Question about Protron PLTV-32 Television
Protron 32" lcd pltv 3250 tv power supply dead no 5v 16v or 24v
Set is may, 2006 model. Has 7 bad caps near output side? Read some where on web that the voltage may have risen above the highest rating of 35v. Something caused these capacitors to swell up. What do you think.
thanks, John Corradini
angelus2k8
SOURCE: Protron PLTV-3250
Probably same problem I have with my PLTV-3250. dead power board.. I still can't find anything affordable to get it fixed.. good luck..65d2d93.jpg
Posted on Mar 08, 2008
dsacco86
  • 1077 Answers
SOURCE: Protron PLTV 3250 Parts
Ask and you shall receive. Shopjimmy.com seems to have them in stock. And people sell TV parts on Ebay all time. I hope that helps you.
Posted on Feb 01, 2009
SOURCE: tv stopped coming on like it was a fuse problem
how do u replce a power supply boared
Posted on Aug 05, 2009
  • 6 Answers
SOURCE: No power to my Protron PLTV 3250. What can I do
My Protron PLTV - 3250 just went out yesterday. By this I mean it turned on and went out in a few minutes. I left it off and today it completely died. I opened it up because I always think I can repair things. So what I found is a burn mark on the curcuit board of the power supply which is located inside the tv. On the other side of the burn mark is a (zener diode), this diode is burned out and therefore the power supply is not working. I am going to Radio Shack tomorrow Monday Aug. 31, 2009. The diode is very tiny but should be easy to replace with a sauder gun because this diode has place holders to hold the tiny diode in. If this does not work at the top of this page is a link that says power supplies for your tv for sale. I am going to check it out. Anyway just so you all who know about computers= the tv power supply is similar to the power supply on a computer. Just like a computer power supply comes in a case that you install into your computer and then you just connect the connectors to your motherboard and drives. Well in the tv the power supply is stand alone also, you can disconnect the wire connections in the tv and replace the power supply. If you notice the power cable to your tv is the same as a computer power cable, so the power supply in the tv is much the same as a computer power supply. I hope this helps you.
Posted on Aug 31, 2009
SOURCE: my protron pltv-3250 stop working
I need to order apower supply board for PLTV 3250
Posted on Sep 06, 2009
Were can i purchase protron ac/dc power supply for protron pltv-32 pltv32 lcd tv
Check this link below:
http://www.lcdpayless.com/productpage.php?productId=5441
Specification of Protron pltv-32 lcd ac adapter:
Output Voltage: 24V and 12V Volts DC
Amperage: 6 A and 3 A Amps
May 15, 2011 | Protron Ac / Dc Power Supply For Protron...
Need a ac adaptor for a Protron PLTV-32. MODEL LU32A1A3. INPUT 100-240V 50-60Hz 3.0A MAX.Output +24V-6A +12V-3A
I found one through Powerpayless.com at http://www.powerpayless.com/ac-dc-power-adapter-for-protron-pltv-32-pltv32-lcd-tv.html. It works great!
Mar 01, 2011 | Protron Ac / Dc Power Supply For Protron...
My TV will not pwer on, I have replaced the ac power cord and made sure the switch was in the on position that is next to where the power cable gets plugged into the tv. The blue led lite in the front is...
This is common problem with the PLTV-3250, the power supply DC filter caps go bad, 5vdc standby transistor and diode shorted out.
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out Q7 and ZD4.
http://s807.photobucket.com/albums/yy352/budm/Protron%20PLTV%203250/
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Power supply: http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=pltv+3250+power+supply&um=1&ie=UTF-8&ei=9lIDTL7XO4fcM7HA-Ds&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CCgQrQQwAA
Jul 12, 2010 | Protron PLTV-32 Television
Protron 32" lcd tv
Jun 30, 2010 | Protron PLTV3250 32 in. LCD Television
I have a Protron 32 in LCD TV. There is no power....
First make sure it does have at least red indicator on the front panel, if not, the standby +5vdc is not working, coomon problem with this monitor is dead power supply due to bad caps, shorted transistor and Zener Diode in the standby power supply.
Power supply; http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=pltv+3250+power+supply&um=1&ie=UTF-8&ei=hdgBTL6MJaKMNZLC1Ts&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CCQQrQQwAA
May 20, 2010 | Protron PLTV3250 32 in. LCD Television
No power to my protron PLTV-3250.
May 16, 2010 | Protron PLTV3250 32 in. LCD Television
PLTV 3250 no power
First make sure it does have at least red indicator on the front panel, if not, the standby +5vdc is not working, common problem with this monitor is dead power supply due to bad caps, shorted transistor and Zener Diode in the standby power supply.
Apr 26, 2010 | Spectroniq PLTV3250 32 in. LCD TV
Pltv-3250 32'' lcd t.v. won't turn on.
Feb 03, 2010 | Protron PLTV3250 32 in. LCD Television
Protron PLTV-3250 fried
remove pwr board--inspect and you will find a heavy current diode which has eatin its solder pad area--if diode checks ok,repair it's connection.Install board and hook back up.Check for shorts in circuit.Cross fingers and plug her up------good luck
Jan 26, 2008 | Protron PLTV3250 32 in. LCD Television
Protron PLTV-32 Television Logo
1,089 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
