SOURCE: ford focus c max towbar electrics
ARE YOU READY
L.H. STOP AND TURN ( YELLOW )
R.H. STOP AND TURN ( GREEN )
TAIL, LICENSE, SIDE MARKERS ( BROWN )
GROUND ( WHITE )
NOW THE COLORS ON THE VEHICAL ARE GOING TO BE DIFFERENT AND YOU WILL NEED A 12 VOLT TEST LIGHT FOR MAKEING SURE YOU HAVE THE WRITE WIRES FROM THE CAR TO THE TOE BAR, DON'T NEED BACK UP TIGHTS FOR THIS
SOURCE: ford focus c max 2005 towbar wiring instructions needed
probably you have to open the tail light bulb and connect the wire there
SOURCE: I want to fit towbar electrics to my Ford c Max
You can wire directly to the rear light wiring behind the trim carpets on both side, however you must use a bypass relay system on the indicator circuits as the flasher unit overloads and switches off if more that 1 extra lamps are connected.
SOURCE: Towbar Wiring Instructions Ford Focus
On the left inside the boot behind the carpet is a blue connector, this has all of the wires for the rear lights. if you use a test lamp you can identify which wires do what and connect as you go. Use a self tapping screw for earth.
sorry i might have misled you its a ford focus 2000 estae
