Question about Jensen KA3 Car Audio Amplifier
Amp not working
Well i went to hook up my jensen ka-3 2 channel amp and i connected up the ground then right as i touched the 12v to the amp it sparked like there was a short but i hooked up a different amp and it worked fine id like to know whats wrong. Thanks
What's the problem? It's not unusual to get a spark when you connect power to an amplifier; there are capacitors in the amp that will charge. Is the amplifier not working?
Posted on Feb 26, 2007
What do you hook the mute wire to a ground or 12v positive?
Normally this wire is already pulled up to +12V with an internal resistor, so you can leave it disconnected but isolated with tape.
Oct 08, 2013 | Jensen VM9226BT 6.2" Touch Screen DVD,...
Jensen ka4400 400w amp
Hello Brian,
I have done a search for the Jensen KA-4400 Amplifier manual, without any luck. Sorry.
However the following might be useful for you to continue the search:
(1) Jensen Customer Support: 800-732-6866
(2) Go to: http://caraudio.manualsonline.com/manuals/mfg/jensen/jensen_car_amplifier_product_list.html
(Be careful to copy ALL of the URL address).
Then click on "Ask the membership for help locating your Jensen Car Amplifier manual"at the bottom of the screen.
Then fill in the form.
Good luck.
Dec 13, 2011 | AMP Car Audio & Video
Kicker zx1000.1 stopped working completely. I have 3 Kicker 10" cv subs hooked to it. The first time it shut off I turned the system off. When I turned it back on it worked for a few minutes and...
First check to see if your'e getting power to the amp by using a test light and touch the main power(12V battery) connector on the amp, test light should come on since it's constant 12v supply. Now turn on the radio and test the remote wire connector on the amp and you should have 12V(test light should come on). Also make sure that you have a good connection with your ground wire, check both connection points to make sure it's good. Now if you have power where your'e suppose to and when your'e suppose to and the amp does not power up, then it may be time for a new amp. Try wiggling the connections at the amp a bit, the solder may be cold/loose.
Jul 12, 2011 | Kicker Car Audio & Video
I have an older model Jensen 500 watt 2 channel bridgeable amp. When i hook it up the red light(protect light) comes on and it will not work
REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS AND POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL GOES INTO PROTECTION AND YOU HAVE VERIFIED THAT THE POSITIVE AND ESPECIALLY THE GROUND CONNECTIONS, ALONG WITH THE REMOTE CONNECTIONS ARE 100%, THEN THE AMPLIFIER WILL NEED TO BE SERVICED. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Dec 01, 2009 | Jensen A300HLX Car Audio Amplifier
Does the rmt hook up to ground or power
Hi the RMT is short for remote and is connected to a 12v feed taken from the remote output from the cd player, it provides the 12v needed to turn the amplifier on when required & turns it off when the player is turned off. Do not connect this to a permanent 12v feed as the amp. will be on all the time & you will have a flat battery every morning! Cheers, acbva.
Nov 16, 2009 | Jensen LXA400 Car Audio Amplifier
Crazy Car Amplifier
to be honest with you, your best bet is to buy a new amp.  cheap amps are cheap because they plan on you buying another one when they don't last.  save up and buy a nice amp, thats my advice.  if you really want to fix this one i wish you luck, but i've never worked on an amp before, just install and troubleshooting, so in my experience this one's fried.  But i'm sure it could be fixed, the question is wether or not it is worth it?
Oct 30, 2008 | Legacy Audio LA720 Car Audio Amplifier
No power to the amp i touched the power wire to the side of the amp
It probably burned a trace on the circuit board.
With the amp hooked up normally and the head unit on (so the amp will have remote voltage), do you read 12v DC anywhere on the case of the amp (black meter probe on the ground terminal of the amp)?
If there is no voltage on the case, confirm that you have 12v on the B+ and remote terminals of the amp (black probe on ground terminal of the amp).
Aug 25, 2008 | Kenwood KAC-9102D Car Audio Amplifier
Protection light comming on.
I'd be inclined to check to make sure there isn't a short circuit somewhere in the output lines. Maybe a wire is crushed against the car's body or bare wires touching or badly fitted RCA plugs. All of these things could activate the protection circuit. If you have a multimeter it would make life easier but don't forget your speakers will show up as 4 ohms so that's not a short. BMW
May 31, 2006 | Jensen 100W x 4 Amplifier KA5 Car Audio...
Jensen KA3 Car Audio Amplifier Logo
161 people viewed this question
Top Jensen Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
