Question about Dell HK395 Computer Speakers
Broken orange plug on right speaker going into subwoofer
One of the pins of the orange plug that connects to the subwoofer is broken. it looks like a modified s-video plug. how can i fix or replace this plug. no electronics store I have gone to is able to help and i have also contacted the manufacturer - they say I would have to buy a brnad new system which I don't want to.
  • Anonymous May 04, 2009
    i have the same problem. dell says have to buy new desktop speakers which are $50. they are the only ones that connect to this woofer.
    Problem Solver:
  • 6 Answers
Other posters to this forum have said this connector is available at Radio Shack.  If you can't find a connector here is a workaround that will do the job:
If there is a broken pin you can bypass it by cutting open the cable jacket and delicately soldering a 6 inch or so jumper onto the affected wire, and then  solder a jumper to the appropriate point inside the subwoofer. Pass the subwoofer jumper out of the case (drill a small hole) and connect it to the jumper you added to the cable.
Posted on Aug 22, 2009
How do i connect a set of Harmon Karden HK695-01 speakers to a Macbook Pro Mid 2010
HI Marc
Follow the steps below
Step 1:
Connect the green connector from the subwoofer into the headphone jack on the laptop, the black connector is not used, leave the rubber cap on the black connector to prevent static from the pin grounding on the system.
Step 2:
Plug the orange connector from the right/control satellite into the orange jack on the subwoofer.
Step 3:
Plug the brown connector from the left satellite into the brown jack on the subwoofer.
Step 4:
Plug the AC plug of the HK 965 into the wall outlet
Step 5:
Turn on the speaker set and adjust the volume accordingly.
PS: Do not Forget to adjust the Laptop volume also to minimize Distortion. Enjoy!
Jun 04, 2015 | Harmon Kardon Hk695 - 01 Audio System...
Hi .. i have just bought a logitech x 530 speaker and only 2 of the speaker parts work .. can you please give me some solution advice?
Hi names Rui i like to help you by giving you step by step instruction in propely hocking up your logitech speakers:
Instructions
1. Connect the black plug of the rear right speaker into the black plug on the subwoofer.
2. Connect the yellow plug on the rear left speaker into the yellow input on the subwoofer.
3. Connect the red plug of the front center speaker into the red input on the subwoofer.
4. Connect the white plug of the front left speaker into the white input on the subwoofer.
5. Connect the d-sub connector plug from the front right speaker into the d-plug connector on the subwoofer.
6. Connect the green, black and orange input to the matching plugs on your computer. If you have a four-channel sound card, connect the green plug from the input audio cable to the front plug of the card and the black plug to the rear plug. Do not connect the orange input. If you are using a two-channel sound card, connect the green plug from the input audio cable to the "Line Out" jack on the sound card. Do not connect the green and orange plug.
7. Plug the subwoofer power chord into the electrical power outlet.
8. Place your subwoofer on ground around your computer desk. Position the front center speaker on top of your computer monitor.
9. Place the left and right front speakers on the sides of the monitor. Position the left and right rear speakers behind you, making sure they are pointing toward the front left and right speakers.
10. needs to support 5.1 surround. Normally, more than three sockets for sound indicates that it does. Then you need to use the software that comes with the sound hardware to configure it for 5.1 - Default will be 2.1 or just 2.
Check the control panel out. This is a lot easier under Windows 7.- Here you can access what you need via the speaker icon on the system tray (right click)
There is NO problem with your OS or hardware, this is pretty standard...
hope this will help you solve your problem.
Jul 18, 2011 | Logitech X-530 Computer Speakers
I plugged in my Altec AP3 Speakers to my computer running windows 7. It does not play. i get sound directly from my PC (it had sound prior to plugging in speakers) however the Altec speakers have no sound
Hello
You haven't specified from which computer source you connects this device with. If it is from the audio out socket of the PC, your PC's audio card [or onboard audio] dirive hasn't been installed yet. Unlike WinXP, Win-7 haven't all driver software in its driver cab when it is installed. If onboard sound should energize, the mother board CD should be loaded. There is audio and video drive [normally NVIDIA] drive should be installed. Anyway, you have to install the dirve. Now it disabled. Go to the hardware confujuration of your system, and look whether onboard audio is disabled. If it is disabled, inable it. If there is no driver installed to it, the system will ask CD. Then insert the CD into the CD tray, and follow the instructions. If your Win-7 is registered, you can get diretly into Microsoft site, and can download the driver needed. OK.
Jun 03, 2011 | Altec Lansing ATP 3W Computer Speakers
How do i connect the boston BA745 comp. speakers to my gateway desktop?
Assuming you have the BA745 2.1 speaker set up, all of the cables connect to the subwoofer and then to the computer or the satellite speakers (these are built into the speakers IIRC). Take the cable with the black box (2 pins) to red and green. The red and green plugs go into the matching color ports on the computer and the pins on the black end fit into the jacks between the those for the two satellites. Plug the single end speaker cable into the subwoofer port all the way to the right on the back of the subwoofer. Plug the wire with the two plugs into the matching color jacks (blue to the left, red to the right). Then plug in the power adapter cable in the farthest left jack and plug in the other end to a surge protected power strip (that is plugged in and turned on).
Oct 24, 2010 | Boston Acoustics BA745 Computer Speakers
How do i connect the speakers to my computer?
Step 1 Connect the green connector
from the subwoofer into the green jack on the computer
(the black connector is not used)
Step 2 Plug the orange connector from the right/control satellite into the orange jack on the subwoofer.
Step 3 Plug the brown connector from the left satellite into the brown jack on the subwoofer.
Step 4 Plug the AC plug into the wall outlet.
Step 5 Turn on the speaker set and adjust the volume accordingly.
Jan 22, 2010 | Harman Kardon HK695 Computer Speakers
Speaker cable installation
1.  Check the orange multipin connector for bent or broken pins.
2.  Make you have the subwoofer plugged in to a live power outlet.
3.  Check the fuse on the circuit board inside the subwoofer.
4.  Measure the output of the subwoofer power transformer.  I think I remember it as being in the range of 12-24VAC.  Inspect the rectifier diodes for signs of overload.  measure the dc output of the diodes.  I think I remember 18VDC.
5.  Open the right speaker and verify the on/off switch is working.
6.  New Egg sells a multitude of similar speakers in the $40 to $80 range.
Apr 04, 2009 | Dell HK395 Computer Speakers
Creative Inspire 5300 Volume Control broken!
For those searching the answer "How to replace/repair Creative Inspire 5300 volume control":
Its simple : looking at the back of the suboofer, the pins are as follows from top right, clockwise : LED VDD , Balance pot middle leg, GND, pots + legs, Volume pot middle leg, on switch input. Connect one pots ends to GND and the other ends to pots +, connect a switch on GND and on switch input, anode of led to LED VDD, cathode to GND (there is a 1,8k resistor inside so no external resistor needed)
Dec 19, 2008 | Bose Companion III Computer Speakers
Need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Mar 27, 2008 | Altec Lansing ADA425 3-piece 30-watt...
Dell HK395 Computer Speakers Logo
986 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
