Question about Whirlpool Duet GHW9150P Front Load Washer
I have a front load Duet washer. The washer won't drain. The door is locked. I got the 3 screws out for the lower access panel, but it seems that the door needs to be opened to remove the panel. Is that correct?
    President:
  • Whirlpool Master
  • 2,651 Answers
No not at all after removing those bottom screrws the panle will pull right off, pull from bottom. behind htere yo will see the pump drain cleanout, you can unscrew to clean out , but i warn you that all the water in the machine will exit drom that point, you will get wet, be prepared!
Posted on Dec 02, 2008
Cannot open the door to the Duet washer
Disconnect power and remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, reach up along the inside of the front panel and locate the bottom of the door lock and switch assembly on the right side. Locate the tear-drop shaped tab then gently pull it down until a click is heard, and then open the door.
The door lock and switch assembly may need to be replaced if the problem persists.
Replacing the Door Lock and Switch Assembly
Nov 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet front load washer. Put car mats in to wash. They are too wide and don't let drum spin. Stopped in first few seconds of cycle and error code came up but, door remains locked. How do I open...
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet door locked cannot open it
Jun 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: Whirlpool Duet Washer - Error F21 (What is this) ...
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out. Door locked? Press "end of cycle" for 3 seconds, wait for 2 minutes & try the door. F-21 filter blocked.
How abt a nice rating for the free help? Thnks
May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer door is locked on the Duet Series. Tried all the basics but still nothing.
Dec 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Mt front load duet whirlpool is locked full of water
Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE4T Washer
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Oct 13, 2009 | Kenmore Washing Machines
It won;t power up at all, clothes... Solve It won;t power up at all, clothes are locked inside, no lights on the panel. Plug in is working, I... (More) It won;t power up at all, clothes are locked inside,...
Jul 04, 2009 | Kenmore HE2 Plus Front Load Washer
We have a whirlpool duet washer and the door lock is activated but the door is open. What can we do?
Jan 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Wash cycle has ended and door will not unlock.
welll there are 3 screws across the bottom front of the panel (torx 15) the lower acees panel can be removed, from there you can gain access to the backside of hte lock assy and manually release it. simply run your hand up the right side, just below the lock/latch assy ther is a quarter sized/teardrop shaped pull cord. thos will release the door, for you
Dec 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
32 people viewed this question
Dan Webster
Dan Webster
Sal De
