Question about NZXT NEMESIS ATX Mid-Tower Case
I installed mostly everything but it turns on for 2 second and shuts down i think i shortaged something out
  • WolfenHawke
    WolfenHawke May 11, 2010
    You may have a bad MOBO, or more likely, you have a incompatibility somewhere. Disconnect everything that is not absolutely necessary and see if it starts. Then add items one by one. If your MOBO (motherboard) has built-in video, use that instead of an external video card. Same for sound cards. Also, do not plug in any networking cards for initial bringup. Ideally, just the MOBO, CPU, memory, keyboard, mouse, display, CD ROM and only your boot harddisk. Try this, and comment on what happens.
  • 227 Answers
First Thing I would try is another power supply, this is the easiest and most major cause of pc power problems. Also you can usually take your pc to big name computer stores they will diagnose this issue for free so they can get you to spend tons of money having them put in one. but I would definitely do this first., It is not unusal for a power supply to be DOA
Posted on Mar 25, 2009
Where is my reset button on my asus laptop
I don't think I've ever heard of a reset button on a laptop, but you do have some other options to turn the computer off if it's locking up or something. You could take out the battery and put it back in, that would pretty simply shut it down. Alternatively, most computers can be manually shut down by holding down the power button for around five seconds. Just reboot after shutting it down and it should have the effect you're looking for. Hope this helps!
Aug 26, 2011 | Computers & Internet
On-going problem where tv is turned on and almost immediatley says it will shut down because of an air-flow problem. After turning on several times it used to then work but lately it just repeats the same...
The fan is shorted and might be dead.The projection bulb been in the tv and used for the last 3 years?The projection bulb,life span are over.Require a new projection bulb.
Jul 04, 2010 | Mitsubishi WD-57732 Projection Television
My tv went out and I think I may have blown a fuse or something else went out. When I press the power button the green light turns on for a couple seconds and then just goes out. what do you think the...
NEXT TIME IT SHUTS DOWN: when green light goes out on THE FRONT OF THE SET: press and hold BOTH the menu and input buttons at the same time for at least 5 seconds and then release both.
This is the self check this model has---power light should blink a two digit code---for example--two blinks, a pause and two blinks and the set will repeat the error code about 10 times.
1 blinks and then 2 blinks is NO ERROR DETECTED
2 blinks and then 2 blinks is short protect
ETC.....Let me know if you get an error code and I will tell you what the problem is---hope you find 2,2 that is the most common and the most easy to repair.
SD TECH
Oct 22, 2009 | Mitsubishi WS-65807 65" Rear Projection...
While running the HP photosmart C4150 installion CD an alert popped up about 1/4 the way through the process. The alert was something like C:Windows/system32/services.exe must will shut down your computer...
there is something on your Operating System co'z it does not have any problem on your husband's unit. there might be a virus affecting your system that disturbed your installation setup because this type of virus sometimes attack on the drivers and utilities on the registry or drivers
Jul 11, 2009 | HP Photosmart C4150 All-In-One InkJet...
Car starts run's 3 seconds shuts down
Your car is equipped with a system called PASSKEY standard on all GM cars and light trucks, try the following procedure to reset the system, the battery being dead will trigger the system.
PASSKEY LOCKOUT RESET GM CARS 1999 UP
1) Put the key in the ignition and turn to the "ON" position. Leave it that way for 10 minutes. After 10 minutes turn the key and take it out. Repeat this process (2) more times (3 times, 30 minutes total) This should reset the passlock system to recognize your key.
Mar 30, 2009 | 1999 Pontiac Sunfire
Electrolux cyclonic bagless vacuum power problems
Hi
Sounds like a break in the cord. Normally its just where it enters the machine or just were it goes into the plug
Jan 11, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Pc starts up and shuts down repeatedly
hi
i think your memory timingg pro.if u hace two ram in your pc then try just one ram.
ccheck your motherbord dont touch the cabinet.
also check power cable, smps.
scan your pc with quick heal , avast and symantec antivirus with update definition.
i think most of your ram problem.check your single ram.try this.
Mar 22, 2008 | Computers & Internet
Power problems
There is most likely a software and/or driver confliction not allowing your system to shut down.  Have you recently installed new software or hardware?
Oct 18, 2007 | Dell Inspiron 6400 Notebook
NZXT NEMESIS ATX Mid-Tower Case Logo
69 people viewed this question
Top NZXT Computers & Internet Experts
David Payne
David Payne
Are you a NZXT Computer and Internet Expert? Answer questions, earn points and help others
