Question about Dell Dimension 2400 PC Desktop
Computer monitor won't tur on
When i turned on my computer, power LED, fans, cpu fan and gpu fan, all works except that no display seen on my monitor. light indiacator on the monitor won't turn to green, alway orange, what seems to be the problem here/
  • Anonymous Dec 15, 2008
    its not the connector for me, the monitor works with other computers, and I tried using a PCI video card to no avail, it leads me to think its a motherboard, ram, or processor issue
    Scholar:
  • 160 Answers
Check the connector to the pc from the monitor. it may have come loose. if you have a mouse, try moving it and see if the light on the monitor turns to green. it is possible the video has failed.
Posted on Dec 02, 2008
    Problem Solver:
  • 18 Answers
An orange light would indicate there is not signal from the computer. Make sure the computer is on and you see lights on the front of it. Check the cable that runs from the monitor to the computer to see if it has worked loose.
Regards
John
Hp pavilion modelp6510f press power switch on top of pc does not light computer fans blow but compute does not turn on
ok th p6000. complete range when they were made had to be recalled as they put the copper expansion pipes ran across the gpu & cpu hence a massive overheat problem. they put copper shims over the cpu & gpu but this worked for a short time but it was inevitable and both units ended up being cooked i had this problem with mine. so if you have tried external monitor with no images it would sound or more likely to be the gpu cooked sorry for the bad news.
Jan 28, 2014 | Computers & Internet
Hello, I have a problem with my PC. I'll be
connor,no input you write it can be a easy thing as the monitor-cabel is not tight enough fasten.check that first .if the problem don't go away you have open the computer and remove the videocard clean the cards slot with caned air short poffs never shacke the can.now reseat the card and hope at that did the trick.let me now if ok
Jul 20, 2013 | Computers & Internet
I have a hp a350 cpu.the problem is that the light of led has gone red,as before in working condition it was green. It can't start.the power to hardisk is also not coming.please tell a sollution.
As you say has become red and no power to the hard disk.
First check the power cable for any loose connections and check if it give power to the cpu and the fan placed on processor starts working as you start the power. If fan it starts and with in few seconds stops then your power supply/SMPS is weak or damage. So replace it for proper working of your computer. And if after power on all fines but red led on monitor and no power to hard disk Try to replace the hard disk power cables because they are not working because of it no operating system is detected and led of monitor is red. After replacing hard disk cables hard disk starts working and still no display or red led on monitor check the vga cable for loose connection or replace it.If you are using vga display from graphic card try to get display first from onboard vga slot.After it your problem will disappear and your pc run smooth and fine.
Aug 27, 2010 | HP Compaq d530 SFF PC Desktop
Everything was working fine, then one day I switch...
Try to check your CPU unit it maybe have a power when you turn it on. Or just check their power suppy at the back when it works. If you check that all and it works normal just check inside your computer and try to see the Power LED (Light Emiting Diode) of the motherboard if have a light. Because if it is have a light your motherboard is good and if it is no light in the Power LED of the motherboard that was damage. But if your motherboard does not have installed Power LED try to check the CPU Fan it maybe works properly it because the CPU Fan was conncected in the motherboard if did not works the motherboard is also damage and need to replace. But if the CPU Fan was working properly, try to hold the CPU Heatsink if it is very hot the damage is your micro processor.
May 20, 2010 | Intel D945GCNL Motherboard
Computer won't start up
sounds like the cpu is dead, if your fan was full of dust theres a high chance it wasnt working properly for a while which would of caused the cpu to fry from lack of proper cooling and also the dust in the vents would have prevented heat from escapeing so its highly probable that the cpu is dead try replaceing it, i cannot gaurentee that anything else internally got fried from the heat tho, i had a similar problem a week ago
May 03, 2009 | Computers & Internet
Computer does not turn on
Check the switch of the power supply at the back (black button) First
If the power supply fan doesn't work or cpu fan doesn't work
Replace the power supply.
Thank you for using FIXYA
Please don't forget to rate my help
Have a great day!
Pablo :-)
Oct 16, 2008 | Computers & Internet
AUS A7N8X -X Mother board AMDAthlon 27648 CPU No picture
if this is a built sustem out of the box with old monitor try another monitor oddly enough some arent compatible, you can check by looking at the prong patern.
May 10, 2008 | ASUS P5K Deluxe/WiFi-AP, iP35, S 775,...
K8NGM2 Mother Wont Power Up
I've seen situations similar to yours several times and they've always been a bad CPU.  Since you tried a new video card it's not that, I would suggest a new CPU.  Check on ebay, you can usually find used one's on there.
Oct 10, 2007 | ASUS A8N-SLI Motherboard
Dell Dimension 2400 PC Desktop Logo
257 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
