Ac monitor63 keeps a sign on my desk top when i turn on my computer with a x showing how do i down load to fix the problem
  • 57 Answers
I could not find the software online but I did find an alternative here:
http://www.download.com/Laptop-Battery-Power-Monitor/3000-2094_4-10573418.html
You could try to install the new monitor and see if it differs. If not then you have a hardware problem.
If it does then remove the old and keep the new.
Posted on Dec 02, 2008
How to set up my desktop in a clean way?
The Desktop Cleanup Wizard is a component included with Microsoft's Windows XP operating system. It aims to reduce the clutter in a user's desktop environment by moving unused shortcuts to a separate directory called "Unused Desktop Shortcuts"
If you are not using XP .
1.Right click on desk top.
2.Go to sort by and choose an option
3.Right click on desk top
4.Choose New
5.Select Folder.This will create a folder on your desk top which you can drag and drop all desk top icons that you do not need regularly.
6.Create another folder and use it for down loads.This will keep it clean.
May 11, 2011 | Microsoft Computers & Internet
Screen lights up and goes back off with power still on. Ex.: When powering up computer, screen will show page for a few seconds then disappear untill a differant page comes up, show new page for a few...
Hi Larry,
I see that you are having issues with you LCD monitor intermittently showing Video for a few seconds then just dies to a black screen and will show windows in the desktop then go back to a black screen again on the issue ...
I believe that what you are experiencing on the issue is a screen refresh rate setting in windows.
we will need to check you video settings on the system for the issue.
Before we go and change some settings on your system we will need to boot into safe mode first.
1. From Shut down as soon as you turn your system on keep on tapping the F8 key on-top of your keyboard, this will give you the Windows Advance Options Menu.
2. On the List Select Safemode once highlighted press enter once, a bunch o things will show up on the screen this means that windows is loading in Safemode and windows will be loaded but all drivers will not so may encounter a screen that has big Icons and letters on it which is normal.
3. Log-in you windows profile if you have a password setup, once logged in do the following instructions below.
Changing the Screen Refresh rate:
1. Right Click on your Desktop/wallpaper to get the pop up options menu, click on personalize.
2. In the personalize window click on display lower left side of the window
3. Then Upper Left side of the new window click on Change Display setting then on the next page lower right side you will see Advance settings click on it.
4. you will get a small window click on the monitor TAB you will see there a drop down for the Screen Refresh rate click on the drop down and select 59 Hrtz, then Click on Apply then OK to save the settings work on your monitor.
Apr 06, 2011 | Computers & Internet
Hi i have hp 6735s laptop & i it's battery was very good but in last couple days it began to shut down after i plug off the power by 2 or 3 minutes without showing any message to notify me &...
NO OS stated ?Operating system" we cant never ever guess that.
remove the battery , test the PC with no battery?
does it run perfectly now ? yes/no.
if yes and not with battery then the battery is bad or not charged.
this is step 1. of a long process.... PCs are complex
I can not understand your post at all. (cept its power issue)
the full PCs model was not stated,
Is this LT mobile? or always on a desk.
I cant just know how you use a laptop ever.
on desk or in an airplane or at STARBUCK's is 3 different usages.
on a desk? Ill answer, the others are vastly more complex !
DESK bound 110 LT:
  1. turn off sleep and hibernate modes (CP + power settings)
  2. turn on , the same page, "laptop power button turns off PC":
  3. make sure the your software is from HP at your HP support page, we are NOT HP. here.
  4. keep the battery out, of the pc, charge it and park it so when need it not bad or dead. leave it out. run on AC power only.
  5. my wild guess is PC goes to sleep and sucks the battery dry as all do eventually or all do on weak /bad batteries. keep the AC power pack plugged in to wall power all the time. hint hint.
this PC is a very old COMPAQ
HP does not support this now, it's too old (why not upgrade)?
so to fix it , takes tedious steps.
my post above begins this process....
the one thing I cant unstand is this.
plug off? (what? is this)
Jul 27, 2017 | HP 6735s Notebook Laptops
Need help my desk top monitor is showing a sign flashing saying no signal detected need to see how to fix or what might be the issue with desk top
This is the message shown when you power off your computer but you leave the monitor on. If your PC is on but you still see this message then it is a video problem. It could be as simple as a loose connection somewhere in your video cable (either where it plugs into the monitor or where it plugs into the PC). It could also be the monitor-many have different input modes and maybe the input mode changed somehow. Then again something could be wrong with the video card-are components loose on it? Check all of these, in that order (easiest to hardest), and I think you will have found the problem.
Hope this helps.
May 19, 2010 | Computers & Internet
One of my desk top speakers is crackly like it is blown and it is still under the 1 year warranty
Hi there bud , 1st thing you want too do , when speakers are showing signs of trouble, take it into shop and ask them too fix it , Luckily you have your warranty ...Dont let it carry on without taking it in...Hope you come right Bud
Happy new year
Jan 06, 2010 | Logitech Z-2300 2.1 Computer Speaker...
My lap top worked just fine in the morning and went into sleep mode. The computer was unplugged so there isn't a power surge issue. I've tried shutting it down by holding down the power key, I removed the...
try the following steps.
1.remove the battery pack
2.press and hold the power button for 30 seconds.
3. plug in the ac cord to the wall and to your laptop, (make sure the light indicator on ac adapter is on)
4. press the power button once to turn on
IF this process fails, more likely you have a motherboard issue. South Bridge chipset may need to be resoldering or replaced
hope it helps yuva
Mar 26, 2009 | Computers & Internet
Drivers installation
OK !
turn the computer around, there is a serial number attached to the back panel, you are going to need that, and also write down the model of the computer, it should be on the front of the computer.
go to Dell.com, click on download and support. select the system you have. you should be able to get all of the drivers for the system. privided you didn't change anything in the computer.
Oct 31, 2008 | ASUS P5RD1-VM Motherboard
The screen saver keeps freezing up on my E machine desk top how do I fix it ?
download antivirus:kaspersky or avira
install and scan your computer
hope it will help solving your problem....
tnx 4 using fixya!! :-)
Oct 12, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
