Question about Fisher and Paykel DEGX1 Electric Dryer
Fisher & Paykel DEGX1 dryer has popped off its belt
The drum stopped rotating on the dryer. I removed the front panel and can see both the belt and the pulley that it came off of. I can not reach the pulley and can not figure out how to remove the back and side panel so I can reach the pulley and put the belt back on. Need to know how to remove the 3/4 panel that covers the sides and back.
I need to replace the belt
Posted on Dec 27, 2008
    Problem Solver:
  • 4 Answers
The inside of the dryer is accessed by going in from the front. To do this: 1) Disconnect the Dryer from the wall plug before starting to remove covers. (Safety first, always)
2) There are two plastic plugs towards the front of the top cover. Remove thes by prying up on the side of them with a small screwdriver. Then remove the two Phillips Head screws beneath the plugs. This will allow you to raise up the top of the dryer. Be very careful and do not let the top lid fall backwards behind the dryer or everything attached will get ripped out. Have some help on hand to assist you.
3) Once the top cover is up, you can pull the front cover off. It clips into the side panels with plastic clip which align the side covers. Pull the front cover forward slightly, then push out on the side covers and the front cover will come off. There will be a green ground wire that attachs to this cover that will have to be removed. Set the cover out of the way.
4) If the belt is just derailed off the dryer tub, you should be able to remount the belt at this point.
5) Reverse the procedure and put the dryer back into service.
6) IF the belt comes off again, I recommend changing the belt because it is probably warped, pulled, or otherwise distorted.
Posted on Dec 15, 2008
No matter which cycle I select, why does it go to cool down and continues to beep non-stop?
Clean the vent screen and the vent pipe, apparently the dryer cannot cool down properly because the vent is plugged.
Sep 18, 2015 | Fisher and Paykel DEGX1 Electric Dryer
How do take my fisher and paykel AD55 clothes dryer apart to check the if the belt is loose or not, because sometimes to have to manually turn the drum in order for it to start spinning again. Heat and...
sounds like the maybe the drum roller or motor, here is a video. Hope it helps Tim:
http://www.appliancerepairlesson.com/2011/03/05/fisher-paykel-dryer-access-3/
Apr 15, 2011 | Fisher and Paykel DEGX1 Electric Dryer
We have a loud noise when the dryer turns. Sounds like metal on metal.
This is usually the front drum bearings that are mounted to the front panel. Raise the cabinet top to check. Hope this helps!
Oct 16, 2010 | Fisher and Paykel DEGX1 Electric Dryer
I have a FP Electric Dryer DEGX1US and it is squeaking like crazy! Can you help?
more than Likely the rollers that hold the drum,, you have to remove the drum (be sure and look before to see how the belt tensioner is set up) pull the drum, Lube the rollers , and reassemble
Aug 02, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Dryer not providing any heat during cycle
Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ Check posts on "Heaters" in this forum will work you through your problem
Jun 26, 2010 | Fisher and Paykel DEGX1 Electric Dryer
I have the pull string of a light fixture caught up in the dryer drum or motor.(it is not visible from inside the drum I need to know how to access into the drum area to remove the string. It is causing...
Pull up on the top ... many machines are held down with a spring type clip and there may be a couple screws to remove. With the top up, you will see how to pull the front off. Remember there are wires on the door. Swing the door to the side and the drum will follow.
I hope this helps you
a
Sep 29, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Wont start. Extra dry light on and cool down light on.
Fault #3 Drum Stalled; unable to move.
  1. Check drum movement mechanisms: belt, motor and motor harness (if motor moves drum slightly, treat as fault #2)
  2. Replace the motor control module.
  3. Replace the motor.
Fault #2 Drum Gap Cannot be Located
  1. Ensure sensor module is correctly located and clipped in.
  2. Replace the lens on the sensor module.
  3. Replace the sensor module.
  4. Remove Top Deck and clean the sensing bumps on the outside of the drum end.
  5. Replace the drum.
May 02, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Fisher and Paykel DEGX1 Electric Dryer Logo
313 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
