan has the word "front" stenciled in the lip edge of the pan. If so, be sure that edge is towards the front of the machine. If your pan still won't pop into place when you push down your spring clips may need to be gently pulled out because they can become "slack" over time. Take the pan out and reach in and pull each spring clip up until you start to feel it bend a little and bend them out. Pop your pan into place and if the clips don's start to grab your pan repeat the process of bending the clips out and repeat that until they do. Summary:
1) make sure if your pan is marked "front" that it is aligned properly
2) make sure the paddle and the T underneath the pan aren't in conflict with the matching drive impeller in the bottom of the oven. Just turn the paddle so they are opposite of each other and can engage
3) Restore the "springiness" to your clips by bending them out with your fingers. Be careful though because the spring edges are fine edges so get underneath them when you pull up
For bread machine parts, good used bread machines etc. visit breadmachineshelp.com
Apr 01, 2013 | Breadman Tr2500bc Ultimate Plus 2-pound...
The paddle for my Breadman BK1060BC has been coming off during kneading. Today, I saw some grey residue in the dough. Is the problem with the paddle, pan or both? Thanks.
I just purchased this 2 days ago and started to use it. I noticed the bread pan would wobble and was noisy during the kneading cycle. On the second use the paddle came off during the kneading cycle. Being a service technician all my life, I started to analyze the problem. I was previously surprised how loose the bread pan fitted into the bread maker and suspected there should be something to support the pan and hold it in place. I could not see anything obvious, but after looking carefully I noticed spring clips on the bottom of the bread pan, and also mating spring clips in the bottom of the bread maker. If I pushed the bread pan down fairly hard into the bread maker the bread pan would snap firmly in place. This stopped the wobbling during the kneading cycle and the paddle coming off. I could not find anywhere in the manual where it explained the bread pan must be pushed firmly down into place until it snaps in. The manufacturer should explain this to their customers on their website.
Apr 23, 2011 | Breadman TR2500BC Bread Maker
My paddle keeps coming off when the dough is mixing. What's up with that?
Your paddle is probably worn out and has too much play in it. Some play is necessary to get it off for cleaning but it shouldn't be so loose it is coming off during kneading.
Nov 14, 2010 | Breadman TR444 Bread Maker
The mixing blade is stuck in the tin . How do we get it out?
Try soaking it over night or even for a couple of days. Put just enough water in it to cover the paddle completely plus about an inch with a little detergent. Whatever you do don't try to pry it loose with anything metal because you will damage the nonstick coating on the paddle and/or the breadpan!!!..............If it still won't come out log on to you tube and type in "How do you remove a stuck bread machine paddle" ......you will see my video of how to remove a seriously stuck bread paddle with no damage to your pan or paddle.
Oct 10, 2010 | Sanyo SBM-20 Bread Maker
Paddle shaft unable to rotate in the breadpan.
Hi, There is a sealed bearing in the base of the bread pan. When this sealed bearing fails the paddle gets stuck and will not turn. Take the pan out of the machine and see if you can turn the paddle by hand. If it doesn't turn freely, then it's probably the sealed bearing that is is failing. If it turns freely, then this is good news. Keep the pan out of the machine and go to a kneading cycle. Look through the lid window to see if the motor shaft is turning. If it is not turning, then a belt fell off , needs to be tightened, or has broken. Motor, belts and pulleys are in the base of the machine. Remember to unplug machine before working inside the machine. Finally, make sure the pan is seated in the machine correctly. Good luck Hankl
May 11, 2010 | Black & Decker Bread Machine
Bread Maker stir paddle does not spin
Either contact the manufacturer, or remold the interior of the paddle hole yourself. How? Using something like JB WELD. Place a peice of plastic wrap over the metal spindle, spreading it not only around the spindle but 2-3 inches outward like a skirt. Mix the epoxy (I recommend JB Weld) and place a small blob over the spindle. Pack the hole in the paddle with it. Now, place the paddle back over the spindle and let the epoxy set-up overnight.
Because of the plastic, the paddle should lift up off the spindle. Using a carving tool, a hand grinder, or sandpaper and elbow grease, remove the excess hardened epoxy. The interior of the spindle hole should be good-as-new.
OR, find A STORE that sells breadmakers, and find a paddle that will work on yours, and 'borrow it' (a your own risk, shoplifting is a crime).
Feb 03, 2010 | Breadman TR850 Plus Bread Maker
Paddle shaft and seal replacement
Best bearing company I know of is Tri-State Bearing In Evansville IN. They have an unbelievable selection of high quality bearings. But you will have to specify ID, OD, thickness, material preference, sealed vs. unsealed and temperature range. Or you could try RepairClinic.com online and find parts by make, model, etc.
Apr 24, 2017 | Kitchen Appliances - Others
Loose / wobbly platter?
This is a common problem. If you have another 1200 turntable, switch out the platters and see if that fixes the problem. Usually, the problem does not carry over.
There is nothing to screw or tighten. You can install a new SPINDLE - and it should fix it. But might not be necessary if you just swap your platters out.
- OPTiC
DJ PRO LAB
Apr 11, 2008 | Technics SL-1200MK2 Turntable
Sunbeam 5833 ExpressBake Bread Maker Logo
165 people viewed this question
Top Sunbeam Kitchen Appliances - Others Experts
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
