Question about RCA Victor Clock Radio
Humming noise my parents have a rca victor model VHT-37-L and it has a hum through the speakers on radio or phonograph i think its coming from the transformer but i cant locate the part. the part # on the transformer is 1461174-9 or 450-6704 that could also be one part # have been to several different sites trying to locate and have had no luck any ideas an do you think the transformer is my problem any help would be appreciated. thanks dale
I am fairly certain that your problem lies in the electrolytic capacitors. This is the most common problem in vintage radios, and causes them to make a humming noise that isn't affected by the volume control.
Posted on Jun 15, 2009
Humming in my radio
Hi, Mike for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
installed sound system buzzing noise from speakers
Stereo and hum noise Harley Davidson Forums
How to fix buzzing engine whine in your car audio system
Apr 27, 2016 | Motorcycles
Why does my HTS-20 powered subwoofer make a low hum when plugged in, even turned off and not connected to the receiver and a louder hum when the subwoofer power is turned on?
I suspect the amplifier is damaged. This is not an easy repair to do unless you are well versed in audio electronics. I would recommend a repair shop to look at the subwoofer amplifier.
Jun 03, 2015 | Infinity HTS-20 System
My KLH powered sub maks e a humming sound when i plug it in but it only hums when the speaker is hooked up i tried others but did the same eventually speaker started smoking would wrong fuse do that
Wrap a wire around the outside Metal of your rca jack in back of your radio and ground the other end of that wire to the back of your radio and the noise goes away
May 09, 2015 | KLH Audio Players & Recorders
Have a humming noise in both of the speakers
Something's crossed, keep power lines and sound lines seporated double check wires in and out u could have bad sound wires and if so of home just buy new for a car get the RCA lines with a built in ground.
Aug 07, 2014 | Toymax Magnavox 37MF231D 37 in. LCD TV
I have a vintage RCA Victor turntable from the 50's or 60's. I need to replace the needle housing, but cannot find a model or serial number to look for parts.
Turnatables then used ceramic or crystal cartridges. All you need to do is look for one of them plus something that will fit in the space in the arm. You will probably not find the original cartridge.
Feb 17, 2013 | Audio Players & Recorders
Making loud humming noise only.but if you plug
If I understand this correctly: with NO input or cable attached it hums; with an RCA cable attached it works. (What does 'some' mean in this regard?)
You say that connecting the RCA cable improves its sound. That tells me you're supplying a ground through the RCA cable for stray voltage in the sub.
It seems there may be a basic power issue if it hums with no input. Sometimes a given power source in a home may be wired differently than others or may insufficient grounding, which can result in hum. Try reversing the sub's power plug or move it somewhere else.
Since the sub contains its own electronics it is also susceptible to strong external magnetic fields. Keep it and any signal cables leading to it some distance away from other electrical devices like TV's.
Apr 08, 2010 | Velodyne CT-100 Speaker
37" Philips LCD no sound.
Maybe the antenna that you are using is not picking up sound from the channels. It could also be the cable. If it makes a humming noise, it means that the speakers are getting electric current and that they SHOULD be okay. It also could be your tuner. Maybe check it all out at some tech place like best buy. Those guys can help
Aug 24, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Humming noise
Usually Humming noises come from frequency interferance.  In this case it is being caused by your input sources.  A smiply solution is to replace the cables and or seperate the source cables away from any electircal cords or sources.
Jan 07, 2009 | Harman Kardon AVR 225 Receiver
Background "hum" in R speaker
Yea try plugging it into another wall socket, if it's still humming could be a damaged transformer. or bad capacitor.
Jun 05, 2008 | RCA RS2531 CD Shelf System
RCA Victor Clock Radio Logo
470 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
