Question about HP Compaq P900 (Pearl, White) 19" CRT Monitor
Monitor setting when i start using this type of monitor, i alway configure the monintor setting such as, widht, height, position, bight and contrast. but after few day, when i turn on my pc again, it's alway go to the default setting. when i test it with other computer, it's not change to default setting. Why? it have problem with brand name "DELL OptiPlex 745" with VGA 256MB PCI Express.
    Novelist:
    Champion:
  • 202 Answers
Http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=223913&lang=en&cc=us&prodTypeId=382087&prodSeriesId=221018&taskId=135 Here is the site to update the monitor drivers for the P900. http://www.nvidia.com/page/pci_express.html not sure what kind of video card you have but you should update the drivers too. I just put the nVidia site incase that was your brand. Good Luck, Tim.
Posted on Feb 13, 2007
SOURCE:
Come to work Monday (today) and turn on monintor , light up for a second and then off and now will not come on. Used another monitor on pc , no problem. This is the second monitor that did it to me.
is this a crt monitor or a lcd monitor? if it is a lcd monitor then your problem is a bad back light power inverter board and needs to be replaced. if it is a crt monitor then check the brightness and contrast controls on the crt monitor.
also check to make sure that the display are compatible with the crt monitor as well! meaning that if the crt monitor's max resolution is 1024x768 and your video card is set to a higher setting then you will get a blank screen with a sometimes green power light, maybe flashing. be very careful though because may also damage the crt monitor. also check your video card setting to make sure it is at 50 hz or 60 hz some crt monitors don't like the higher vertical refresh rate.
one last thing is the age of the crt monitor, it may be on its last leg of life. when i worked at a monitor repair center a few moons ago there was a life expectancy of maybe 30,000 hours(?) on a crt(note: it's been awhile so please don't quote me on this life expectancy!)
you may get eye strain with higher than 60hz range.
Aug 22, 2011 | Westinghouse Computers & Internet
I need the specific dimensions of a standard19"LCD monitor (ie, height, widht, lenght)...
Find the TV you want on line and read the dimensions from the web.
There is no standard size.
Jan 23, 2011 | Televison & Video
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
I have a samsung 14'' color monitor model no samtron40n & found pincusion problem. please send me solution
Most CRT monitors have buttons on the front of the monitor select a menu to adjust various settings such as the trapezoidal, pincushion, vertical and horizontal height size and position, brightness and contrast etc.
Apr 01, 2010 | Computers & Internet
I need to find the VGA controller for the Dell 2005FPW monitor
you can use on all vga cards(you dont need any special controler), this monitor has a USB hub
and its is detected normaly on winxp or above, and the vga cards detect the monitor auto.
i give you the monitor specs, take form website
Display Type LCD display / TFT active matrix
  • Built-in Devices USB hub
  • Width 18.6 in
  • Depth 9 in
  • Height 15.3 in
  • Weight 17.6 lbs
  • Enclosure Color Midnight gray
  • Image
    • Display (projector) image aspect ratio 16:10
    • Image brightness 300 cd/m2
    • Image Contrast Ratio 600:1
    • Max horizontal view angle +88 / -88
    • Max vertical view angle +88 / -88
    Display
    • Diagonal Size 20.1 in
    • Viewable Size 20.1 in
    • Dot Pitch / Pixel Pitch 0.258 mm
    • Max Resolution 1680 x 1050 / 60 Hz
    • Color Support 24-bit (16.7 million colors)
    • Max Sync Rate (V x H) 75 Hz x 83 KHz
    • Video Bandwidth 146 MHz
    • Response Time 12 ms
    • Controls / Adjustments Zoom , Clock , Phase , Contrast , Sharpness , Brightness , Saturation , H/V position , Color balance
    • Display Positions Adjustments Height
    • OSD Languages French , German , English , Spanish , Japanese
    • Display Screen Coating Anti-glare , Hard coating
    • Video Output None
    • Signal Input DVI-D, VGA
    • Features Picture by picture , Picture in picture
    Video Input
    • Analog Video Signal RGB , S-Video , Composite video
    • Digital Video Standard Digital Visual Interface (DVI)
    Audio Output
    • Type None
    Input Device
    • Type None
    Expansion / Connectivity
    • Interfaces 1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x DVI-D - 24 pin digital DVI , 1 x Composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 4 x Hi-Speed USB downstream - 4 pin USB Type A , 1 x Hi-Speed USB upstream - 4 pin USB Type B
    Miscellaneous
    • Flat Panel Mount Interface 100 x 100 mm
    • Features Security lock slot (cable lock sold separately)
    • Compliant Standards CE , CCC , MIC , NOM , PSB , BSMI , GOST , SASO , NEMKO , TUV S , C-Tick , TUV GS , EN55022 , TCO '99 , EN 60950 , ICES-003 , TUV Ergo , UL 60950 , IEC 60950 , EN 61000-3-2 , EN 61000-3-3 , FCC Part 15 B , VCCI Class B ITE
    Power
    • Form Factor External
    • Voltage Required AC 120/230 V
    • Power Consumption Operational 55 Watt
    • Power Consumption Stand by / Sleep 3 Watt
    Environmental Parameters
    • Min operating temperature 41 °F
    • Max operating temperature 95 °F
    • Operating humidity range 10 - 80%
    Sustainability
    • EPA Energy Star Compliant Yes
    Feb 13, 2010 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
    Contrast Blinking !!!
    its a harware issue nothing much can be done from your end really.......right time for hardware servicing
    Sep 03, 2009 | Computers & Internet
    Adjusting screen brightness and contrast
    press F2 when the computer starts, the bios page will appear, ALT+P to change the pages until you see the screen bightness options, then you can change it as you want. I hope this will help
    Oct 04, 2008 | Compaq Evo N800v Notebook
    More Brightness
    on the front of the monitor there are key buttons naming menu, ok button and left & right arrow marks buttons first press menu button then go to brightness then by using arrow keys you can increase & decrease the brightness once you are finished decreasing r increasing press ok button.& there are many other settings you can change like contrast etc....
    Feb 07, 2008 | LG Flatron 775FT 17" CRT Monitor
    Screen colors washed out
    You can RESET the monitor setting externally by clicking adjustment menu button goto RESET press ok. If contrast and birghtness not set properly light will not be properly visible
    Dec 10, 2007 | Samsung SyncMaster 940MW 19" LCD Monitor
    Processing auto configuration keeps coming up on my monitor
    Help! I want to get rid of the "Processing Auto Configuration"
    Dec 07, 2007 | HP w19 19" LCD Monitor
    HP Compaq P900 (Pearl, White) 19" CRT Monitor Logo
    87 people viewed this question
    Top HP Computers & Internet Experts
    Thomas F. Schneider
    Alun Cox
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
