Question about Motorola Mobility W510 Mobile Phone
Picture capture failed and system error when using camera
My memory card is installed but it is not listed as storage device on my phone also I can't use my camera it has error message of picture capture failure and video camera has system error when attempting to use it. Is there some kind of application that has been removed?
    Brigadier General:
  • 7,752 Answers
The mainboard need to be tested and diagnosed to determine what the problem is and to fix it.
Posted on Dec 27, 2008
I want to keep some pictures on my camera and delete some
While viewing the image, press the trashcan button. The camera will ask for confirmation of the delete.
I would recommend against making a habit of keeping some pictures on the camera or memory card and deleting others. You're guaranteed to fragment the memory, leading to camera speed loss and eventual memory corruption. The camera is an image capturing device, not an image storage device. If you need to keep some pictures on the camera, copy them to a computer, format the memory card, and then copy them back using a card reader.
Mar 18, 2012 | Canon PowerShot SD1100 IS Digital Camera
Delete select pictures from camera
I am trying to download pictures from my Nikon S8000 by either plugging the camera to my PC via USB or plugging the SD card into my PC, and I cannot! I can view the pictures in the camera, so I know they...
Must install the camera's driver on to your computer before plugging the usb cord into the PC.
I would as a rule install the camera's software from Nikon.com's support site if it did not install automatically.
http://www.nikonusa.com/Find-Your-Nikon/Product/Digital-Camera/26191/COOLPIX-S8000.html
It can sometimes be difficult to setup a digital camera on a new computer. Usually the process is simple: plug the camera in, allow the system to install the driver and begin using the system, however, sometimes things can go wrong. Following these steps can solve more than 90% of problems relating to USB connection issues. You must be thorough and follow it step-by-step.
  1. What CF Card is installed in the camera?
    A large number of problems are caused by incompatible CF Cards. In many cases these cards will work while shooting but can fail to properly download to the computer. You must be extra careful that the card is approved. Actually look up the card you are using in the manual to see if it on the list. Many retailers include "Unapproved" cards in their bundles, so just because a card came with the camera doesn't mean that it is "Approved".
    If in doubt, use the "Nikon Starter Card" for testing.
  2. Is the Camera in Mass Storage Mode?
    While PTP mode can be used if your camera and operating system (Mac OS X and Windows XP) supports it, for troubleshooting it may be useful to switch to MSC USB mode using the camera's setup menus.
  3. Are there images on the card that can be viewed on the camera in playback mode?
    Nikon View will not auto launch or give a transfer window with no images on the flash card. If you have covered the first three items you should now connect the camera to the rear USB port (not through a hub or front port) on the computer. On all Windows systems excluding Windows 98 Second Edition (SE) ("Plain" Windows 98 is not supported.) make sure the Nikon View CDROM has been removed from the system prior to connecting the camera.
  4. Does the LCD Display Screen go dark after being connected for 2 seconds?
    If you are not getting the "Found New Hardware" wizard then check the LCD display. If the display stays "on" and the camera seems to be in Shooting mode or Playback mode then you may have a bad cable, camera USB port or computer USB port. If this is the case, contact Nikon Support for more information or Click Here for more troubleshooting.
  5. Does "New Hardware Wizard" Start?
    If you connect the Camera and a "Found New Hardware" wizard comes up you should allow the system to auto search for the driver by simply clicking the "Next" button until it is finished. (Windows 98SE requires the Nikon View CD-ROM to be in the CD-drive at this point.) On Windows systems newer than Windows 98SE the camera should pick up and use the Microsoft Mass Storage driver.
  6. "Hardware Handshaking"
    You need to understand how hardware handshaking works. The hardware Handshake occurs when a USB device is connected to the USB port. The computer detects the USB device on the USB bus and asks: "What are you?" The Coolpix line of cameras should answer: "I am a Nikon Coolpix 5700 currently set to Mass storage mode."
    If the computer does not understand this message the most likely cause is an incompatibility with the USB chipset on the particular USB controller that the USB port is connected to. You can check your controller chipset on the Microsoft Hardware Compatibility list. First find your "USB Controller" (i.e. Intel 82801AA USB Host Controller) in your computer's "Device Manager" and then look it up on the above link. You can tell if the handshake failed if the camera is listed in Device Manager under “Unknown Devices” or “Other Devices”.
  7. Drivers
    The Mass Storage Driver set consists of two drivers. The first driver is the “Mass Storage Driver” ("Nikon Mass Storage" driver on Windows 98SE systems) and the second is the driver for the CF card in the camera. The CF Card driver should be listed under “Disk Drives” in Device Manager. Be sure both drivers are installed and showing up cleanly in Device Manager.
  8. Auto Launch
    If both drivers are installed "cleanly" in Device Manager (no question mark or exclamation point) then you do not have a camera or driver issue. If Nikon View does not “Auto Launch” or the Nikon View “Transfer Window” comes up but fails to transfer images then the you can usually resolve these problems with the following steps. Nikon View is not required to transfer images from Nikon Coolpix camera’s capable of running in Mass Storage Mode.
  9. If the drivers are clean but you are unable to transfer images
    Double click on “My Computer" and verify that a “Removable Disk” icon with a drive letter is listed. If the "Removable Disk" is not listed then there may be Network Drives mapped with drive letters that follow the last actual local drive listed. If this is the case Click Hereto learn how to change the drive letters to accommodate the Removable disk
  10. If the Removable disk does mount
    There are two simple ways of transferring images:
    a) You can click through the directories on the removable disk: i.e. "g:\DCIM\100Nikon" and copy the entire contents of this directory then paste into a local drive location such as "c:\My Documents\My Pictures."
    b) The second option would be to launch Nikon View and select the removable disk from the folder list on the left. With the removable disk expanded down to the "100Nikon" directory you can "select all" and drag the images to a local drive location listed on the left.
  11. Transfer starts but fails to transfer all pictures.
    If Nikon Transfer starts but fails at any point during the transfer then there may be some bad picture files or corrupted data on the flash card. This will sometimes occur if the card has been used in a card reader to move non-picture files between various computers.
    Note at which file number the transfer is failing and go through the mounted removable disk to delete that picture file. You can also copy all the picture files except the damaged files from the card. Always format the flash card in the camera after you have recovered the undamaged picture files to the computer.
Jul 29, 2010 | Nikon COOLPIX L18 Digital Camera
W910i can not save the pictures. I was working fine before
Hi, first for the pictures captured to be saved, might be that your phone memory if full and no other place for it to save the pictures.if you have an external memory card, change the storage device to save to memory card in your camera settings.
And secondly, if you want the call logged call registry to display, you will have to copy the numbers into the phone memory before the call logg can display callers identity.
Hope it helps.
Take care.
Jun 01, 2010 | Sony Ericsson W910i Cellular Phone
I just got a memory card I can't get it to work.
She/He as a i presume have the V3xx.
(this is about the same for all Razrs that take memory cards/Trans flash)
-Menu
-Settings/tools
-System
-Device Info
then to
-Storage Devices
and if it shows up than obviouslt your cards working and the phone knows its there.
if not, a lil trick i found.
Put the transflash card (your lil memory card) into the SD adapter and put it into a camera and take a picture. check and see if the picture is saved on the card. If it is than pop it in your phone and see if you can find that picture. if you dont see it on your camera, its the card.
also if it is listed in your Storage devices.
but for some reason when you take a picture it doesnt save to the memory card?
go into your camera settings and change your storage device to the memory card.
at default it sets your phone as the primary storage, not you memory card.
I hope this helped.
Feb 17, 2009 | Motorola Mobility RAZR V3xx Cellular Phone
SD 215mb memory card reads ''memory card error''
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Nov 12, 2008 | Vivitar ViviCam 5385 Digital Camera
Samsung i900 - insufficient memory when trying to take photo.
The phone has 3 memory's
My device about 90MB which is where everything gets stored by default and because it's the smaller memory it will easily get full.
My storage about 8 GB (handset internal memory)
Storage card about 8GB depending on your contract (Memory card)
You will need to move items from the "My devices" memory to either the "My storage" or " Storage card"
Start
Programs
File explorer
My device
My documents
Tap and hold on a file
Select cut
Go to my storage or storage card which ever desired memory
Tap and hold paste.
Try change default storage for pictures and video.... So that they no longer saved under My devices memory.
Open camera as you about to take a picture tap on the tool icon
tap on the tool
change default storage to my storage or storage card
Also change default storage for files transferred via bluetooth...
Start
Settings
Connections
Bluetooth
Tap on FTP tab
tap on the bar with 3 dots
select desired default storage
Works like a charm!
Oct 06, 2008 | Cell Phones
Camera Error in 2mth old Imate Jamin
This happens also because the RAM memory is full by programs opened before. For example, whenever you turn of any program or aplication like contacts or messages, it doesnt turn off at all by clicking the X, it remains opened and you have to go to Star, Set up, then click on Memory, then on running programs, and stop them. This way ram will be able to use the camera and store pics on storage card. Do this also when you see that camera looks like unfocused, its always the ram memory.
Feb 09, 2007 | i-mate JAMin Smartphone
"Read only card, change to internal memory to capture"
This error message indicates that the memory card in the camera is write-protected. To take a picture, turn off the camera and insert a new card, or change the storage location to internal memory.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Motorola Mobility W510  Mobile Phone Logo
116 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
