Question about DeLonghi DEFSGG24SS Gas Kitchen Range
Front fan failure
Front display says there is a front fan failure.fan stops running after you have been cooking for 1 plus hours possible over heating.
Call the Delonghi parts and service hotline during normal business hours toll free 866 844 6566 for help on solving your problem
Posted on Feb 28, 2009
What would cause my Sanyo Microwave to not heat up? The glass plate turns, I hear the fan runs but not heat when done with cooking time.
Multiple possible causes - most likely are high voltage rectifier failure or magnetron failure. Less likely would be high voltage capacitor failure, transformer failure, or transformer not receiving 120 volts from the controlling mechanism. Also possible on some ovens - open thermal protector, loose connection / broken wire.
Apr 29, 2014 | Sanyo Microwave Ovens
Cannon ir 3025 photocopier displays error code 805-000.
E805
There is a fan error.
0000
Failure in heat exhaust fan (front) (FM2)
When lock signal is detected for 5 sec while the fan is stopped.
- Replace the heat exhaust fan (front) - Replace DC controller PCB
0001
Failure in rotation of heat exhaust fan (front) (FM2)
When lock signal failed to be detected for 5 sec while the fan is driven.
0002
Failure in heat exhaust fan (rear) (FM1)
- Replace the heat exhaust fan (rear) - Replace DC controller PCB
0003
Failure in rotation of heat exhaust fan (rear) (FM1)
there are 2 fame in the right door if you just look on the right door you will see 2 square vents
get in there and remove the fans and clean them out with canned air and apply a small amount of oil in the center then flick the fan to make sure it spins softly
reinstall and try it should fix the problem but please go ahead and order a new fan the part number is on the fan itself in the sticker it will say FK2-????-????
Oct 30, 2013 | Office Equipment & Supplies
Washer Front Panel states: 70 Series Heavy Duty Plus Dryer Label inside door says: Model / Stock No 87980100 79801 Ser No M94039293. Dryer Issue: Drum Turns, Clothes get hot, Lint screen clean, 1.5 ft Exh...
Possible blower fan failure, Or Blower fan blades are choked with lint, so no blow.
Your gonna need to open it up. If fan blades are choked, simply clean and vacuum them. Reassemble and test run.
If fan blades are clear, (minor lint-ing will not stop it working) then it indicates fan motor is bad.
Possibly a capacitor (motor starter) rather than motor. Usually a small cylindrical object with wires attached, located in close proximity with related motor. Check for swelling, leaking. if looks OK it's likely fine.
Capacitor is cheap to replace first. Must use SAME VALUES as original.
Nov 17, 2010 | Kenmore Dryers
How do i set the time on w westinghouse pgn659s wall oven?
Instructions below.
  1. 1 Fill the insert of the Corningware slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  2. 2 Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
  3. 3 Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
thank for visit.
Oct 09, 2010 | Ovens
Turn on oven cleaning, but clean indicator stops after few seconds
hello
what this need is to set the reprograms
here are solution below
You can set the timer on a Corning ware slow cooker to automatically switch to a warming setting when you estimate Foods will finish Cooking The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a Corningware slow cooker to let the kitchen appliance do all the Work, and come home to a fully cooked meal.
  • Fill the insert of the Corning ware slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  • 2 Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
  • 3 Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
  • hope this hope ?
    thanks
    Oct 03, 2010 | Ovens
    AFter start of cycle F11 displays and washer stops
    The Motor Control Unit has internal failure; repeating under or over voltage, or over current conditions. If failure occurs during high-speed spin the door unlocks after 3 minutes. Possible Causes/Procedure 1. Unplug washer or disconnect power. 2. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and b etween the MCU and the Central Control Unit (CCU). Check the motor and do a continuity test. 3. Plug in washer or reconnect power. 4. Check the MCU by looking for operations of the drive motor. 5. Check the drive motor for powered rotations. 6. Replace MCU board.
    Jun 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Lost my manual for chef condor integra oven - need to check auto functions and how to set them
    For TOuch Control oven:
    1. Press Finish Time touch pad
    2.press ^ touch pad until clock displays the required am or pm finish time.
    3. Press Cook Period touch pad.
    4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
    5. Press Automatic touch pad.
    Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
    7. Turn oven thermostat to desired setting.
    8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
    10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
    For Multifunction oven:
    1. Set time of day.
    2. Turn Function switch to Finish. 0.00 will be displayed.
    3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
    4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
    5. Turn Function switch to Auto. The automatic programme is now ready to use.
    Turn upper oven thermostat to desired setting.
    If keep warm function is required, turn function switch to Cook (optional)
    Happy cooking!
    Jun 14, 2009 | Ovens
    Need directions for presidents choice slow cooker
    Heat intensity is warm, 1, 2, 3 (highest)
    How to operate: Plug in. Set timer to amount of hours to cook. Press the SELECT button to scroll thru 4 settings - "warm", "1" (Low), "2" (Medium)", "3" (High). Once the desired cooking temp selected, press the "round circle" power button to begin cooking. The time display will now start to count down to "0:00" When the cooking time has been reached, the slow cooker will automatically go into "warm" mode for a maximum of 6 hours, then automatically turn off. NOTE: Not recommended using the WARM setting for more than 4 hours at a time. NOTE2: To stop the cooking process at any time, press the "round circle" power button. The unit will default to "0:00" time but the indicator light in the "3" high position will remain on.
    Apr 11, 2009 | Crock Pots & Slow Cookers
    Microwave heated food an hour ago but has stopped heating it now. Sensor cooking ceases and displays "F3H". Fan has stopped working also.
    A make and model would have been nice, but try unplugging it from the wall outlet for 15 minutes.
    Hope that helps...
    Geno
    Mar 26, 2008 | Microwave Ovens
    Problems after Power Management changes
    Experience a similar problem with a FIC MB. I cleared CMOS then removed MB battery for 1 hour. Restarted the unit with just the video card and hard drive installed. After unit rebooted I added sound card, network card, etc.
    Jan 06, 2008 | FIC P4M-915PD1 Motherboard
    DeLonghi DEFSGG24SS Gas Kitchen Range Logo
    142 people viewed this question
    Top DeLonghi Kitchen Ranges Experts
    JP Services
    JP Services
    Vitaliy Gins
    Vitaliy Gins
    Paul Bade
    Are you a DeLonghi Kitchen Range Expert? Answer questions, earn points and help others
