Question about Video Game Consoles & Games
When powered on the Xbox 360 shows a blue screen only and nothing else. The CD-ROM slide functions OK but the machine does not seem able to read anything from it.
  • 82 Answers
Blue screen normally means that you either
a) did not plug in the video cable all the way (yellow)
b) are on the wrong input on the tv
Posted on Dec 02, 2008
Xbox 360 DVD Drive Not Reading Games Only DVD,CD after replacing the dvd rom
If you replaced the DVD-ROM drive yourself, some newer Xboxes do not recognize and/or function properly with older drives. I tried replacing a drive in an older Xbox with an older yet DVD-ROM drive, and it would not work. When replacing a DVD-ROM in an Xbox, it is advisable to use the same model drive, as the Xbox does strange things when you introduce different hardware. The url of a page is below that details the different drives that Xboxes use. See if your new drive is the same as the old one, and if not, that is almost certainly the issue.
http://www.llamma.com/xbox360/Xbox_360_DVD_Drive_Comparison.htm
Good Luck!
Jul 07, 2011 | Microsoft Xbox 360 Console
My 360 is not reading the disk what can i do?
There are a couple of steps you can take when your 360 isn't reading your DVD-Rom.
First off, try another game, if it reads it then your 360 is working properly. Your game on the other hand may have scratched which need to be cleaned. If it's cracked, there's nothing you can do.
If it's not reading any other game disk, then you should try airing out the dust in your 360. If that doesn't work you can try cleaning the lends. Here's some information from eHow in regards to cleaning the lens. I like recommending eHow because it provides simple, easy to follow, step-by-step instructions for situations which may seem difficult:
http://www.ehow.com/how_4926838_clean-xbox-lens.html
Jan 04, 2011 | Microsoft Xbox 360 Console
XBOX 360 cd rom is not reading discs
1. Make sure you REMOVE any discs from your XBOX' tray. 3. Turn on the console again, either by using the controller or the POWER button (NOT the EJECT button) and WAIT for the initial XBOX setup. ... This fixes the OPEN TRAY error 100 % of the time on my XBOX 360. XBOX 360 cd rom is not reading discs Google Search
Jan 13, 2018 | Microsoft Xbox 360 Console
Xbox 360 will only read halo !!
That is an odd problem. It sounds like you maay need to change the laser or the dvd rom assembly if its reading only one game, yet all the games it wont read are working ok in another console. If i was you id simply replace the DVD rom drive, making sure its the same version as the original from the unit. I hope this helps. Good luck.
Dec 05, 2009 | Microsoft Video Game Consoles & Games
Disk reading problem
The Cd rom is bad call Xbox live because you cannot fix xbox 360;s yourself you void the warranty 1-800-4my-xbox
Sep 18, 2009 | Microsoft Xbox 360 Console
Won't read any disks. DVD's, Games, or Music
If the system boots up and goes to the dash board but when you put a game or dvd in does nothing or says it can't read the cd. The problem is the CD Rom is dead. You can try cd rom cleaner cds found at Walmart. It could also be a dirty lens.
Hope this helps
Sep 06, 2009 | Microsoft Xbox 360 Console
360 just has blue screen
Check if it is on the right video imput or check the connections from your xbox to your tv via the three colored cables.
May 12, 2009 | Microsoft Xbox 360 Console
I need help xbox 360 black screen
OK, I think I can slove your problem.
There is a slide setting thing on your av cord that gives you the option of using TV or HDTV (look near the end of the cord that slides into the XBOX 360), You will see two choices for settings on the cord "TV" or "HDTV".
Just make sure that you have it on the correct setting. I had the smae problem. My XBOX 360 is not hooked up to HDTV, so for me it should stay on TV. But somehow when I took out the cord I accidently slide it to HDTV.
I simply slide it back to the "TV" Setting and in about 30 seconds it worked perfectly.
I hope this helps you.
Dec 27, 2008 | Microsoft Xbox 360 Console
Won't read games
If you swap drives from another xbox 360 will not work unless its the same dvd drive thats why your 360 plays cd's and dvd's only !!1
good luck
Nov 09, 2008 | Microsoft Xbox 360 Console
Xbox 360 not reading DVDs
Here is my advice Clean the disk with a disk cleaner and put it in then when it say's disk cannot read click ok and a backround should come up whether it is blue,purple,orange,etc. a screen will pop up...go to setup and it should say cd,dvd,multimedia click on it and there should be a box and you need to click inside and mark it and select ok
Mar 10, 2008 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
44 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
