Question about Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range
Cleaning front doors
Our new range is grimy looking--how do I clean it? I've tried alcohol to get the tape off completely, but it's spotty looking.
Thanks,
Joyce Ferreira
    President:
  • Jenn-Air Master
  • 2,651 Answers
Stainless steel cleaner should shine out the metal for you, (always clean with the grain of the metal as not to scratch)and the glass is reg glass, so windex should clean that up
Posted on Dec 02, 2008
Oven door is not closing completely
Sounds as though the electronic latch isn't working. I would have a service tech check it out.
May 20, 2012 | GE Kitchen Ranges
What is F7 10 code on kenmore elite 790.4661 electric range
You may have a bad Electronic range control ERC, but if your not handy you may want a service person to look at it. If you are handy and can get to the control panel, check and clean the connections, after you disconnect the power. Use tuner cleaner or alcohol. There are diagrams of you range online. Are you having one error or two. Looks like you mention f7 and 10, or am I mistaken.
Dec 21, 2017 | Kenmore Kitchen Ranges
I have a VCR dvd combo... the volume on the VCR is starting to sound muffled and real hard to understand, but the dvd player volume is good. How do I fix the volume on my VCR?
If the picture is good and the sound is muffled, try running a VCR head cleaning tape through the machine, This will clean any build up from the magnetic tape used in VCR tapes and should be ran on a regular basis. If this don't fix the problem, try using a long Q-tip with denatured alcohol on it to clean the tape heads, these are easy to see once you lift the tape door, clean everything the tape comes in contact with, you can use isopropol alcohol if that is all you have but be sure to let the unit dry before plugging it back in to avoid a fire. I hope this helps, Good Luck.
Mar 15, 2011 | Televison & Video
I am getting an F7 error on my LG LRG30355ST Range. The panel is responsive to the Cancel/Off and Start buttons, but none of the other buttons appear to work. The burners still work, but I am unable to...
It means the keypad detects an electrical short. It's the equivalent of holding your finger to a number button for more than 40 seconds. It will cause an error. You have to remove/clean/repair whatever is causing the short. Try cleaning the front keypad with isopropyl alcohol. If it doesn't work, remove the front panel with a 1/4" socket wrench and T15 torx screw driver. Remove the LED/clock board with philips driver. Then clean the entire back of the keypad panel with ispropyl alcohol. Allow the alcohol to dry completely or use a hair dryer to dry the alcohol completely before plugging in stove again. I did this with my stove and it fixed the problem.
Dec 12, 2010 | Microwave Ovens
Only one channel is playing, i heard some music in stereo. Do heads need adjusting?
clean the head with alcohol.if the head surface is not smooth,it could be worn
.there is a small screw on the side of the head for changing the azimuth.
most front load tape decks have a small hole in the front of the door, when the outer part of the door is taken off.
the best way to align the heads with with a 10khz alignment tape and an oscilloscope.
the screw is adjusted for maximum high frequency performance.
a qualified shop should be able to do a complete service and align for around 50 dollars
Aug 18, 2009 | Audio Players & Recorders
Taped sounds are deteriorating and disappearing.
If the tapes you are using are indeed brand new, then I would assume that the heads on the tape recorder are either very dirty or damaged. Try using a q-tip dipped in alcohol to clean the heads of the recorder. Clean the rollers too and pins that guide the tape. If that doesn't work it may be a component problem. And may be cheaper to replace than repair.
Feb 10, 2009 | Dictaphone 1243 Handheld Cassette Voice...
Bad color
Chances are it is the connector on the "lvds" cable where it attaches to the lcd controller board. Detach the connector and clean any glue or tape residue off of it with isopropyl alcohol or electronics cleaner and then reattach it.
Dec 02, 2008 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Self cleaning oven door locked before I got the door closed.
Try holding in on the door switch while resetting the clean cycle.
This should rotate the latch. Once the cycle starts, cancel it. The latch should go to the unlock position.
You will have to hold in on the door switch during all these steps.
If this does not work, post back with the complete model number from the oven and I will see what else I can come up with.
Nov 25, 2007 | GE JGB916SEKSS stainless steel Gas Kitchen...
Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
95 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
