Question about Brother PE-150V Computerized Sewing Machine
My Brother PE150 keeps telling me to check to see if threads cut.
And neither thread is cut. It also keeps breaking needles. I have cleaned it changed bobbins, thread and of course needles (including trying different sizes).
  • 399 Answers
SOURCE: I have a Brother SE-270D
its the problem of the timing belt in your machine its extra loosen or extra tightned or is slightly came out of its position or finally broken.
as the machine is proper just missing the proper speed as it should be .
it is running continuosly as you stated.
check the timing belt and make it proper if its worn out and needs replacement this is how its done
There is an adjusting screw on the right side of the machine head. Follow the motor bracket to the machine head and loosen that big old screw or bolt which will raise or lower the motor giving you slack to remove or replace the belt.
feel free for further queries
thanks
Posted on Sep 19, 2008
  • 201 Answers
SOURCE: needles keep breaking & bobbing wont feed thru
First try taking your bobbin case right out of the machine (not sure if this model has a top loading or front loading bobbin, but your manual will help you here) and floss out the tension slot with a piece of strong thread. Don't use waxed dental floss, but non-waxed would work okay. (The bobbin case is the piece that the bobbin sits in.) Look around while you have the machine open and remove any fluff and thread you can see - TURN MACHINE OFF BEFORE DOING THIS! Replace bobbin case. Replace bobbin and make sure it "clicks" into the tension slot.
Then unthread the top of the machine, clean the tension disks by passing a folded dollar bill (or any paper money, depends on what country you are in) through the disks in the direction you thread the machine. Do this several times. Re-thread making sure you follow the correct thread path.
Make sure the needle plate is on firmly.
If after all that it still won't work, I'm sorry to say that it sounds like you have a misaligned needle bar. This commonly happens after you have a major thread snaffoo and needle breakage. The needle gets caught in the thread knot, pulls to the side and breaks but if it gets seriously caught it can pull the needle bar out of place. You cannot put the needle bar back in place yourself - it's a job for the workshop. Don't sew on your machine until it is fixed. The noise you are hearing is likely to be the needle striking against the needle plate or even the bobbin. Your timing will probably need re-setting too and this needs to be done by a qualified technician.
If you really need to sew before you can get your machine into the workshop, and if you can move the needle position on your machine by pressing a "sideways" button of some sort, you could try to get the needle in the centre yourself using this feature. This will not help if it is the timing that is the major problem.
Pam M.
Posted on May 03, 2009
SOURCE: Set the timing
bbragg77 solution lacks a few points that I found out after talking to someone who repairs the machines.
Turn the balance wheel (counter-clockwise) so that the needle moves down and the hook is supposed to be spinning counterclockwise. As the needle reaches the bottom and starts to come back up, stop when the need reaches approximately 2 mm off the bottom. In this position, the point of the hook should be directly behind the needle.
Posted on Jul 25, 2009
chrismyers67
  • 53 Answers
SOURCE: top thread keeps breaking
This sounds like a backwards needle. Take out the needle and when you re-insert it back in, make sure that put the flat side to the back.
Posted on Jun 07, 2010
SOURCE: The bobbin thread is not
try a new needle
make sure the bobbin is not warped
make sure the bobbin case area is free of lint or loose thread
make sure you hold the upper thread tail while it's going down to pick up the bobbin thread
make sure there is a 2 to 4 in tail for the upper thread to grab
Posted on Aug 02, 2010
My brother pc700 the thread is fraying and some times it breaks
Make sure thread tails are at least 6" long when you put underneath your presser foot. Also, make sure you turn hand wheel toward you until metal take- up lever raises to highest position. Make sure needle inserted ALL THE WAY UP in needle bar goove and secure needle clamp. I M P O R T A N T: presser foot must be raised all the way UP before threading machine and pull thread TAUT when threading machine so thread can locate into the tension slots correctly. Thread still breaks? Please clean bobbin case and feed dogs for fuzz balls, lint, and anyoose broken threads! Hope this helps! If so, please give me rating for my free service. Happy sewing! Jimmy
Apr 06, 2012 | Sewing Machines
Brother ls 1717 keeps breaking upper thread. I have rethreaded and put in a new bobbin. Please help. What can I do to correct this problem?
Change needle--flat side goes toward back of the machine
Clean under needle plate where feed dogs are for lint
Clean bobbin area for lint or loose threads
Check tension 3 or 4 is usually good
watch the thread take up lever --some machine have a problem that the thread comes off the lever
make sure the needle & thread are compatable
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Nov 24, 2010 | Brother LS-2125 Mechanical Sewing Machine
Thread keeps breaking
change the needle
Rethread machine top thread make sure to get every thread guide
& bobbin
Nov 21, 2010 | Brother XL-2600
Top thread on my Brother Limited Edition 350 Sewing machine keeps breaking. Having used the automatic cutter, the thread pulls up and out of the needle when I want to start sewing again. Also the machine...
rethread the machine
try a top thread tension of 3 or 4
change the needle
always keep a thread tail of 3-5 inches on top & bobbin thread & keep the thread pulled back behind needle before starting to sew
always keep the bobbin area clean of lint & loose thread
& check under the needle plate for lint also
you might consider having the machine serviced, since you said it sounds like a tractor
some needle & thread are not compatable-try this
Nov 04, 2010 | Brother Sewing Machines
Why dose the thred keep breaking even when im useing heavy dudy thred
try rethreading the machine
the thread tenison may be to tight
the needle could be damaged
needle & thread may not be compatable--here's how to tell
Oct 11, 2010 | Brother LS-2125 Mechanical Sewing Machine
Brother pe150 won't pick up bobbin thread
Hi. This may sound silly, but the most likely reason the upper thread doesn't pick up the bobbin thread is that the needle is in backwards. (Sounds silly, but it's true!)
Needle shanks have a flat side and that flat side has to go in a particular way for your machine. With most modern machines, the flat side goes to the rear, facing away from you. Check your manual to be sure.
The second most likely reason is that your needle may be bent. Check that your needle is straight (or just use a new one).
Hope this helps!
Happy Sewing,
Robbie
Mar 14, 2010 | Brother PE-150V Computerized Sewing...
Brother 1034D
I had the same problem with the blue thread- it would sew and inch then pop- mine worked wihtout breaking after I re threaded in this order: green, blue, red then yellow
Jun 08, 2008 | Brother 1034D Mechanical Sewing Machine
Brothers pe150 embroidery machine will not sew
If you tighten up your needle thread, reduce the tension of the needle thread.
For embroidery, and zig-zag, and because the needle makes side movements, it needs more needle thread.
So try to keep you needle thread not very tight,
and tight up your bobbin case tension more, so that the two threads meet under the meterial.
Mar 30, 2008 | Brother PE-150V Computerized Sewing...
Brother PE-150V Computerized Sewing Machine Logo
80 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
