Question about Smeg FC40RX Bottom Freezer Refrigerator
Freezer just stopped working
Last night I discovered that my freezer had just defrosted. The door was shut and everything setting wise appeared normal. I cannot get the freezer to freeze again and the red LED light on the top left of the freezer is now on. There is nothing in my manual that explains what these lights and buttons are for although I imagine the red light is warning me about something. Does anyone have any ideas how I can get my food frozen again? Thanks
  • Anonymous Mar 22, 2008
    I have the same problem - no instructions to say what the switches and lights are for. Door was closed and fridge is ok but freezer has defrosted itself .
  • 237 Answers
Several problems can cause this. It may be "stuck" in the defrost cycle, the compressor start device could have failed, the temp control system could have failed, evap fan could be bad and not circulating cold air, or worst case is the sealed system has leaked all the refrigerant out. Post again with more info like: Is the compressor running? Are there any fans running? Does the temp control turn the compressor off and on? It never hurts to unplug the unit for a few minutes and then plug it back in to see if it will kick over and run again. We'll have to go back and forth with some troubleshooting to narrow it down.
Posted on Jan 31, 2007
I have two door bottom freezer in my LG refrigerator...Freezer is defrosting its' contents..I lowered the temperature but it still persists...any solutions?
My bottom freezer LG is intermittently shutting down and thawing everything in the freezer (cooling stops in fridge part, too). $3,500 for a refrigerator that works only 18 months.
Mar 18, 2013 | LG Refrigerators
Freezer not cold but refrigerator still cool
HI JULIE.TRY DEFROSTING ALL FIRST 24/48 HOURS.(USE ALTERNATIVES FOR FASTER DEFROSTING.ie;hair dryer;steamer;boiling water bowls etc.)if ok after that great.if same again then 1-defrost timer 2-defrost heater 3- t/stat.good luckALI
Jun 30, 2012 | Maytag MBB1954G Bottom Freezer...
Kenmore refrigerator stop cooling but fan working
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Apr 06, 2010 | Kenmore 53642 / 53644 Side by Side...
Not only will the fridge side not cool properly, now the door won't stay shut. Temp in fridge side stays 20 degrees warmewr than what panel says.what a pos.
Fridge problem- How to check everything http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR
Door problem-The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Aug 22, 2009 | Refrigerators
The freezer appears to be thawing even when shut all day.
Aug 18, 2009 | Refrigerators
Refrigerator and freezer not working
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 15, 2009 | Whirlpool ED5FHEXMQ Side by Side...
My son got into my fridge lastnight-left open, now won't cool
evaporator coils is probably frosted from condinsation.shut door set at normal setting and give some time.
Jul 26, 2009 | Frigidaire Freezer Refrigeration White...
Kolpak - Polarpak - door left open all night, might be broken
check to see if the evaporator coil is frozen up, if so you can defrost with hot water.be sure to turn power off and not spray directly into fans.
Mar 17, 2009 | Kolpak Commercial Freezer Polar-Pak®...
Smeg FC40RX Bottom Freezer Refrigerator Logo
470 people viewed this question
Top Smeg Refrigerators Experts
John Tripp
John Tripp
Mike
Jay Finke
Jay Finke
Are you a Smeg Refrigerator Expert? Answer questions, earn points and help others
