Question about Emerson EWF2004 20" TV
My cat jumped on my remote & now my tv only shows a few channels
How can I reprogram or what do I need to do to get my tv working properly? My cat jumped on the remote and now the tv only shows a few channels in spanish.
  • 82 Answers
Go into the menu and look for a "program mode" or "auto program" something to that effect.
If your cat did what I think it did, its pretty funny coincidence.
Posted on Dec 02, 2008
My philips flat screen shows no signal and #3 in right hand upper corner just happened when cat knocked over remote no sound
To which model television are you referring? It sounds like you either need to change the input method for the TV or just change to a different channel (2 or 4).
Dec 10, 2012 | Philips Televison & Video
Hi, I just got a new samsung tv and my remote that came with doesn't appear to work properly. The power button, source button and volume and channel will work but the rest do not. The tv I got was a...
Refer to your dealer about this situation, hence there is no problem with your remote control. If some buttons are working others not, then the remote could be different. On the manual, there is a model number for the remote, if it does not match with the model number on remote, then change it.
Mar 04, 2011 | Samsung AK59-00104R Remote Control
Remote will not work tv.
A working TV remote is a security blanket that allows us the peace of mind of knowing that we don't have to get up unless nature calls or the house catches on fire. People are more likely to spend more time and energy to fix their TV remote than to get up and change the channel. There are a number of simple fixes that can ease your mind when your TV remote is not working.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Easy Instructions Things You'll Need:
  • New Batteries
  1. Check the batteries. Make sure the batteries are in correctly and, if they are, replace the batteries. If the batteries are dead or are not in correctly, your remote will not respond and the LED light will not illuminate when a button is pressed. Make sure the TV is plugged in. An unplugged TV will not respond to any remote.
  2. Check the selected input to make sure the remote is set on the TV and not some other device programmed into the remote, such as your DVD player, VCR, or video game console.
  3. Reprogram the sync code. If you are using a universal remote, it may have deprogrammed, leaving the remote and TV out of sync.
  4. Unplug the TV for a few minutes. During a power surge, a TV can become "confused." Unplugging it for a few minutes will give the TV the break it needs to sort everything out and work properly with your remote.
  5. Use another remote on the TV. Program a universal remote to work with the TV. If the TV does not respond, the problem is likely with the TV and not the remote control.
Jan 09, 2011 | Toshiba 62HM95 62" DLP HDTV
I can't get my dish system to work with this TV. I'm only getting 2 chanels. How do I program new chanels to this TV? I need chanel 60.
It depends on the TV a bit. Which model of Broksonic TV do you have? Do you have the original remote? (remotes.com has replacement remotes for many TVs.) Look at the TV (or the original remote) for a menu or channel add subtract option. (The TV is probably programmed to skip the channels that didn't have a signal in the past so you need to reprogram this.) If the TV is a really simple TV (with just the channel and volume controls on the TV), you'll need the original or a direct substitute remote (or a higher end programmable remote). Most basic universal remotes will control power, channel and volume but not the reprogram channels option (in my experience). If you can program the add/remove channels, press 60 on the remote, wait for the TV to go to that channel and then press the Add Channel button. Alternately, with the satellite receiver on, press the combination to search all channels and program the skip to channels with signal.
I hope this helps.
(I had a really old Emerson TV; when the original remote started to fail, the cheap universal remote didn't handle the channel programming. Fortunately, the original remote would usually still work for that.)
Jul 07, 2010 | Broksonic TV
My Harmony 890 remote has a difficult time inputing numbers
Hi. This problem is caused because the 'repeat' setting on the device that you use to change channels (TV or cable box) is too high.
1. In the software, click 'Troubleshoot' next to the icon for the device that you change channels on.
2. Select '<device> responds to some commands either too many times or only occasionally' and click NEXT.
3. Decrease the setting by one (the default is usually 3).
4. Update your remote and test it.
Apr 25, 2010 | Logitech Harmony 890 LCD Remote Control
Broadcast fail to show (E202)
U just take ur tv original remote just turn to channel 3?Why is ur cable service connected to channel 3?The proper way to connect to cable service is get the pay cable connected.Take ur original tv remote.Push Menu on ur remote,go to SET UP go down the CH Setup,pick cable,than scan for all the pay cables channels you pay for.
Mar 31, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Remote no longer works-need code to reprogram it
the only codes i have are 0121 0135 or 0035
Mar 23, 2009 | Orion1934 19" TV
Toshiba Remote #CT-847
where can I get the manual for a Toshiba ct-847 remote
Dec 06, 2008 | Toshiba Televison & Video
No freaking signal
Double check ALL your ant wire connections. Then reprogram the converter to check for stations again. If that doesn't work then reposition your antenna and reprogram again.
May 21, 2008 | Insignia Digital-to-Analog Converter for...
Toshiba 36a41 television
You should be able to use your remote control to do this.Your channel 73 is more than likely UHF 73 so you need to put your tv in the antenna setting rather than cable setting. Once you do this just input 73 with your remote. Hope this helps! Stargazer
Jan 21, 2007 | Sony KV-36XBR250 TV
Emerson EWF2004 20" TV Logo
74 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
