Question about Dishwashers
Kitchenaid dishwasher woudl not work MOD KUDPO1FLWH6
We have had problems with the dish washer for the last while. the only light on is the control lock Sanitize clean. Nothing happens when any of the other bottons pushed. I have tried the Heavy normal sequence. Nothing happens. Any Idea? Would replacing the door interfase help?
  • mansour_khoi Dec 07, 2008
    Thank you very much for the help. I did try the solution and it is working fine. Thanks again.
    President:
  • 2,651 Answers
Is it on steady??? or blinking??? if on steady try pressing nad holding the button with the "lock" symbol on/or above it, thinknits the heat button, for 3 secs it will "unlock" the controls, if blinkin then its a diff issue, may be a bad door switch not recognizing hte door being closed therefore wont start,
Posted on Dec 02, 2008
  • Chris Groll Nov 28, 2010
    Thank you very much it fixed my problem. My dishwasher is working.
My kitchenaid dishwasher kudc101xbl4 won't quit running or cancel / drain button light stays on and none of the other buttons work
If you wash your dishes off before you put them in the dish washer the sensor for the food particles won't pick it up and it will keep running. My repair man told me when he repaired my dish washer.
Sep 23, 2014 | Dishwashers
RINSE ONLY LIGHT BLINKING Kitchenaid KUDM01TJBS0
I want to know what was the exact maker/model, part# of your unit
Thanks
Jun 01, 2008 | KitchenAid 24 in. KUDM01TJ - Multiple...
Dishwasher not cleaning dishes properly
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
zzty
Jun 16, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Drying problems
Check the front control panel for a AIR DRY / HEAT DRY switch. Perhaps the switch is in the AIR DRY position. If so and you really want to HEAT DRY your dishes, set the switch for HEAT DRY.
Second, it is not a bad thing to let your dishes AIR DRY. It saves money! Just open the Dish Washer door after the last rinse cycle has finished and let the dishes AIR DRY manually. In a hour or so they can usually be put away.
You can also check for the heating element.Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element. Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thank you!
May 14, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
I have a 2006 tall tub kitchenaid dishwasher which over the last 6 months has been leaving residue on the dishes, esp. glasses. We have had it serviced twice. Last Wed was the last time and he found food...
Try changing the type and brand of detergent. We had similar problems with a Maytag dishwasher which was solved by the above. The glasses in particular seemed to have a sand-like texture in the debris, yet drinking water showed no such problem. Hope this helps!
Apr 13, 2010 | KitchenAid 24 in. KUDP02CR Built-in...
Hi! I'm having a problem with my dishwasher its a Kitchen Aid Mod # KUDK03CTSS3 It's is just rinsing the dishes then stops completely and the start/resume button flashes!
have you found a solution? i have the same model and it won't take the detergent and only rinses the dishes. please let me know! thanks.
Sep 26, 2009 | KitchenAid Dishwashers
KitchenAid dish washer: Control Panel Problem
Circuit board/ Electronic control assembly needs to be replaced.
Jul 24, 2009 | Dishwashers
KITCHENAID dishwasher will not dry the dishes
kitchen aid mod kud101dl does not clean dishes well. lot of scum on door.
Feb 26, 2009 | KitchenAid Dishwashers
Diswasher stopped working
there is a fuse in the washer that needs to be replaced reply to me and will walk you through it
Dec 31, 2007 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwashers Logo
280 people viewed this question
Top Dishwashers Experts
