It starts and stalls
SOURCE: jeep liberty 2002 air conditioning
please elaborate, does your inside fan still works? does your compressor clutch kicks in?...would you know if you have refrigerant in your system? if you can trace the hose from the compressor to the evaporator, you can see a plastic cap normally blue with a big letter "L" at the top, then it is the low side fitting, you can remove the cap and get a pin and press the pin at the center( be carefull, refrigerant might be present). if there is none, then you have a leak. u lost all of your refrigerant that is why the ac did not work. if you do have a big burst of gas as you press it, then it is not a refrigerant problem,
a lot more to be tackle as you help me diagnose your problem.
tnx
drcool
pls rate me..
SOURCE: can you help i have a 2002 jeep liberty 3.7 have
try this website and pages 9-77 to 9-82 are the timing belt/chain and sprockets pages.
http://www.scribd.com/doc/3287172/Jeep-KJ-2002-Liberty-Service-Manual-PDF-Secc-09-Enging-3-7L
SOURCE: 2002 jeep liberty interior fuse diagram
1-20amp-pwr outlet frt. 2-10amp-rear fog lights(export only)
3-15 amp-horn 4-10amp-hedlt low beam rt
5-10amp-hedlt low beam lft 6-20amp-bodycontrolmodule/pwr dr locks 7-spare 8-spare 9-10amp- rt pk lt /rt tail lt/trailer tow lt/cluster
10-spare 11-15 amp-flasher 12-15 amp-stop lts
13-10amp-bodycontrolmodule/cmtc/cluster 14-spare
15-10amp-pdc fuel pmp & auto shutdownrelays/skis
16-20amp-pwr outlet rear 17-15amp-rear wiper 18-20amp-radio choke relay 19-20amp-frt fog lts/trailer tow stop and turn lts
20-20amp-sunroof 21-spare 22-10amp-wiperswitch/frt and rear washer 23-10amp-lft park lt/lft tail lt 24-10amp-pdc blower motor relay 25-10amp-heatseatswitch/hvac controlhead/trailor tow battery charge 26-10amp-hedlt highbeam rt 27-10amp-hedlt highbeam lft
28-spare 29-15amp-heated seat module 30-10amp-heated mirrors/rearwindowdefrosterindicator 31-20amp-cigarlighter
32-10amp-radio/frtdoorlockswitches/bodycontrolmodule
33-10amp-skis/diagnostic connector 34-15amp-cluster/courtesy lts/radio/bodycontrolmodule/maplights/cmtc/underhood lt/vanity lts
35-spare 36-10amp-ignition run/start-orc/lft and rt siacm
37-10amp-ignition run only-orc 38-10amp-abs module/brake shift interlock solenoid 39-10amp-rear window defroster relay/flasher/backup lts
starts and stalls? or stalls while running awhile?
Starts and stalls when shifting in second
