Question about Dell Dimension 2400 PC Desktop
Thanks! I read that paper clip solution in another post, but didn't see the small hole in the front of the drawer. I assumed this model didn't have one. : ( Wonders of using a flashlight-tadah!!
  • 115 Answers
There will be a small pin-hole below the tray either on the left-side or rightside.
Posted on Dec 18, 2008
Hitachi htc-c15u drawer wont open
straighten a paper clip and insert it into a small hole in front of the CD panel, this is an emergency eject button for a defective cd drive
Jul 14, 2014 | Computers & Internet
MHC-RG270 cd draw won't open
cd drawers often jam.
In the cd/dvd drawer you will see a small hole. Use a blunt pin or a straightened-out paper clip, insert it into the small hole and gently press. The drawer should then click open.
Try cleaning the plastic drive teeth/mechanism with a light drop of oil. Press the drawer button and it should then close. Press it again to see if the drawer opens as per normal.
If your cd drive plays a dvd as per normal but doesn't open when the button is pressed, continue using a blunt pin/paperclip. If the plastic open-close mechanism is worn or damaged there's very little you can do about it expect replace the entire drive.
Feb 01, 2014 | BenQ FP91G+ 19" LCD Monitor
Opening cd player
What about opening the cd player?
Are you saying the cd drawer will not open when you push the button? If so, try the steps below.
Take a paper clip (Gem Clip) and straighten it out then get in front of the cd drawer where you place the cd. Look for a small tiny hole on the drawer and insert the paper clip (Gem Clip) into the tiny hole and push it in while you press the button on the drawer. Don't worry about breaking something, use a little force to push the paper clip in, that's why that hole is there.
May 31, 2012 | Samsung Computers & Internet
Laptop dvd drawer stuck closed
The front of the DVD drive, (Tray), has a small hole. It is to the right of the button you push to open the DVD drive.
Use a partially straightened out paper clip to insert into the hole.
This is a manual override.
When the paper clip is inserted into the hole, you will feel pressure, when the paper clip is so far in. Gently push the paper clip in further, until the tray pops out.
Follow with cleaning the DVD drive, with an appropriate product. It could be the laser optical eye is dirty, or it may be that the DVD drive is at the last of it's 'Life-Cycle'.
A DVD drive is a mechanical device, and is rated in hours of usage.
For additional questions please post in a Comment.
Regards,
joecoolvette
Dec 18, 2011 | HP Pavilion dv7-1130us laptop
Drawer won't open
There is a mechanical way of opening it. Straighten out a paper clip, find a very small hole on the face plate of the drawer slide. Insert the straighten paper clip end into the hole and push gently. this will push the unlatch triger and release the tray.
Jan 07, 2011 | Dell Inspiron 6000 8x DVD/CDRW Combo Drive...
CD Tray will not open, on playback often says insert disk when a cd is entered.
Straighten a paper clip. There is a small hole the size of the paper clip on the front of most disk devices. Put the clip into the hole and the drawer should open.
read ya,
Zee
Dec 29, 2009 | iLO DVDR04
Disc will not open
If you have something inside that you need out fast. Take a paper clip and straighten it out and push it in the small hole. There is a release clip inside that will allow the drawer to open. You have to use a little (key word, a little) force to open it. Don't cram it and don't be light eiether. You will see the drawer try to open up. Now once the drawer is open you have a new dilema. The laptops cd might be failing. I am going to assume nothing has been changed (new drivers) but you might want to take it by the Nerd Herd and see what is wrong. If you are posting this you must be unsure, so pay them $30.00 and be sure and watch them. Not because you can't trust them, but for you to learn. Always learn.
Dec 13, 2009 | Acer Aspire 5050-3242 Notebook
Drawer of cd burner will not open
This could be an issue with the drive itself.
You might want to consider replacing the drive, however, if you have a CD stuck in the drive or the drive doesn't seem to be getting enough power, etc...
Then you may want to try this.
1.) Unfold a small paper clip until it is straight. Any small, straight metal object will work but I find that paper clips work best.
2.) Look at the front of your ODD. You should see the button that normally opens the drive on the right hand side.
3.) Slightly to the left and above the button you should see a small hole (VERY small, like the size of a paper clip)
4.) CAREFULLY insert the paper clip in to the small hole. Push straight back until you feel the paper clip strike the mechanical release.
5.) This will open the ODD slightly, you may have to use your fingernails to open the drive the rest of the way.
Oct 08, 2009 | Dell Dimension 3000® Pentium® 4...
Dell Modem CD Drawer Won't Open
Yes. There should be a very small hole on the front of the CD/DVD drawer. Insert a straightened paper clip into this hole until you feel it push a button, and this should manually release the drawer.
Nov 05, 2008 | Computers & Internet
CD drawer will not open
Most CD's have a small hole in the front of the drawer cover. This hole can be used to open the drawer, straighten out a large paper clip (wire style). About 2" should be enough! Put he paper clip end thru the hole perpendicular to the front (straight in). You will feel resistance at about 1/2" to 1", pressing firmly (don't jam it in), the drawer will start to open as you press the right place, gently pull the drawer open. If something is jammed inside, removal and possible replacement may be required. If you don't feel confident in opening the case, don't!
Oct 20, 2008 | Compaq Presario X1000 Notebook
Dell Dimension 2400 PC Desktop Logo
22 people viewed this question
Alun Cox
