Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Kenmore coldspot not making ice, and not cooling in the bottom
We have a kenmore coldspot model # 106742 69400 and it stopped making ice and isn't cooling in the bottom. The freezer is working though. We vaccumed the coils, any other solutions?
  • 172 Answers
Your refrigerator is frosted up. Remove the inside panel of your freezer. Defrost the ice out of the coils and check the heater and bi-metal. If both are good then your defrost timer is bad. If one is bad replace and you have it fixed. Good luck.
Michael Anderson
(865)945-3808
Posted on Dec 02, 2008
I have a Kenmore 55602400 Coldspot and the icemaker has stopped making ice. What do I need to do to fix it?
The model number you listed is for an air conditioner. Please check inside the refrigerator for the model number?
Oct 15, 2012 | Kenmore Refrigerators
I have a Kenmore Model 106-55602400 Coldspot and the icemaker stopped working. What do I do?
The control module has failed on the ice maker. You can replace the control module alone, but I would replace the ice maker completely.
Here is a link for the control module.
Here is a link for the new ice maker.
Kenmore coldspot model 106.58902800 ice maker does not dispense ice
Ice maker will not dump ice, makes it but will not dump ice.
Jan 30, 2012 | Kenmore Refrigerators
Kenmore coldspot model 106 9445781 the icemaker motor makes loud noise. Sounds like its under a heavy load.
Suggest you take the ice maker out and defrost it. You propably have ice crystal buildup and causing it to labor harder.
Jan 16, 2012 | Kenmore Side by Side Refrigerator
The Refrigerator isn't cooling. The Freezer works fine. There is ice build-up in the drain resulting in a drip inside the refrigerator. After being thawed, it re-iced within 48 hours. The fan is...
Due to the blocked drain it sounds to me as if the vents in the ceiling of the refrig. has frozen over so no air can be circulated from the freezer into the refrig. section. This tip i wrote will show ya how to clear the drain and addation to clearing the drain the ice build up would need to be removed from the vents. Here is that tip, http://www1.fixya.com/support/r9945686-check_when_refrig_cools_ok_but_leaks
GENE
Sep 23, 2011 | Kenmore Top Freezer Refrigerator
Kenmore Coldspot Ice Maker Modle #106 56622500 I
these have to be in correctly to lock back in and allow the unit to function. Try removing the bin again and be sure there isn't any small pieces of ice trapped anywhere. Also make sure there aren't any broken pieces from the bin. Hope this helps. Good luck.
Aug 18, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore coldspot refrigerator model #106 RUMBLING!!!
Does it have automatic ice cube maker not hooked up to water? If you do make sure thin stainless bar isn't straight down. on the side of ice maker.
Nov 15, 2017 | Kenmore Refrigerators
Kenmore Coldspot stop working
first ,do you have power to it,is the lights coming on?2-is there frost building in the freezer on the back wall?i think you have a defrost problem,let me know more-mike
Dec 15, 2008 | Refrigerators
Refrigerant problem
could be that the freezer is iced up and causes it not to cool properly, maybe try defrosting it
Oct 04, 2008 | Kenmore Refrigerators
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
453 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
