Question about Toshiba DKT-2020 Corded Phone
Panasonic 816 reduce from 4 to 1 ring before auto attendant ans.
Our church installed a used panasonic KXTD 816 phone system with voice mail. It takes minimum of 4 rings before the machine answers. Is there any way to reduce this. We let the auto attendant /voice mail redirect the calls to the proper extension.
Myron
  • 45 Answers
You can voice mail to answer after one ring.
You will need a programmer to program ringing.
info@ameritelnj.com
Tony
Posted on Apr 03, 2009
Don't know the extension to check messages.
I need to know what phone system you have. If it has a VM system and the model of that unit.
I am going to make a hunch here that you have a KXTD unit (816 or 1232) and a VM system that goes with it. The system will know who you are by extension number when you hit a red lit Message lamp on the phone. If it is off, use Intercom 165. In most cases you will need the password otherwise you will need to reset them. I caution you that you should get a Panasonic tech into your office to handle this for you though.
Sep 18, 2017 | Panasonic BTS Panasonic KX-T7433 Black...
One line is being answered by Voice Mail without the phone ever ringing. How can I turn this 'auto-answer' off?
You have to check DIL in the 400 series on the 1232/816. This may be done by TRUNK GROUP or Line number. So if it is line one doing this, simply find Day DIL and if it asks for line number place 01. It will show an extension number typically 165. Hit the transfer button then hit the store button. Now this can also be done under intercept with the rings set to 1 ring. That is in the same area and the procedure is the same. You should first find what TG the line is in first, then do this. Now I am sure you want the VM to answer at some point so I would place that in the intercept Day and Night and set it for say 4 rings. By the way, these particular settings are not normally customer settings. I may also advise you to contact someone who can quickly make the changes for you.
To contact me direct, call 585-216-5066.
Aug 23, 2012 | Panasonic KX-T7453 Corded Phone
I have a panasonic KX-T7130E and want to know how to connect and install it.
It connects to a Panasonic Key Service Unit, pick a number, TA/TES, TAW, KXT, KXTD, and in some cases TDA/TDE/NCP. It's an analog 4-wire system phone, so it requires both voice and data pairs (a 4-pin connection) and a port on the system. You can only connect one 7130 to a system extension.
Carl
Jun 05, 2011 | Panasonic KX T7130 Corded Phone
How do we set up the phone system so that an outside caller can call our extension directly without having to go through reception/main unit?
There are a couple of ways. The easiest one is to use the Panasonic voice mail system which has an auto attendant built-in. It can be programmed to answer incoming calls, play a menu and let the caller dial extensions or ring the operator. If no one answers, it can take messages and provide the voice mail for the system. The TVA system has a LAN card that can send voice mail to email. It's optional in the TVA-50 and included in the 200.
Carl
Mar 14, 2011 | Panasonic KX-T7630 Corded Phone
1)How can i stop the automatic transfer of calls to another extension phone when i have not taken the call that should be for me... 2) how can i program my switchboard into voice mail where they can...
It takes so long to get an answer because you asked two different and complex questions. 1. Where do you want the call to go? It's related to question #2, but the forward either works or it doesn't...that's what the FWD/DND button is for. Your delay before it goes can ge adjusted. In our installations, we use CF-No Answer and set the ring count to 4. If you're on the phone and another call comes in, you can see it from the display and hear the soft ring. You can either answer it or ignore it and it will go to somewhere else (generally voice mail).
As far as your second question, if you have voice mail, an auto attendant can be part of the system. It's programmed at installaton to pick up incoming calls and follow a menu system called Custom service. It also functions as your voice mail system as mentioned in #1.
Carl
Mar 08, 2011 | Panasonic KX-T7633 Corded Phone
I have a Panasonic KX-T7433 and want to change the Auto Attendant message. How do I do this?
An auto attendant in a Panasonic brand voice mail system (TVS/TVA/TVM etc.) is controlled from the message manager's phone. It is accessed by calling 165 and dialing #6 *998
Unfortunately, your question has no hard answer. Each voice mail and auto attendant is different. For example, in TVS boxes, we use custom greetings and store day messages in 30 and night in 60. There are 100 "custom" greeting slots and 32 "company" slots in a TVS box. In the newer TVA systems, the interface is visual and custom messages get assigned sequentially. In those systems, we start with 1 day and 2 night.
So, the best answer is to find the installation instructions. If you can't, then you can step through each custom greeting for the existing one, or log into the VM system and read the database.
Carl
Feb 16, 2011 | Panasonic KX-T7453 Corded Phone
I currently use a Panasonic KX-T7431 at work and I wnat to either know does it have an answer machine function within the phone or can I buy one to add to it , we cusstenly do not have any faciity for...
Generally, a 7431 phone plugs into a Panasonic KX-TD phone system cabinet. The 1232 starts as an 8 line 16 phone cabinet, the 816 a 4x8, and the 308 a 3x8. To those systems, you can add a TVx Panasonic brand voice mail system, or even a plain old ansering machine. Both would need to be probrammed by someone familiar with ringing and intercept groups in system programming.
A quick call to your Panasonic installer or dealer would be the best, as it's beyond the scope of this forum to provide instructions.
Carl
Aug 17, 2010 | Panasonic KX-T7431 Corded Phone
We have a Landmark/Southwestern Bell Telecom DKS 308/616 system and need to know how to access and change the auto attendant greeting.
Call your own number or press and hold #1 button and when the message starts playing press either # or * and follow the directions. It's usually #
Apr 16, 2010 | Cell Phones
Need more rings
You have to change the rings from the voice mail server. If you don't know your way around the server, its best to get a local NEC tech although it is fairly simple to navigate. Depends on your skill. Typical default password for the server is NEC
Oct 16, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Voice mesage
What manual did you download, where is the message located, and what is it recorded on?
A 7433 phone is just a phone, it has no messages. It is connected to a TD-816/1232 Key Service Unit and a TVS/TVM/TVA voice mail system if it's Panasonic branded.
When you call in to the TD system, the voice mail answers the call and plays the Auto Attendant greeting. Is this the one you want to change? Or do you want to change the greeting that you get after the AA answers any they dial your extension?
Each of those messages can be changed from the Message manager's box or from your own mailbox, using the codes and passwords supplied at installation.
Carl
Aug 27, 2008 | Panasonic KX-T7730 Corded Phone
Toshiba DKT-2020 Corded Phone Logo
184 people viewed this question
Top Toshiba Lands Phones Experts
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
