How do i build a local area network in windows xp?
In my home, I have two computers. One is a desktop wired to a Verizon FiOS Wireless router and the other is a laptop that connects to the internet wirelessly via the router. I have one printer, which is wired via USB to the desktop computer. It is not a wireless printer. Both computers are Windows XP SP3. Is there a way to build a local area network such that I can use this printer from my laptop wirelessly? If so, how?
  • lalalap Dec 02, 2008
    thanks! that worked perfectly.
    last question: does the computer that the printer is connected to have to be on to print from the wireless computer and if so is there a way around that?
    Problem Solver:
  • 7 Answers
On the machine that the printer is connected to go to Start>Control Panel>Printer and Faxes>Right click the Printer that you want to Network and Left Click Sharing> Select the Option to Share the printer and Name it something that you wil remeber. On the Laptop go to printers and Faxes select add new printer and select Network Printer. And Choose the second option Put the Name of the Computer that the printer is connected to and then printer name. Example \\Desktop\HpPhotoSmart 8100. Also you will need to check to make sure that both machines are on the same Domain\Work Group. Go to Start>Control Panel >System>Computer Name Tab ( Here verify the Machines Name)> Join or Change Domain>Put the machines on the same Workgroup if they are not, Do the same on the laptop. To test this, on the laptop go to Start>run and type \\Desktop Name and you should see what is able to be shared. Walk thru the steps above to install the printer on the laptop and have the intall cd in the laptop to install the drivers and you should be good to go. I hope this is understandable. If not feel free to email me at smichael@phoenixschool.net and I will see if I can clarify this for you. Happy networking!
Posted on Dec 02, 2008
  • jockeyjoc Dec 02, 2008
    I always leave my main machine on so I have never tried this but I am almost for sure that you would need to have it on. By the way please take the time out to rank me on my instructions if you do not mind.
Wireless network very slow. We are fine when hard wired into the router but when not it's painfully slow. We have a Verizon fios wireless router westell 9100
Make sure you are connected to your network on wireless and neighbor's
open a browser and go on to www.speedtest.net
click to check your internet speed Fios is pretty fast!
Your wireless if connected to your own network the speed is comparable weather wired or wireless!
Try these steps and let us know the results to further help you!
good luck
Sep 11, 2011 | Computers & Internet
Can't get on line with my Linksys wireless router
you can daisy chain ..but you will need an eithernet run from the fios router to the linksys...
Jun 25, 2010 | Linksys Wireless-G WRT54G Router
Windows Networking Issue
FIOS and DSL use different modems and or gateway devices. Sounds like you were using a DSL gateway device with networking setup and when you moved to FIOS, the tech did not duplicate your network on your new FIOS gateway. OR you had a 3rd party router e.g. Linksys that was removed from the setup when FIOS was installed.
Either way, Verizon is who you should contact. Just tell them your network went down after you moved from DSL to FIOS. Dont mention Microsoft or Livewebtv.
Sep 21, 2009 | Dell Inspiron 1525 Notebook
Cannot Network printers on FIOS system
If both computers are connected to the router. Try turning off the firewall on both computers first. normally its firewalls blocking file and printer sharing that block the connection.
Mar 07, 2009 | Westell Wirespeed VersaLink...
Create a local area network
you can get a HP x175 printserver. (not expensive.) and connected it between the printer and the router. that way you don't have to have the desktop on all the time.
Dec 02, 2008 | Computers & Internet
I have Verizon Fios install in my home. I use to have Comcast. This is the situation, before the Fios my linksys wireless router was connected directly to a modem. Now my linksys wireless router is...
Your IP address for you linksys router needs to be changed.  More than likely there using the same IP address such as 192.168.0.1.
You have to convert your linksys router to a switch and change the IP address range it uses to on that doesn't conflict with the Verizon router.
10.150.1.1 should work.
Oct 08, 2008 | Computers & Internet
Wireless router, laptop problems
Try to delete all the prefered networks. Right-Click Wireless Network Connection, View Available Wireless Networks. Click on Change the Order of Prefered Networks. Remove all prefered networks there and click OK. Now try to View the available wireless networks again, reconnect to your own wireless network and see if it connects fine. Post your feedback.
Jul 12, 2008 | Linksys Wireless-G WRT54G Router
Laptop problems
Does this mean that its the laptop that can't get a wireless connection? Just want to clarify before giving out more steps that you can try.
Jul 12, 2008 | Linksys Ultra RangePlus Wireless Routr...
The battle: Acer Vs. Verizon FiOS
Verizon needs to apply a firmware update for the Atheros wireless adapter in your notebook. I work for Acer and I end up having to tell people this all day long. If you take this to a wireless router that is not from verizon you will have no problems with your connection. Maybe if enough Fios customers complain they will provide a firmware update for this.
Mar 06, 2008 | Computers & Internet
Computers & Internet Logo
537 people viewed this question
David Payne
David Payne
