SOURCE: Question on a Konica Bizhub 600. Works well after
Make sure that during the PM the LD1 and LD2 adjustments are done. If they are set too light or too dark it will cause over toning or under toning. Also check the gears on the back of the developer unit, there is one small gear that can wear down. This gear drives the augers that add the toner to the developer mag roller.
SOURCE: konicaminolta bizhub 600 machine dropping the toner. what is the solutions?
first toner must must and must be genuine, other wise it wont work in any conditions,
2nd toner density sensors and gamma sensor should be cleaned and all auto setting must be run .
third some time toner drops down the others side of the drum due to recycle clutch did't not work properly and all cleaned toner drops down after filled in recycle area,
Hi kholiqjamal, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? do not quite under stand?
