Question about Whirlpool GU2455XTS Built-in Dishwasher
Fill valve vibrates loudly
When activated the fill valve (solenoid) vibrates loudly. Would the problem be the solenoid itself of could it be defective Triac in the electronic control?
    President:
  • Whirlpool Master
  • 2,651 Answers
I would look to the valve solenoid as the issue, if not the pressure from the incoming water supply( try decreasing under sink perhaps to high)
Posted on Dec 02, 2008
How do i fix e5 on the dishwasher
Three common causes.
  1. Defective solenoid water inlet valve
  2. Plugged water inlet filter
  3. Defective stop valve located where the inlet hose connects to the water line.
Problem 1 usually no water will enter. It usually works or not.
Problem 2 and 3 the situation is the tub begins not to fill and over time the filter closes completely or the stop valve plugs completely.
If you open the door after the fill cycle and you have not heard the unit fill it is most likely the fill solenoid. Partially filled need to look at the stop valve. The rubber washer of the valve deteriorates and loosens relocating over the hole plugging the water from going through. When you try to shut off the valve it in most cases will not close water tight. You can replace the stem and washer if you can find the same hardware type.
The solenoid replacement can usually be axcessed from the front but requires a skilled technican.
26051739-3tozjaopshvuyndb2zxhmboi-4-0.jpg Solenoid valve below
26051739-3tozjaopshvuyndb2zxhmboi-4-2.jpg Hope this helps?
Jan 13, 2016 | Dishwashers
Magic chef model rc203pd no water getting to ice and water outlet
yes.
please check the power supply to your water control valve.
check from the place where it receives power.
Jul 05, 2008 | Refrigerators
GE Side by Side Refrigerator model GSS25jfpa cc. No water to icemaker. Replaced the ice maker and the dual solenoid water valves. Still no water to ice maker? Water to door works fine.
if you can reverse the solenoid valve wire connections,then use the door water fill to activate this valve,but not long as it will overfill the icemaker,this will certify that theres water getting up to the icemaker,then it could be the maker itself not activating the icemakers water valve assy to fill the maker
Feb 01, 2013 | GE Refrigerators
Why doesnt my washer put out cold water
either the hose screen inside the fill hose is plugged with lime/rust/etc. or the water solenoid is defective or not getting power from the controls,on some fill valves there is a thermistor that senses water temps as it fills and this part could also be defective,you can test this valve with a cheater cord to see if it opens,or unplug the machine and use an ohmmeter to test the solenoids coil for continuity,if good plug it in and check for voltage(normally 120 volts A.C.)on the solenoids terminals during the fill cycle
Nov 19, 2012 | Amana Washing Machines
Loud humming when the water enters the dishwasher. The copper pipe vibrates. The dishwasher is approximately 11 years old. Problem slowly getting worse over time. I tried to tie down the copper pipe in the...
the fill valve solenoid has gone bad.u need to chg the fill valve assly.it is very easy to chge ad it is mounted on lhs bottom corner of the unit behind the toe panel.
Aug 17, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
The water will not fill washer. It spurts a little then stops. Water is on. No kink in hose.
HI, this is a defective water valve assembly. you must replace this assembly asap, if possible. this will fix you issue.
The inlet valve connects the hot and cold water from your home to the back of the washer. The valve solenoids on the valve open one or both valves to provide the proper water temperature for the wash cycle. If the valves are blocked or the solenoids do not activate, the symptoms may include no water, low water pressure, the wrong water temperature or water entering the tub even when the machine is off.
Jul 23, 2009 | Washing Machines
Ice maker not makeing ice anymore
check the output power supply
Jul 07, 2009 | Refrigerators
Aprilaire 760 furnace humidifier makes a loud screeching sound.
A bad circuit board should not make any noises. A bad solenoid valve could make a loud buzzing noise. If the noise is a squealing noise then you have defective bearings in the blower motor.
If you disconnect the low voltage wiring from the solenoid valve and you still hear the noise, then its not the solenoid valve.
Apr 06, 2009 | Aprilaire 700 Humidifier
Kenmore 90 Series Washer Noise--Won't spin
For Tegres
If the noise is only when there is water flowing, check tighten the screws that mount the water fill solenoid valves to the case. The solenoids operate on line current so they vibrate at 60/50Hz (local suppply frequency) if they are loose at all, the noise is loud the body acts as resonators
For SRONEAL, that symptom describes coupling failure exactly, have you removed the coupling to check, often times the motor side hub is stripped, but there is no visible external damage
Jul 23, 2008 | Kenmore 15864/15862 Top Load Washer
Whirlpool top loader
You either have a defective pressure switch or water inlet valve. Start to fill the machine with warm water so that both solenoids on the water inlet valve (hot and cold) are activated. After about 30-60 seconds, push the timer knob in to stop water flow. If the water continues to flow, replace the water inlet valve. If this is the case, it may take a few times of starting and stopping water flow to allow solenoid to heat up and become symptomatic. If water flow stops abruptly each time knob is pushed in, you most likely have a defective pressure switch (water level switch).
May 09, 2008 | Whirlpool LXR9445JT Top Load Washer
Whirlpool GU2455XTS Built-in Dishwasher Logo
245 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
