Question about Kenmore 22812 Bagged Canister Vacuum
Need to know if a replacement part can be purchased and where
The plastic piece in which the power heads pipe/hose is connected to the top of the powerhead has split into on my Kenmore Progressive canister vacuum. Therefore the powerheads pipe/hose keeps coming unattached from the head. Is there a way to replace this part? This is for a Kenmore Progressive Canister vacuum model 116.22813204.
If a part is available where and how do I go about getting one.
  • pdfs Dec 04, 2008
    I am having same problem, and found parts lists and schematics here:
    My model is 22912, but the powermate unit the hose plugs into has a 5 instead of a 2 at the beginning (look on bottom).
  • 3 Answers
Posted on Mar 05, 2009
  • 55 Answers
Kenmore canisters are privately labeled Panasonic canisters and sometimes panasonic parts will fit them. Any reputable independent dealer should be able to tell you if the part you're looking for is intercharngable with a Panasonic, but he/she will probably need to actually see the unit.
Your other option is to take it to the Sears service dept. They are the only ones who have access to the schematics and "Kenmore" parts. It'll probably be more expensive through them though.
Posted on Dec 02, 2008
Hi my dyson dc18 has great suction from wand but when you got to use the vac for floors little suction but wand still got suction even while vacuming floors is it suposed to stop suction from wand
My Dyson dc18 had the same symptoms. The wand worked well and the floor bar had no suction. After removing pieces & shoving my fingers into the machine (no blockage) I found the suction pipe rotates between two positions (floor and wand). It looks like a piece of plastic broke on the outside housing, so it no longer rotates positions when the wheels are raised or lowered. My son found we can move the suction by sliding a finger into the mechanism behind the wheel cover, and rotating the plastic piece clock-wise or counter clock-wise until it locks into position. It's a big pain but it works for now. I wish I could find a replacement piece online. Patty
Apr 03, 2010 | Dyson DC18 all floors Bagless Upright...
I want to install a new hose on a Sears vacuum Mod #116.23812300. How do I remove the Hose Connection Cover(#4370325)? It appears to be a flexible plastic part, however, it will not move from it's position...
You are trying to remove the flexible hose part from the end correct? If you post a picture of the item that would be very helpful since the numbers you posted really didn't help much.
Usually you can just take a flat headed screwdriver and pry out the old hose from the side of the connection piece. Let me know if I am not understanding correctly and I would be glad to help you.
May 05, 2008 | Vacuums
I have a 370A steamer but have lost the two pieces
Hi there, SmartAlec from here. If you are in Australia i can certainly help you. We are a platinum electrolux agent so if you put in a request via our website we'll be able to sort it out no problem.
Happy Vacuuming
Feb 20, 2010 | Electrolux Envirosteamer 370A Canister...
Power head with brush not working
The parts are available for this model but rather than throw money at it by buying parts that you may not need, take it to your local vac shop and let them assist you. It will probably save you some money and time.
Jun 05, 2017 | Hoover S3755 WindTunnel Bagless Canister...
I have an Electolux Oxygen canister vacuum and the power head suddenly stopped working. It is only a few months old. Any suggestions.
1. You have to verify if it's simply the belt that has broken and the spinning brush isn't spinning because of it. Place your ear next to the top of the power head to listen for the power head motor. If electricity is getting to the head you'll hear the motor and know to inspect the belt.
2. If the motor doesn't run, look at the electrical pin connectioins in the pipe from the hose to the head. Are they burnt? If yes a new wand is needed. Also check the electrical connections in the hose handle and make sure they are not burnt.
Let me know if this helps
Oct 09, 2009 | Electrolux Oxygen Z5540 Pet Lover Vacuum
The machine will not suction - it will spray and spin the brushes but will not suction - the power is going to the machine, but it will not suction.
Disconnect the suction hose. While running, check the suction port if it works, by putting a piece of paper. If the paper is taken in, then it is oK. Now, check the suction Hose for breaks or opening before the suction head. Breaks or opening breaks the suction power at the suction head. Loose connection between the suction pipe and the suction port also must be check as this will also cause the same
problem. You may need to replace the suction hose
to correct this problem,
Send us the e-mail and your vote if this solves your problem.
Sep 27, 2009 | Eureka Atlantis 2590A Wet/Dry Vacuum
Hoover s3755 bagless windtunnel canister
Very likely it's the cord at the nozzle neck. These cords flex when you vacuum and they often break internally where the cord goes into the neck. Turn the vacuum on and wiggle the cord at the powerhead and see if the powerhead comes on and off. If this happens, then you will have to replace the cord.
On some of the early models, the receptacle in the hose, where it plugs into the top of the wands, will break away from the plastic pins it sits in, and the receptacle will slide back into the handle, which means that it will not plug into the powerhead connection when you connect the hose. You can check this by looking at the end of the hose and observing if the receptacle is sitting flush with the opening it sits in. If it is pushed back, it will not make a complete connection with the powerhead cord that is sitting at the top of the wands.
Jan 18, 2008 | Hoover S3755 WindTunnel Bagless Canister...
Electrolux Renaissance Hose Replacement
Notice how the hose has a groove just around the outer edge of the gray plastic near the white plastic insert. The hose is held into the handle buy two "tongues" inserted into this groove. One of these tongues is on the end of the top plastic piece of the handle. The second is on the piece of plastic that is slid into the little hole at the base of the handle and it is visible in the picture.
To remove the first, you'll have to remove the two screws in the top of the handle that hold the top plastic piece. This can be a challenge unless you have the right tool. It's essentially a hex-star allen wrench tool that is required, I'm guessing about 1/16 inch. I had one in my tool box that fit. Remove the screws and pop the top plate off. This frees the first tongue from the groove. Now, just get a screw driver (or use your finger) to press the plastic piece inserted in the hole at the bottom of the handle. Press from the "t" side and this should slide right out. Now your hose will slide right out of the handle and you can replace the old with new. Re-insert the small plastic insert, and refasten the top plastic piece of the handle and you're good to go.
Dec 04, 2007 | Vacuums
Kenmore 22812 Bagged Canister Vacuum Logo
467 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
