Question about Formac Gallery 1740 Oxygen 17.4 in. Flat Panel LCD Monitor
All of a sudden I have no power
I turned off my computer last night and all was fine. This morning, however, my monitor has no power at all. I have checked and rechecked all the plugs, cables, etc and all is good. Any ideas??
0 characters
1 Points
My monitor was fine last night, when i woke up this morning it would not come on, the blue light is flashing, help
Press and hold the button, until the monitor turns itself off.
Then, turn it on, and hope that it works correctly.
Aug 21, 2010 | Proview PL926WBi 19" LCD Monitor
We leave our computer turned on at night but we turn off the monitor. The last two weeks when we have turned on our monitor in the morning it will show the desktop but when we move the mouse the monitor...
Yes. Do not turn the monitor off by its power switch, let the computer do the work for you. Alot of times when people use the power switch to turn off the monitor, the computer sees that all of a sudden the monitor has been disconnected from the pc. when that happens the pc sees it as a device beimg unplugged and removes that certain device from the pc's list of things that should be connected, and when you turn it back on the pc sees it again and starts loading drivers for that new part(monitor)
Sep 21, 2009 | AOC LM729 17" LCD Monitor
Plasma screen not coming on at all
IF it is not an adaptor-powered screen, try to exchange the tripol-power cord and try again.
Else you may have to rely on warranty/ return it to where you purchased it or ask electronics dealer for support.
If adaptor powered, buying a new one should be the last option, else you may end up with a broke monitor and two working adaptors!
Good luck
Aug 04, 2009 | Computer Monitors
Colored vertical lines on monitor
Have you unplugged the power cord to the LCD? Let it sit for a minute, then try it. ALWAYS buy a UPS and plug any computer devices into it. Doesn't have to be big, a $50 unit will protect it from dangerous voltage surges.
Jul 24, 2009 | Dell E171FPb 17" Flat Panel LCD Monitor
HP vs17x flat screen monitor won't come on, blue light flashes.
Try taking on the back of the monitor and pulling the power plug all the way out of it for about five minutes and then plug it back in and restart the computer see if it solved it thanks
May 27, 2009 | HP vs17c 17" LCD Monitor
Monitor not starting up -
I think the Power Settings in your Computer needs to be changed. As whenever your computer been IDLE, it goes in a Power Saving Mode.
Adjust your Power Settings from the Control Panel "Power Options" and set them to "Balanced Power Settings" or as per your requirement. There are lot of options their to mention.
Hope your problem will be solved.
Apr 23, 2009 | Computer Monitors
Lg1932 monitor died
same thing just happened to me, fine last night, no power in the morning, why!??!?!?!?! I'm very upset, obviously this is not an isolated incident!
Sep 19, 2008 | LG L1932TQ LCD Monitor
Envision EN7410e monitor
Just fixed mine. Maybe it's a few years late. Hope you guys still have the display. It's the power supply board. I've just replaced 4 bulge capacitors near one edge of the PS. They are 2x1000uF 10V, 1x470uF 25V & 1x470 10V. I salvaged my parts from an old CRT monitor. Hey you can go green with your repairs too!
Apr 25, 2008 | Envision EN7410 17" LCD Monitor
Formac Gallery 1740 Oxygen 17.4 in. Flat Panel LCD Monitor Logo
19 people viewed this question
Top Formac Computer Monitors Experts
Brian Sullivan
Brian Sullivan
Are you a Formac Computer Monitor Expert? Answer questions, earn points and help others
