Question about LG LFX25960ST Stainless Steel French Door Refrigerator
LFX25960ST Ice maker problem
I have an LG refrigerator with an Ice maker that stopped working.  You said the I/M is bad but what is the I/M?  How do I know that will fix my problem.  I turned off the ice maker and now the wire will move and when I turn it on the arm moves from down position to the up position and the arms that pushes the ice cubes out cycles around.  Everything seems to work fine except now the ice tray will not fill with water.  when it stopped working the wire would not move.  I thought it had just frozen so I thought turning it off and letting it thaw out would fix it but now it does not fill with water.  When it stopped working there was water in the tray but it would not eject the ice. Now it seems to have thawed and work fine but does not fill with water. What do I need to replace?  Can you help?   Email Address:  Steve.Tiedemann@xerox.com
  • msr3w May 08, 2009
    iCE MAKER NOT FILLING WITH WATER i MANUALLY FILLED IT AND IT NEVER FROZE
5 Suggested Answers
ginko
  • 19396 Answers
SOURCE: ice maker will not push out ice cubes once frozer
That means that the evaporator fan system that releases the the ice cubes is not working as it should.
The heater, or evaporator fan and heating system must be checked, and fan, or solenoid, or element must be replaced.
Use the number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
Posted on Nov 29, 2008
jumptrout51
  • 3361 Answers
SOURCE: Ice cubes don't thaw fast enough.
No. The motor timing is set and not changeable.
Posted on Apr 28, 2009
SOURCE: LG Ice maker
I got the same problem where the plate is cold and the water does not fill - saw this comment from other posting and help. Basically, the ice maker was stalled! Make sure you can see the green light is on, which means you have power. if its lit, press and hold the cube size button until i/m starts to cycle. If i/m runs, but does not fill then your water valve is bad. If i/m will not start then your i/m is at fault.
Posted on May 07, 2009
  • 36 Answers
SOURCE: I've got the LFX25960ST model. The icemaker
its the ice maker .water or condensation has built up in the ice maker modual and refroze upon turning unit back on.either get a new ice maker or uninstall the ice maker and let it dry for a few days and reinstall.but it could happen again that way.or maybe not.
Posted on Jul 24, 2009
Trouble shooting LG french door ice dispenser
LG French Door Refrigerator - In Door Ice Maker Troubleshoot
? 4:41
https://www.youtube.com/watch?v=rA1DhfTwuwM
Feb 4, 2013 - Uploaded by ExperienceLG
Ice makers are great, but not if it means you can't fit all of your food in the fridge. The Slim SpacePlus Ice ...
LG fridge ice maker troubleshoot/ repair. How to fix ice ...
? 8:06
https://www.youtube.com/watch?v=arJpFgMnvPY
May 19, 2013 - Uploaded by spartacus1234567890
The ice maker quit working in my LG refrigerator so I decided to take it apart ... LG French Door Refrigerator - In Door Ice Maker Troubleshoot ...
LG Refrigerator Ice Maker Not Working - Model LFX25960ST
www.repairclinic.com/RepairHelp/...Fix...-/LG-Refrigerator-ice-maker-n...
LG Refrigerator Ice Maker Not Working. LFX25960ST. The part(s) or condition(s) listed below for the symptom Refrigerator ice maker not working are ordered ...
Jan 05, 2016 | LG LMX28988ST Refrigeration : Refrigerator...
Ice maker is not working. Light goes on but no water fills the maker Model LFD25860TT
Pull the line off at the icemaker and check for a filter at the inlet...often **** builds up there and stops off the water...
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jul 12, 2010 | LG LFX25960ST Stainless Steel French Door...
Ice maker stopped working
Here is a tip that I wrote about the reasons why ice makers do not work.
heatman101
jkkjffkj
Jun 27, 2010 | LG LFX25960ST Stainless Steel French Door...
Ice maker stopped working and how to clean the stainless steel?
For this problem you need tech support. There are many things that can cause this and it needs to be diagnosed by an authorized LG tech. In the long run you will save money and get a quality repair.
Jan 24, 2010 | LG LFX25960ST Stainless Steel French Door...
Ice maker stopped working. The cubes gradually got smaller until it just stopped producing cubes
heatman101
iot47
Oct 05, 2009 | LG LFX25960ST Stainless Steel French Door...
LFX25960ST Ice Maker Shutoff Arm
Unplug the ice maker from the fridge. You will see the plug by following the wired coming from the ice maker. Leave it sit for 20 mins. Plug it back in and hold the green ice cube size button in and watch for the ejector fingers begin to move. If they move they will go around to about 11 o'clock or so and the water should come on filling the tray. If any of these things don't happen, you have a bad ice maker.
Jun 12, 2009 | LG LFX25960ST Stainless Steel French Door...
Ice maker LFX25960ST
3 months old?? warranteed for a year call for service , you bought new so you wouldnt have to fix it!
Oct 31, 2008 | LG LFX25960ST Stainless Steel French Door...
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
287 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
