Question about Hotpoint Dryers
How to rebuild hotpoint dryer timer - Hotpoint Dryers
  • Hotpoint Master
  • 3,463 Answers
Generalluy speaking, it is not possible to rebuild a timer sucessfully. I speak from experience
Best to replace it.
Posted on Dec 02, 2008
Hotpoint tcym 750c tumble dryer serial number tcym750c6p. The wires attached to the timer control and start button have disconnected does anyone know how they go back on?
images for Hotpoint tcym 750c tumble dryer wiring
Hotpoint TCYM 750C Style - YouTube
? 3:07
https://www.youtube.com/watch?v=RjQMN6U4PdE
Oct 8, 2012 - Uploaded by Missing Sleep
Hotpoint TCYM 750C Style. Missing Sleep ... How to replacetumble dryer belt Hotpoint, Indesit, Ariston, Creda, Proline etc - Duration: 9:36. by ...
Hotpoint tcym 750c tumble dryer serial number tcym750c6p ...
www.fixya.com/.../t25992053-hotpoint_tcym_750c_tumble_dryer_seria...
48 mins ago - SOURCE: Reconnect wiring on a Hotpoint VTD00 tumble dryer. most electric dryers have a wiring schematic on the back or inside on the back ...
Dec 03, 2015 | Hotpoint Dryers
Can i bypass the timer on my hotpoint aqurius dryer
no timer controls everything turns it off on and controls heat to turn on and off stats are there for temp reading and cycling
guess if you want to burn your house down it can be done but why
buy the timer
Nov 15, 2014 | Hotpoint Dryers
Hotpoint TVM572 timer is faulty
It is important not to open the door of the dryer if it is still running. The timer controls the cooling cycle otherwise the clothes will get damaged if kept on hot.
It is very likely the timer contacts are frozen at some point and the timer will need some attention.
It is not hard to locate it. I cannot find the actual parts drawing for your model (it is good you have provided the full model details). But to help you locate the part I have found another Hotpoint model that may be similar to yours. Check this drawing to see if the front panel is similar.
Item 100 is the timer.
HOTPOINT Electric Dryer Backsplash blower moto Parts Model NWSR483EB1WW
The actual timer for your model looks like this.
Hotpoint TVM572P Timer
As the clothes are not getting burnt or singed I will assume the thermostat is ok and keeping the temperature within the range.
Aug 07, 2014 | Hotpoint Dryers
THE WIRES MIXED UP ON MY TUMBLE DRYER HOTPOINT VTDOO TIMER
In most appliances I've had apart there is a stick plasic envelope stuck somewhere inside the cabinet or the control panel that contains the wiring diagram.
Nov 24, 2013 | Hotpoint Dryers
Hotpoint nvlr333etowb no heat.
Diode? Ain't no diodes. 3a90295.jpgIf all of theses items check good you might have a burred contact inside the timer. These dryers have a timer that is easy to take apart. Gently remove the motor and cover, look for a burr between the leaf switches. File em down smooth. Let me know.
May 08, 2010 | Hotpoint NVLR333EE Dryer
Need to know how to reconnect the timer on a hotpoint dryer
As you do not state the model number of dryer, it is virtually impossible to be of any help here, as there are literally hundreds of different models of Hotpoint dryers produced over the years.
I suggest you go to the Hotpoint web site and see if they can help.
Feb 02, 2010 | Hotpoint Dryers
Hotpoint tumble dryer CTD00 timer
It is not a difficult job...the thing to keep you out of trouble is to make sure you get the right timer switch, then remove one wire at a time.
Remove one wire from the old timer and put it on the new timer, there is not that many wires for your timer.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Nov 05, 2009 | Hotpoint Dryers
The timer on my Hotpoint dryer doesn't work
More than likely the timer.  If it works automatic and timed it is definitely the timer.  You can usually find them on ebay with a decent warranty, or depending on how much confidence you have in your mechanical ability take the timer apart, look for the burned contacts, clean them with sandpaper and bend them SLIGHTLY.
Oct 25, 2009 | Hotpoint Dryers
Heats take long to dry and timer won't move
The timer not moving means that the timer has gone bad. The heating problem may have to do with the timer too. You can take off the vent tube of the dryer and make sure it is not restricted (from dryer to outside) If this is plugged it will also take longer to dry your clothes.
Feb 10, 2009 | Hotpoint NVL333EY Electric Dryer
Dryers Logo
181 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
