Question about NEC Televison & Video
Hello, I have a NEC NP1000 projector and I have 2 questions: 1. The top and bottem of the picture are cut off. I have tried it using VGA, S-Video, and HD, all with the same results. It is also the same in all of the aspect ratio settings (4.3, Letterbox, Wide Screen & Crop) and I have tried the horizontal and vertical settings too. When I use the same inputs on an Infocus LP820, the picture is fine. Any suggestions on how to correct this issue (NEC said bring it in for service, but the guy sounded like he couldn't tell the difference between a projector and a toaster). 2. This NEC projector seems dark for a 3500 Lumen output. I just installed a new bulb which helped, but my 3200 lumen Infocus out performs the NEC in brightness and color (not sharpness clarity though). Again, I have tried all of the different settings. Can you help? Thank you, Lou
  • 82 Answers
If there is a reset to factory default, try that. Seems like some setting for screen zoom, or height/width adjustment got tinkered with.
Posted on Dec 02, 2008
Nec v260xg image alignment problem
Try the Keystone correction function to correct the trapezoid distortion.
May 02, 2016 | NEC Display NP-V260X Dlp Projector - 3D...
URGENT: How can I connect my tv to my NEC VT695 projector?
Do you want to duplicate the image going from the source to the projector on your TV? If so, then if your TV has a VGA port, just use the monitor Out on the projector. If your TV doesn't have a VGA port, you'll need an appropriate converter. (Avoid a VGA to component video or VGA to composite cable.) If you add a comment with more information on the inputs for the TV (or the model of the TV), then I will try to point you to the correct converter.
If you want to get your TV signal to the projector, you would need a set-top box (cable, satellite, digital tuner) as the source. Most TVs do not have a video output. You can connect a computer or DVD player to the projector.
The manual and quick guide for the VT695 are available from NEC here: http://www.nec-display.com/dl/en/pj_manual/vt695_491.html . The direct link to the English language version of the manual is http://www.support.nec-display.com/dl_service/data/manual/english/vt695_491_manual_e.pdf .
I hope this helps.
May 25, 2014 | Office Equipment & Supplies
How can I get the best video image quality with Nec np1000 projector ?
Your best option is using the COMPONENT IN input of the projector (Y, Cb, Cr). Though the highest video signal the projector will support is 1080i.
May 09, 2014 | NEC Televison & Video
Service manual
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Jan 31, 2014 | NEC (NP01LP) Projector Lamp for NP1000,...
Tutorial
Hi Connect your computer monitor out VGA connector to Computer input VGA connector of projector. Select source in projector (with remote) as computer/RGB/VGA as terminology used on the projector..
The projector will work as large screen projection monitor for the projector.
If you want to use monitor and projector both, you can use 1IN-2 OUT VGA distribution amplifier (Commonly called as "VGA Splitter"
Jun 26, 2012 | NEC Np13lp - Projector Lamp - 180 Watt -...
I have an NEC projector that the image has flipped so it is upside down. How do I fix it?
1. Click on the Menu button, either with the remote, or using the controls on the projector.
2. Use the Select control, scroll to the Setup tab at the bottom and click Enter.
3. Use the Select control, scroll to the Installation tab on top and click Enter.
4. Use the Select control. scroll down to Orientation and click Enter.
5. Use the Select control, choose the Front option that gives you the correct picture. (The Rear options are only used when projecting through a mirror)
6. Use the Select control to highlight OK, and click Enter.
Jan 13, 2011 | NEC MultiSync LT280 LCD Projector
Hello, I'm a teacher in a primary school, and we have a serious problem trying to turn NEC np 110 on. We work on Windows XP, and so far, couldn't find a solution to the problem. Is it possible to get an...
The projector doesn't use any kind of driver.
You just need to connect it to the VGA output of the PC and actually, enable that output.
Go to desktop settings and enable the second monitor. That will turn on the projector display.
Also, make sure the projector is turned on (Steady light on the power button) and that the VGA input is selected.
Nov 05, 2010 | NEC NP110 Projector
I have a multimedia projector NEC VT470 and is getting red picture.
If you are using the vga input connection please take a look at all the pins and make sure none are bent this could be the reason you are missing one of the primary colors. If not check your cable pins.
Jun 04, 2010 | NEC VT470 Multimedia Projector
NEC NP1000 projector: In a corporate meeting...screen display is upside down! Help?
There should be a menu setting to flip the image vertically. Check the menu settings.
Feb 04, 2010 | NEC NP100 Projector
NEC NP1000 powers up, strikes, then shuts down
the expected lamp life is an average .. its not unusual to see early failures ... check the lamp connections to make sure they are secure ... check ventilation to make sure its not blocked by dust .. if there is a fan, make sure its working ..
Oct 07, 2009 | NEC NP100 Projector
Televison & Video Logo
200 people viewed this question
Top NEC Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
