Question about Maytag Atlantis MAV6000 Top Load Washer
My washer will not work in the spin and rinse cycle.
My washer is less than 2 years old so the warranty is up, but the spin and rinse cycle has stopped working. All other cycles work properly and the spin and rinse makes noise, but doesn't perform. I checked the belt and it is fine, the drain hose is not clogged as I can drain it by removing the hose from the wall and setting it in a bucket. The lid switch seems fine because it stops other cycles and restarts properly when opened. I'm afraid my pump has went out but I'm hoping it's a simpler problem I can fix myself.
  • 2 more comments
  • ashbob_smith Dec 02, 2008
    that sounds great! With the holidays, the last thing I want to be paying for his a technician. I'm ok handy when someone can walk me through a process though. and I know I have that socket!
  • johnny ray 6 Dec 05, 2008
    I have identical problem. Couldn't find solution. I have a 5/16 nut driver. Please Help
  • bstocks19 Dec 11, 2008
    My washer sounds like it is going through tnhe spin cycle, but the cage and agitator are not moving a bit...please help I just bought them used. Silly me I guess.
  • Anonymous Dec 17, 2008
    Motor comes on, tub will not spin
  • 868 Answers
Whats happened is that the clutch/brake assembly is stuck.Without a qualified service tech. you can really get taken if the repairman doesn't know the trick to this.I can walk you through this step by step and you need only a 5/16 nut driver or socket.
Posted on Dec 02, 2008
My washing machine will only turn on, on the rinse and spin cycle settings, no wash. It is less than a year old and the mod # is HTWP1200DOWW
most washers under one year are under warrantee call a repair shop and ask if they do warrantee work and if there will be any charge to you after you find a shop you trust let them fix it.
Sep 14, 2014 | Hotpoint HTWP1200DWW 27" Top Load 3.5 Cu....
Wash doesn't progress to rinse and spin
This is one of 3 faults
1 you may have a problem with the heating cycle check element
2 you might have a water valve not working
3 there may be a program fault
These videos on how to change an element and water valve will help
Jul 22, 2013 | Bosch Classixx WFL 2066 Front Load Washer
My Kenmore he front load washer stopped at the rinse and spin cycle. I don't know the model but it only a few years old. It made a load noise before stopping. I attempted to get it going again wit
Kenmore front loader. stopped at rinse. First ck to see if you washer works at different settings if so its very possible its your timmer or what called the wig wag or solonoid this switches the machine to spin & rinse. A basic service call should resolve your problem.
Jan 30, 2012 | Washing Machines
GE front load washer will not complete the rinse & spin cycle
1) 1st check the filter under the machine (it unscrews behind the access panel 2) open front door and pull back the rubber membrane to see metal and clean out the debris blocking drain holes 3) remove the drain hose from the machine (spring clip) and try and run water thru it and keep blowing out the junk and re-attach 4) run the machine thru 2 cleaning cycles w/bleach and without bleach 5) start using less detergent
Apr 09, 2010 | GE WSXH208A Front Load Washer
Agitator on maytag sav2555aww won't spin, loud clicking noise
I just replaced the trans in my maytag.if the washer is less than 5 years old trans is covered under warranty. but here is the kicker, labor and thrush bearing is not. trans cost is about 300.00 and labor is about the same. a new washer is about 450.00 So if you know someone who can do trans.[like for free] if not buy a new one. Good Luck
May 21, 2009 | Maytag SAV2655A Top Load Washer
Whirlpool ingis washer will not engage rinse cycle
make shure the cold water is on and also if it worked before then it cold be two parts 1 the timer is bad or 2 the water inlet valve
Jan 17, 2009 | Whirlpool Inglis IP4400 Washer
Issue with switching to rinse cycle automatically.
Dear G.Arnold,
ngfam at you service
If you are under warranty it's FREE
Sounds like you need service! no cost to you!!!!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Jun 22, 2008 | Frigidaire ATF6000ES Front Load Washer
Whirlpool LHW0050PQ Front Load Washer
Basically,the machine you have is garbage! - I have one also, It is less than one year old and the repair folks have been out 5 times. It doesn't spin either!
I'd call this one a lemon!
Apr 14, 2008 | Whirlpool LHW0050PQ Front Load Washer
3 audible beeps every 20-25 seconds
Try unplugging the washer for about 20 minutes then plug back in and use. I have found that this actually works! The only thing I can figure out is that it takes time for the electronic control to clear. If that doesn't fix the problem I would call sears tech since it is less than a year old. They have a 1-2 year warranty.
Dec 21, 2007 | Kenmore Oasis HE 27062 Top Load Washer
Loud noise when spinning
the only part that makes a loud noise is your bearings m8 other than that could be a bra wire stuck inbetween your drum and casing m8
Aug 11, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
150 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
