Question about Panasonic DMR-E30 DVD Recorder
Panasonic DMR-BW500 Bluray/dvd recorder not region free
I ordered a Panasonic DMR-BW500 bluray/DVD recorder and was told it would be region free.I just got it and it is locked to region 4, How can I make it region free??
  • 10 more comments
  • fourieoj Dec 02, 2008
    My Panasonic DMR-BW500 bluray/DVD recorder is locked to region 4, how do I unlock it to make it region free??
    Panasonic DMR-BW500 bluray/DVD recorder is locked to region 4 playback for normal DVD's.How do I make it region free??
  • fourieoj Dec 03, 2008
    Panasonic DMR-BW500 locked to region 4 playback for normal DVD's,how do I make it region free??
    Panasonic DMR-BW500 bluray/DVD recorder locked to region 4 playback for normal DVD's,how do I make it region free??
    Still no Luck!!
  • fourieoj Dec 04, 2008
    Panasonic DMR-BW500 bluray/dvd recorder is locked to region 4 for playback of normal DVDs, how can I make it region free??
    Panasonic DMR-BW500 bluray/DVD recorder is locked to region 4 for playback of normal DVDs, how do I make it region free??
    Panasonic DMR-BW500 bluray/dvd recorder is locked to region 4 for playback of normal DVDs,how do I make it region free??
    Panasonic DMR-BW500 bluray/DVD recorder is locked to region 4 playback for normal DVDs,how do I make it region free??
    Pansonic DMR-BW500 bluray/DVD recorder is locked to region 4 for playback of normal DVDs,how do I make it region free??
    Master:
  • 479 Answers
The region code is not available online for this dvd player.hence trying wrong codes can by chance make the player stuckup or currupt .so its advisable to get this codes from the company servicenter or replacing the device.
Posted on Dec 14, 2008
    President:
  • 2,110 Answers
Turn On the unit with the remote controller
Wait until "no disc" appears in the unit's display
Press Pause, 3, 1, 4, 1, 5, 9
The word "CODE" should appear in the display
Within five seconds, press the key that corresponds to the zone you want i.e. 0 for region free, 1 for region 1, 2 for region 2 and so on
Again, within 5 seconds, press Pause and Power
If the above fails to work then you may wish to try the following:
Put the player into Standby mode
Press 1 and Return on remote for region 1, 2 and Return for region 2, and so on. Use 0 and Return to return player to default region settings
Press P-Mode and Return to play DVD's with the selected region, auto-switching is Off
Press Audio and Return for auto-switching On
Press Angle and Return for MacroVision On
Press Subtitle and Return for MacroVision Off
    President:
  • 1,952 Answers
Have u checked in ur manual
Posted on Dec 06, 2008
  • 194 Answers
The best i can recommend is to contact the dealer
Posted on Dec 05, 2008
  • Cordderryl Pittman
    Cordderryl Pittman Dec 07, 2008
    please take a few mins to rate my responce
    New Friend:
  • 50 Answers
This must be a pretty new player as i cannot not find any information. However this company seems pretty legit and you when it becomes available i am sure they will have it.
http://www.digitalpinhead.com/dvd-unlock/?pu=false&srec=true
  • 51 Answers
1. Power on player with no disc inserted and wait for "No Disc" message on screen
2. (using the remote) Press PAUSE
3. Press the numbers 314159 in order. (player should now show "COdE - -" the same as below)
4. Press the number of the region you desire ( 0 = any region, 1 = US&Canada etc.)
5. Press PAUSE
6. Power off the player for a few seconds..power back up and insert your DVD disc!
Hope this works.Thank you.
Posted on Dec 04, 2008
    Sergeant:
  • 217 Answers
There r particular code to be entered to make irt region free.and that code is available with the sevice center only.so contacting service center is necessary for making it region free.every player haS its unique codes .so code for 1 dvd player will not not support other dvd player.
    Genius:
  • 1,239 Answers
Hi 1. Power on your machine
2. Press the Stop, Open/Close, Skip Forward and Skip Backward buttons on your player simultaneously and hold down for 3 seconds
3. A hidden menu should appear. Release the Stop, Open/Close, Skip Forward and Skip Backward buttons on your player
4. Select Region Number from the hidden menu and choose the Free option. DO NOT make any selections from the Initialised 'Type' menu, this can leave your machine inoperable. If you do by accident, go back to this menu and select option 1.
5. Exit the menu
To convert this player to Multi-Region if the above doesn't work
2. Press the Stop, Open/Close and Skip Forward buttons on your player simultaneously and hold down for 3 seconds
3. A hidden menu should appear. Release the Stop, Open/Close and Skip Forward buttons on your player
4. Select Region Code from the hidden menu and choose the Free option. DO NOT make any selections from the Initialised Type menu, this can leave your machine inoperable. If you do by accident, go back to this menu and select option 1.
5. Exit the menu
6. Your player should now power itself off
  • ABHISHEK.C
    ABHISHEK.C Dec 04, 2008
    hi sir i given a correct solution.did you tried it what i suggested.........please check it
  • ABHISHEK.C
    if it relly doesnt work here is my best solution to reset to factory settings
    To restore players factory region code
    1. Be sure players drive is empty (nodISC)
    2. Enter following key sequence using remote control:
    Enter, 6, >=10, <<, 00F2, Audio, 8, 9, Subtitle, 1
    3. Player will reset and set to factory region code
  • 76 Answers
You cant you have to just use it the way it is. The reason why you cant change it is because the lense itself is programed by the dvd recorder to only read region 4 dvds or blueray discs.
If the person you purchased the machine from said that it is region free and it isnt then you should take it back and explain your problem.
If you have anymore questions please dont hesitate to ask
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, your location and/or where you purchased the unit would be a significant factor. If by chance you are in Australia and/or the unit was purchased in Australia, then to my understanding, "regional lockout is unconstitutional in Australia", there are no hacks, sorry.
Panasonic Australia Austlink Corporate Park 1 Garigal Rd Belrose NSW 2085. Tel: 132 600. Fax: 02 9986 7450
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Dec 12, 2008
    Hi again,
    Any updates or developments so far?
  • Panasonic Master
  • 586 Answers
  I can provide you the information that how can your DVD player get work to region free.
Inform me if you want.
    Sergeant:
    Champion:
  • 251 Answers
Call panasonic at 1800211pana
Posted on Dec 03, 2008
  • 541 Answers
  • Lee Reynolds
    Lee Reynolds Dec 06, 2008
    plz can you rate me
  • Lee Reynolds
    Lee Reynolds Dec 07, 2008
    plz can you rate me
  • 10,594 Answers
Manual of DMR-BW500 clearly says that...
≥Playback of the following discs is not possible.
–BD-Video discs that do not include region “B”.
–DVD-Video discs that do not include region “4” or “ALL”.
≥The region management information for BD-Video/DVD-Video indicates that the disc
conforms to industry standards. You cannot play discs that do not conform to industry
standards or do not have a region code or number.
Now sales person didn't said some thing correct about "region free"
  • 1,800 Answers
  1. Power on
  2. Open tray
  3. Push the info on remote once (with supplied remote) You will see numbers.
  4. Press 9 for multi-region. keep trying until you see the number 9 appear in upper left corner
  5. Power off
  6. Power on
  • Jalal Sordo
    Jalal Sordo Dec 03, 2008
    REGION 1 -- USA, Canada
    REGION 2 -- Japan, Europe, South Africa, Middle East, Greenland
    REGION 3 -- S.Korea, Taiwan, Hong Kong, Parts of South East Asia
    REGION 4 -- Australia, New Zealand, Latin America (including Mexico)
    REGION 5 -- Eastern Europe, Russia, India, Africa
    REGION 6 -- China
    REGION 7 -- Reserved for Unspecified Special Use
    REGION 8 -- Resevered for Cruise Ships, Airlines, etc...
    REGION 0,9 or REGION ALL -- Discs are uncoded and can be played Worldwide
  • Jalal Sordo
    i told u how did u read that above Sir??
    that is working for 97% of DVDs of the world
  • 849 Answers
It is better to return them back with thank and get another one, test the other at their place.
Posted on Dec 02, 2008
    Brigadier General:
  • 3,614 Answers
Click here and follow the instructions.
    Genius:
  • 2,035 Answers
Please refer to page number 84 in the manual and set to 8 to play all the DVD in the player.. if you want online manual you click on this link:
http://www.panasonic.com.au/support/downloads/search_results.cfm?productID=6720&productCategoryID=192&formSubmitted=yes
Download owners manual..
Good luck....
  • Anand Kumar
    Anand Kumar Dec 03, 2008
    This unit plays DVD-Video marked with labels containing the region number “4” or “ALL”. Please which box you received you can contact make exchange to get all player which is region free...
  • Anand Kumar
    This unit plays DVD-Video marked with labels containing the region number “4” or “ALL”.The box unit you have received is locked to region 4 you need to contact panasonic get it exchange to "All " region player ....
    Good luck...
  • 3,037 Answers
It should be region free, where did you get it from, I would take it back and exchange it for a different one and make sure that it is region free before taking the new one home as they should be region free out of the box but maybe you got the one unlucky one. You can also call Pansonic about this, if you need their number let me know.
    Genius:
  • 1,447 Answers
Hi
Have you tried inserting a disc that supports a different region? panasonic service representative have this option or codes. have you tried contacting them? since this will require some step by step process.
Hope this helps
What is the unlock code for a panasonic bluray/hdd recorder DMR-PWT540
you can find almost any code you need by googling: unlock region code
Dec 11, 2014 | Panasonic Televison & Video
Sorry should have added - I need the region free fix/code for the Panasonic Blu-ray Disc Recorder (DMR-BWT835) - without having to buy a universal remote.
Bluray players cannot be updated to add more regions. You will need to purchase a Bluray player that supports the region of the movies you are trying to watch.
Sep 21, 2013 | Televison & Video
I have a Panasonic DVD player DMR-PWT500 which will not play region 2 DVD's how do I unlock it please
Sep 07, 2013 | Panasonic Audio Players & Recorders
Hello, how can i unlock blu ray DMP-BD110 from Panasonic? The DVD and the BluRay so I can make them ALL region? I live in Europe. Regards Eduard
You cannot hack the BluRay capability to make it multi region, that's impossible on almost all makes and models. But if your computer has a recordable BluRay drive then you can use software such as DVD Fab to copy the disc onto a blank BluRay disc and remove all region coding and other protection so that it will play in any BluRay device.
The DVD region coding on your machine is also currently unhackable without a special servicing remote control. You cannot buy nor hire them as they are only available to authorised Panasonic service centres, but you can expect that fairly soon there will be 3rd party suppliers who will have reverse engineered the coding and will be selling or renting suitably modified service remotes. But for the same money or less you can buy a perfectly good ready hacked or very easy to hack DVD player form one of the usual budget brands known for easy DVD hacking. Alternatively if you have software as previously mentioned it will also do the same job for DVD's.
Note that I only mention DVD Fab as it's what I use. It's certainly not cheap but it's never failed me and there are other products which claim to do the same job, but as I've never used them I must leave you to choose amongst them.
Aug 02, 2011 | Televison & Video
Is the panasonic dmr bw500 a multi region player, ie I am in australia (region 4) and want to buy a region 2 dvd to play on it. Will it work???
I can't let a fellow Aussie pass so some good news and some bad. The BluRay player is region b but the dvd part of the unit is multi region. So YES it will work as long as it's not BlueRay. Whether or not a fix will be available at a later date to change the BlueRay to multi region is something you may have to wait for. It sure would make a top unit even better. I certainly wouldn't refuse one.
I hope the news is good mate
Apr 10, 2010 | Panasonic Electronics - Others
1-800-211-PANA (7262)
Let me know if you need anything else, like I said, it should've come unlocked, good luck
Dec 02, 2008 | Televison & Video
I need to make my Panasonic DMR-BW500 bluray/dvd recorder region free!!
Looks like you are out of luck for now. I just checked the site I have used a few times to turn off the region on my dvd players and there is nothing for yours. You can check back again later to see if something is posted
http://www.videohelp.com/dvdhacks//9659
Dec 02, 2008 | Panasonic DMR-E30 DVD Recorder
Panasonic DMR-E30 DVD Recorder Logo
227 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
