Question about Kitchen Ranges
Control Panel went blank after self-clean cycle on gas range
We have a KitchenAid KGSA906 gas range. We used the self-clean cycle for the first time and the control panel went blank during the self-clean cycle and the over door is also locked. I now found out out that this is a common problem on these models and it is related to the thermal fuse. How do I access and replace the thermal fuse on these models. Any help is highly appreciated.
Thanks,
-Hari
  • harikr Dec 02, 2008
    Thanks a lot for your advice. I'll try it out.
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
Youll need to pull unit out and remove the back cover, probalby 15 screws or so then youll find the thermal fuse located toawrd the top in the middle 2 wires leading to it, ble and white striped. heres the part number to order 8300802.. LIVE WIRES DISCONNECT POWER!!!!!!!!
Posted on Dec 02, 2008
I used the self cleaning, quick cycle. When cleaning completed the display panel light went off and the door is still locked. Cooking part of the gas stove still works. Could you help us...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Jan 05, 2011 | Ovens
Kitchen Aid KGRA806PSS
hmmm....that interlock is dependent on a temperature sensor, to ensure that no one opens that door when it's too hot inside. I'm assuming that it's still locked, even after the temperature has dropped off?
Feb 26, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
I was using the self cleaning function on my kitchenaid dual fuel range when about half way through the cycle the digital display went blank (i.e. no lights were on at all) and now 2 hours after the cycle...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Aug 19, 2010 | KitchenAid KDRP467KSS Dual Fuel (Electric...
Self cleaning attempt has shut down the control panel.
You need an air flow kit, part 81911788 and a professional to install it.
Dec 23, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
After using the self-clean cycle, display panel went black and oven door stayed locked.
Happens alot dont feel bad , self clean mode runs the elements at 500 deg. to cook off everything possible , what happens is the cabinet gets to hot and heats saftey temp. fuses until they go out and they are not resetable. they are always located in different areas of ranges but usaully in the back. you can ohm them out to check them if you have a meter.let me know if you have any other questions.
Phil
Apr 14, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
Kitchaid Gas range
heres the thermal fuses thats gone bad its mounted on the back wall of the unit youll need to get behind and remove the panel , unless of course its under 1 yr old then its a warr. issue part#8300802 - THRMST-FIX
Oct 25, 2008 | KitchenAid KGRI801PBS Gas Kitchen Range
Kitchenaid kgri801pbs
there is a thermal fuse in the back of the oven that more than likely has tripped during self clean poor air flow around can cause this power surges during self clean can too you have to pull the oven out and remove back panel to find it
Jan 10, 2008 | KitchenAid KGRI801PBS Gas Kitchen Range
Kitchen aid model# kgri801pbs
On most models, the door stays locked during a self clean, until the temperature returns to normal for safety reasons.
It sounds like your unit may have tripped a breaker during this self clean event. Check your panel for a tripped breaker. If the oven has cooled down, and the lock is still engaged, then we may have a different problem.
Let me know what you find out!
Kitchen Ranges Logo
698 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
