Question about Breville Die Cast 800ESXL Espresso Machine
Temp adjust on Breville espresso thermal block machine
You described how to increase the brew temp, but how do you decrease it? I live at high altitude, and the upper temp is above the boiling point, and I would like to decrease it. Saeco sells a 90 C thermostat. Should I try to replace it, or can you suggest some way to trick it into kicking off at a lower temp? I'm not sure the Saeco part would work.  Thanks for your help.
  • 4 Answers
SOURCE: breville ESP8XL Espresso Machine Cafe Roma leaking.. help please..
We had that happen and it was a crack in the black ring that holds the filter. Breville could not supply us with one but we found an OEM part in aluminum from http://www.vancouverwireedm.com/caferomadiyt.htm. We received it 1 week after ordering. It was pretty easy to replace. Our machine works fine now.
Posted on Sep 26, 2008
EsWorld
  • 1618 Answers
SOURCE: frothing valve leaks water when not in use
There are 2 inserts pins in the steamvalve assembly, they need to be replaced replace. Easiest solution order a new valve assembly.
Posted on Feb 27, 2009
EsWorld
  • 1618 Answers
SOURCE: Dispensing Failed- Saeco Talea Ring Plus
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
Posted on Jun 24, 2009
SOURCE: how do I get my breville cafe roma espresso
Same thing happened to me and I had to push down on the water tank a little more firmly. It looked like it was seated okay but I guess it needed to be pushed down more to open the little spring-loaded opening at the bottom.
Posted on Dec 28, 2009
SOURCE: Breville Die Cast 800ESXL Espresso Machine no
I had the same problem. I opened up the back and disconnected the water hose from the spring loaded intake hose and put the hose directly into the tube and into the reservoir tank. Now it seems to **** the water in again. Not sure this is the best solution but it seems to work for now.
If someone has a better solution, I'd be happy to hear about it.
Posted on Jan 02, 2010
A breville you brew bdc600xll coffee maker basket overflowing water and grounds
I have that problem also when I use the wrong filter in my BUNN but when I use only BUNN filters it does not do it . you could try them they seem to be a little deeper .
Oct 09, 2015 | Breville BDC600XL Coffee Maker, You Brew...
Thermal block assembly for Breville part 800ESXL/251
Breville has discontinued supporting the 800ESXL. As part of the all unique part like the Thermal block are no longer available.
Jul 18, 2012 | Breville Coffee Makers & Espresso Machines
Cannot remove stainless steel brew head
Hi Roberto, thanks for your message.
I am quite sure that the brew head removal will be described in the service manual. I found that here:
http://tradebit.com/visit.php/84445/product/-/150234770
Dec 08, 2011 | Breville Die Cast 800ESXL Espresso Machine
How to increase temperature on model BCM120. The coffee is not hot enough after brewing. Is it possible to increase the temperature on the thermostat.
There is no temperature adjustment for the heating element under the carafe.
The Instruction Manual says:
If coffee is too cold, machine not preheated, cups not preheated, milk not heated enough (if making a cappuccino or latté)
Jun 12, 2011 | Breville Coffee Makers & Espresso Machines
I own a Breville 800ESXLespresso machine which i already decalcified, that leaks from brew head and handle moves while brewing
If you've had the machine for a while, your brew head seal (gasket) is probably damaged or shrunken from age/heat and needs to be replaced. That's most likely why the filter holder moves and leaks while brewing. Breville brew head seals are rather difficult to locate, but I personally stock them and sell them at a reasonable cost. I sell lots of new and used parts for various coffee machines, but specialize in Krups. If interested in purchasing a Breville brew head seal, contact me at cowboy_romeo@yahoo.com and I'll make arrangements. I accept Paypal to make the transaction safe and secure for us both.
Nov 27, 2010 | Breville ESP8XL Espresso Machine
Grind size cannot be ajusted
On the side of the machine is a rotary dial, this adjusts the grind size. The other dial adjuster only increases or decreases the volume not the grind size.
Oct 20, 2010 | Breville Fresca BES860 2Cup Coffee Maker
I've A Breville 800 esxl espresso machine.when making an espressothe machine starts leaking from the external slots outside coffee filter holder.what is the cause of it?
Breville brew head seals are rather difficult to locate, but I personally stock them for ESP8XL & 800ESXL machines and sell them at a reasonable cost. I sell lots of new and used parts for various coffee machines, but specialize in Krups and some Breville. If interested in purchasing a Breville brew head seal, contact me at cowboy_romeo@yahoo.com and I'll make arrangements. I accept Paypal to make the transaction safe and secure for us both.
May 21, 2010 | Breville Die Cast 800ESXL Espresso Machine
Heater doesn't work.
Hi. Sound like a problem with your Control Board or thermal block. You will need to speak to Breville
  • AskUs@BrevilleUSA.com
  • 1.866.BREVILLE (1.866.273.8455)
  • May 21, 2010 | Breville ESP8XL Espresso Machine
    Temperature adjustment?
    the rear temp sensor is in charge of the brew temp. To increase the temp, lift sensor and clean out the thermal paste. To further increase, insert some fine metal mesh between sensor and boiler. The front senser is for emergency (overheat) cut off. Don't tamper! Brought to you by Jim Vonkas
    Mar 16, 2008 | Breville Die Cast 800ESXL Espresso Machine
    Breville ESP8XL Espresso Machine Cafe Roma leaking.. help please..
    Mar 06, 2008 | Breville ESP8XL Espresso Machine
    Breville Die Cast 800ESXL Espresso Machine Logo
    85 people viewed this question
    Top Breville Coffee Makers & Espresso Machines Experts
    Henry  Thomas
    Henry Thomas
    Colin Stickland
    Colin Stickland
    Steve
    Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
